Old 06-17-2012, 07:09 AM   #1
ft86-UAE
turbo FT-86
ft86-UAE's Avatar
Drives: ft-86
conversion fa20 head with fb25T block
hello,
do some here now if we can make a hybrid between the to enignes. bigger block with fa heads?
that they share the same staff.
Thanks,
ft86-UAE is offline   Reply With Quote
Old 06-18-2012, 01:22 AM   #2
jedibow
post whore extraordinaire
Drives: 2013 Asphalt Grey FR-S 2003 Evo 8
Why would you want to?
If I'm thinking about this correctly you would end up either lowering the compression on the NA motor (2.5 block without turbo with the 2.0 head) ot increasing the compression on the turbo motor (if you left the turbo on the fb25). Both would lower the end results of the build, if you want a turbo, swap in the fb, or build the bottom end of the fa (lowering compression), or if you want NA check to see if you can swap the crank from the fb into the fa to increase displacement.
jedibow is offline   Reply With Quote
Old 06-18-2012, 02:39 AM   #3
carbonBLUE
Reverse Burnouts
Drives: 2013 Argento FRS
Originally Posted by ft86-UAE View Post
hello,
Thanks,
yeah but the pistons will have be different with a longer stroke, the cups wont maximize turbulence to mix the air and fuel properly, plus we dont know how the new heads handle forced induction just yet or if the bigger lower block with the fa20 heads will even clear the frame, plus the the FA20 has 2 ecus, find a tuning solution first before i would attempt a Frankenstein build
(wont forget you)
2013 Argento Scion FR-S
2011 Infiniti G37x
Old 06-18-2012, 10:46 AM   #4
3MI Racing
Pro Subie Engine Nerd
3MI Racing's Avatar
Drives: empty spot for an FR-S/BRZ
plus there is not FB25T
3MI Racing is offline   Reply With Quote
Block machined to take wet liners??? DoogenBurns Engine, Exhaust, Transmission 3 05-21-2012 01:41 AM
Engine Block # ichitaka05 Engine, Exhaust, Transmission 23 05-06-2012 05:33 PM
Open Deck Block nrclptcnsmniak Engine, Exhaust, Transmission 36 01-27-2012 01:00 PM
Ken Block Gymkhana 3 Midship Runabout Other Vehicles & General Automotive Discussions 24 09-14-2010 11:55 PM
