Old 10-31-2016, 10:51 PM   #1
phantasticity
Ricer
Airlift suspensions hose leaks
There's a hole on the air hose on my passenger side, is there a way I can fix it, or does it really need to be replaced??
phantasticity is offline   Reply With Quote
Old 11-01-2016, 01:29 AM   #2
Michael
Lovin' the Low Life
Michael's Avatar
Drives: 2014 Scion FR-S
Simple answer, replace it. How did a hole form there?
2014 Scion FRS: Bagged & Wide
INSTAGRAM: @frsmichael
BUILD THREAD: Click Here
Michael is offline   Reply With Quote
Old 11-01-2016, 01:38 AM   #3
phantasticity
Ricer
Im tryna fix it instead of replacing it. And i thnk theres a cut from something
Old 11-04-2016, 02:57 PM   #4
ChanceK
ChanceK's Avatar
Drives: 2016 FRS
It would probably be cheaper just to replace the whole line, but if you just really really didnt want to do that, buy two straight couplers and a small section of hose and patch it. Keep in mind, that would probably be more expensive and MUCH more prone to more leaks. More connectors = more leaks.
ChanceK is offline   Reply With Quote
FS:(NJ) OEM LCA $50 pick up zc06_kisstherain Brakes, Suspension, Chassis 11 05-19-2017 02:15 PM
ST Suspensions Coilovers!!! FBPARTS Brakes, Suspension, Chassis 3 12-03-2015 01:38 PM
did first oil change and now it leaks Bakemono858 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 26 10-18-2013 09:17 PM
Any air suspensions? Danny Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 06-16-2013 11:56 AM
BRZ suspensions Subabie Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 03-18-2013 01:56 PM
