Old 09-20-2016, 10:22 AM   #15
Matt@Cosworth
Drives: blue - Cosworth SC stage 3.0
hi they should be ready for SEMA and we will offer std (0.78), 1.05mm & 1.45mm
works out as follows:
so stock = 12.5:1
1.05 = 12.1:1
1.45 = 11.6:1
Matt@Cosworth is offline   Reply With Quote
The Following 2 Users Say Thank You to Matt@Cosworth For This Useful Post:
celek (09-20-2016), xwd (09-20-2016)
Old 11-16-2016, 10:25 PM   #16
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Got the head gaskets in... we'll see if the price makes sense.
-alex
Old 11-17-2016, 03:15 AM   #17
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
so stock = 12.5:1
1.05 = 12.1:1
1.45 = 11.6:1
Any further update on this? What are the cons to reducing CR with head gaskets?
Fizz is offline   Reply With Quote
Old 11-17-2016, 10:37 AM   #18
celek
Resident Gear Head
celek's Avatar
Cons are limitation due to a fixed Chain length but plenty of slack for adjustment.
Lower compression is designed for forced induction. In the NA platform no benefit.
celek is offline   Reply With Quote
Old 11-17-2016, 08:41 PM   #19
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
I'm currently running turbo kit on pump 98. This may be a cost effective way of reducing some compression without going for a full bottom end rebuild. And with the heads out it would also be a good time to upgrade the valve springs which is also fairly cost effective. So yes very interested if this will work
Old 06-10-2019, 11:49 AM   #20
bhmax
Drives: 13 BRZ, 17 Focus RS
Looking for some head gaskets. Any feedback on Cosworth gaskets? Looks like they were discontinued, but some are still available.
bhmax is offline   Reply With Quote
Old 01-17-2020, 11:17 AM   #21
bhmax
Still looking for feedback on head gaskets. I had them replaced last year with Cometic and it seems I’ve now blown one of those.
Old 01-17-2020, 11:27 AM   #22
tomm.brz
Drives: brz 2017 hksv2
i just put Cosworth 1.05mm in mine
all good
bhmax (01-17-2020)
Stock exhaust gaskets/Perrin 3" gaskets migx333 Engine, Exhaust, Transmission 1 07-10-2015 11:23 PM
FA20 Aftermarket Intake Manifolds slava Engine, Exhaust, Transmission 13 03-20-2015 09:49 AM
HKS Stopper Head Gaskets for FRS and BRZ Hal@Dynosty Engine, Exhaust, Bolt-Ons 7 07-03-2012 07:48 PM
conversion fa20 head with fb25T block ft86-UAE Engine, Exhaust, Transmission 3 06-18-2012 10:46 AM
