Old 09-16-2016, 12:04 AM   #1
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Aftermarket head gaskets for FA20
Aside from Cosworth and Cometic, does anyone else offer a head gasket for the FA20/4U-GSE?
Thanks.
-alex
Old 09-16-2016, 10:04 AM   #2
-Phil
Drives: Rb25 neo brz
I do not believe there are any. if it makes you feel any better we use cometic for our builds and have never had a failure or quality control issue.
-Phil is offline   Reply With Quote
Old 09-16-2016, 10:48 AM   #3
Amputechture
Drives: 2014 BRZ
I believe HKS does as well.
Amputechture is offline   Reply With Quote
Old 09-16-2016, 02:53 PM   #4
celek
Resident Gear Head
celek's Avatar
Cometic is your only choice you should look at
celek is offline   Reply With Quote
The Following 2 Users Say Thank You to celek For This Useful Post:
fika84 (06-14-2019), Hostile_Kittens (09-19-2016)
Old 09-16-2016, 02:55 PM   #5
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
Yeah like mentioned above HKS makes 2 variations of head gasket
Old 09-16-2016, 03:03 PM   #6
celek
Resident Gear Head
celek's Avatar
Thin and Thicker
All motor and Turbo
Cometic will make you like 80 Variations of the gasket and thats no lie
The Following User Says Thank You to celek For This Useful Post:
go_a_way1 (09-16-2016)
Old 09-16-2016, 06:06 PM   #7
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Originally Posted by celek View Post
Thin and Thicker
All motor and Turbo
Good to know
Old 09-16-2016, 08:37 PM   #8
mav1178
mav1178's Avatar
Thank you.
I am working with a head gasket maker out of Taiwan, who is also an OEM supplier for several top tier brands out of Japan.
Trying to see if head gaskets make sense for the FA20 market since it's a new platform and many people boosting their cars don't opt for engine rebuild.
They can also offer many variations like Cometic. Also trying to target $100-150 price point.
-alex
Old 09-16-2016, 11:50 PM   #9
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
I ran oem on a properly decked block and heads at 30psi (600whp) for close to a year. Oem gaskets on a Darton sleeved block at around 700whp as well with no signs of failures or high coolant pressures when I tore that motor down.
Pure Automotive Performance
MoTeC
Build Thread
@spitfire481
The Following 2 Users Say Thank You to spitfire481 For This Useful Post:
Hostile_Kittens (09-19-2016), xkalelx (04-14-2017)
Old 09-17-2016, 07:27 AM   #10
Drakiv
Project Shadow
Drakiv's Avatar
Drives: 2015 BRZ Limited 6MT
Fullblown makes a headgasket as well, or at least its their spec.
FBM Stage 2 Turbo Project Shadow Build
614whp/421tq on E85
Instagram: Drakiv
Drakiv is offline   Reply With Quote
Old 09-18-2016, 03:18 PM   #11
Matt@Cosworth
Drives: blue - Cosworth SC stage 3.0
We're about to offer thicker gaskets too over the stock 0.78mm thickness
I feel I should also point out that our gasket is the only one to run closer to the chamber than the stock item, so reducing crevice volume
Matt@Cosworth is offline   Reply With Quote
The Following 3 Users Say Thank You to Matt@Cosworth For This Useful Post:
ajc209 (09-19-2016), Tokay444 (11-16-2016), weederr33 (09-18-2016)
Old 09-19-2016, 08:54 AM   #12
celek
Resident Gear Head
celek's Avatar
While true Cometic is offering 89.5mm as a catalog number which is backwards compatible to 86mm, they can make it an actual 86mm bore. I love Cosworth product but bias to my local company 10 min down the road. I have had so much success with them since 2001 when they got into the Automotive market. Yet to see one fail.
Originally Posted by mav1178 View Post
Thank you.
-alex
You will be very limited on any design changes. The factory gasket is actually 89.5mm bore size. The timing chain limits thickness changes. Honesty if you are investing it is not worth the tooling costs to recoupe if you are trying to make a thicker turbo gasket. I want to say Cometics price point is already like $140 a set and you can request any customization's free of charge. i.e larger head stud holes, bore size changes thickness changes ect....
Also the MLX design has a 3 die processed folded center layer like the HKS Stopper gasket at less than 1/2 the cost.
http://www.cometic.com/i-24767479-su...-5mm-bore.html
Old 09-19-2016, 01:28 PM   #13
mav1178
mav1178's Avatar
Thanks for the info.
The gasket is already made, I just need to figure out how many to bring in and what the market currently has.
Price point will be similar to Cometic, but at the end of the day it's all about what the market wants to pay for and use.
-alex
Old 09-19-2016, 02:47 PM   #14
xwd
When are these coming and how do they affect the CR?
Stock exhaust gaskets/Perrin 3" gaskets migx333 Engine, Exhaust, Transmission 1 07-10-2015 11:23 PM
FA20 Aftermarket Intake Manifolds slava Engine, Exhaust, Transmission 13 03-20-2015 09:49 AM
HKS Stopper Head Gaskets for FRS and BRZ Hal@Dynosty Engine, Exhaust, Bolt-Ons 7 07-03-2012 07:48 PM
conversion fa20 head with fb25T block ft86-UAE Engine, Exhaust, Transmission 3 06-18-2012 10:46 AM
