Old 11-17-2016, 08:11 AM   #113
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
Originally Posted by Gunman View Post
Very few times will you want the chassis to be softer, only once have I worked with a race car that needed braces removed. That was a NASCAR cup car, during the coil bind era, and when coil bound, the compliance had to come from someplace else, which is the chassis.
A very valid and unique situation, especially when you consider that the moment you have coil bind, you're effectively suspensionless. At that point (and ONLY at that point onward) the vehicle's chassis becomes it's suspension as well. But until that happens, any wheel movement needs to happen through the suspension, as that's the whole reason it's there, and a stiffer chassis will make it work more effectively and predictably.
Motorcycle frame design started allowing more lateral flex about 15 years ago to compensate for the extreme lean angles that race bikes were increasingly capable of producing. However, this is due to the uniqueness of motorcycles in that their suspension is effectively turned on it's side at these lean angles, and therefore unable to cope with vertical movement in relationship to the road surface. Certainly not applicable with cars. If you're trying to tune this car's performance by adding additional chassis flex, you've already screwed up your suspension selection.
The Following User Says Thank You to venturaII For This Useful Post:
Tokay444 (11-17-2016)
Old 11-17-2016, 06:38 PM   #114
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
I'd put this product in the same category as the TRD door stabilizers. I'm sure it does something positive but only difference I notice was a lighter wallet and having to close the doors harder than without. Looks cool though. lol
Intent > Content
The Following User Says Thank You to solidONE For This Useful Post:
NissanGuy (11-19-2016)
Old 11-19-2016, 09:26 PM   #115
NissanGuy
NissanGuy's Avatar
Drives: Strangely.
Lol I got those door latches too. I think it maybe made the car handle better, and totally ruined the ride quality.
My FR-S has a build thread!
(It's mostly full of Nissans)
NissanGuy is offline   Reply With Quote
Old 11-19-2016, 10:48 PM   #116
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Originally Posted by chaoskaze View Post
hey feeling traction with my butt is not my specialty.
When discussing butt dyno many people get traction and friction mixed up. This is why lube is suggested and according to the research I've seen is highly recommended.
The Following 4 Users Say Thank You to Captain Snooze For This Useful Post:
churchx (11-20-2016), Tcoat (11-19-2016), Ultramaroon (11-19-2016), weederr33 (11-20-2016)
Old 11-21-2016, 08:35 PM   #117
solidONE
solidONE's Avatar
I think I got better MPG's after the mod... sometimes.. depending on the weather.
To be fair, having driven my car with and without a front strut bar. I can say there there is a difference felt driving at the limit. I'm sure these strut bar/damper things will have some effect in the feel just as a solid bar has an effect. Probably somewhere between not running any bars vs just the stock bars.
Intent > Content
Old 11-21-2016, 11:46 PM   #118
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
If you guys want to buy me these things, I'll put them on my car and AB with both the bars on, bars off, and stock bars.
Old 11-21-2016, 11:52 PM   #119
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
For it to be accurate you will have to have someone else installing/uninstalling without telling you, so that you aren't biased when you know they are installed!
Originally Posted by humfrz
I'm old and lazy
Old 11-22-2016, 01:13 AM   #120
Captain Snooze
Drives: Red Herring
I think a better test would be to put one on just one side and keep the stock bar on the other side and see if you drive around in circles.
Old 11-22-2016, 01:56 AM   #121
stevo_12v
Drives: Mazda MX-6 Turbo, Toyota GTS86 37J
I'm gonna get this. Need more TRD in my build.
stevo_12v is offline   Reply With Quote
Old 11-22-2016, 02:42 AM   #122
EAGLE5
Dismember
EAGLE5's Avatar
But if I pay somebody to do that, they might just install them backwards.
The Following User Says Thank You to EAGLE5 For This Useful Post:
Clipdat (11-22-2016)
Old 11-22-2016, 04:45 PM   #123
solidONE
solidONE's Avatar
Looking at that list you got in your sig. I think this type of product is a perfect fit for you. lol Let us know what your impressions are when you install them.
Intent > Content
Prothane Motion Control Looking for Test Vehicle itsibarra Southern California 2 05-22-2015 12:13 PM
Motion Control Suspension coilovers xwd Tracking / Autocross / HPDE / Drifting 27 02-21-2015 10:24 PM
is there a shorter endlink out there? mcs motion control damper toby714 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 10-19-2014 07:28 PM
motion control suspension(mcs) spring length toby714 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 08-21-2014 11:42 AM
Motion Control Suspension andrew20195 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 03-30-2014 10:55 PM
