Old 03-18-2013, 12:16 PM   #1
Subabie
Drives: BRZ LTD
BRZ suspensions
I am transition from a 4 door sedan to this brz thingy! and the ride is too rough (hard) for me .. LoL ..what is the recommendation to make the car ride a little smoothier? ...
Subabie is offline   Reply With Quote
Old 03-18-2013, 12:18 PM   #2
JesseE
JesseE's Avatar
Drives: LS Swapped BRZ
buy a "comfy" car for a DD
JesseE is offline   Reply With Quote
Old 03-18-2013, 12:31 PM   #3
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
Not much really you could do without potentially changing the handling characteristics of the car (if that matters to you). Dropping the tire pressure may help, but may affect mpg and "dull" the feel of the wheel. Getting aftermarket "comfort" dampers/springs may help, but again, may change the handling characteristics (more sway/dive I would guess). Perhaps swapping dampers/springs with an FR-S, I hear their suspension is (minutely) softer than ours.
Old 03-18-2013, 12:31 PM   #4
SubieNate
SubieNate's Avatar
Drives: 2013 FR-S Ultramarine
I would suggest upgrading your struts/shocks while keeping the stock springs. Get in touch with @Turn in Concepts and see about upgrading to Koni yellows. The best thing you can do for ride quality is to up the quality of your dampers while keeping the spring rate reasonable.
Nathan
SubieNate is offline   Reply With Quote
Old 03-18-2013, 01:21 PM   #5
Calum
That Guy
Drives: 2013 asphalt FRS MT
FRS front springs are softer then BRZ and would probably ride softer.
Old 03-18-2013, 01:49 PM   #6
swift996
swift996's Avatar
http://articles.chicagotribune.com/2...nt-lab-results
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 03-18-2013, 01:56 PM   #7
Shim
Dismember
Shim's Avatar
Drives: FR-S & JSW
How about 16" wheels paired with tires that have more sidewall?
Shim is offline   Reply With Quote
Buttonwillow Pictures by JRZ Suspensions renzo1982 Tracking / Autocross / HPDE / Drifting 41 12-19-2012 02:36 AM
