Old 09-08-2013, 02:26 AM   #1
Bakemono858
Drives: 2013 Scion FRS
did first oil change and now it leaks
The drain plug was torqued at 29 and didn't bother to change the gasket. I've read that people aren't really changing them immediately after the first change, but would this be the reason why it's leaking?
Bakemono858 is offline   Reply With Quote
Old 09-08-2013, 02:49 AM   #2
Wes
Wes's Avatar
Drives: JRSC'd Asphalt FR-S
It could be the reason for the leak. Although it would be safer to change it since its pretty cheap anyway, but replacing your engine isnt.
Old 09-08-2013, 02:55 AM   #3
Bakemono858
I plan on changing it once I can get a hold of one on monday, I was just curious since I've heard of people not even changing it.
Old 09-08-2013, 04:05 AM   #4
suaveflooder
I still have the original plug gasket on mine and I have NO leaks from it. Odd. I've already changed the oil twice.
suaveflooder is offline   Reply With Quote
Old 09-08-2013, 04:25 AM   #5
whataboutbob
AutoX-10/10ths every run
I had mine leak once after an oil change. The crush washer that comes with the filter can sometimes get deformed during the tightening procedure and not create a good seal. The Toyota tech ended up putting some high temp RTV like stuff on it with a new crush washer when I brought it back in.
Build thread:Here
Old 09-08-2013, 09:30 AM   #6
Chimpo
Chimpo's Avatar
Drives: '15 STi Ltd
I re-used my crush washer, but as with other subaru's I've owned, I always add a dab of RTV around it (both sides) just to make sure it doesn't leak. I think next oil change I'm going to get a new one because it did look pretty tweeked, but then again NO LEAKS.
Chimpo is offline   Reply With Quote
Old 09-08-2013, 09:33 AM   #7
ZionsWrath
Thanks
ZionsWrath's Avatar
Fumoto valve here, no leaks no problems. A no brainer IMO if you are going to be doing your own oil changes.
Old 09-08-2013, 09:51 AM   #8
ft_sjo
Drives: GT86
The washer is supposed to be single-use. Either anneal it or replace it.
Old 09-08-2013, 12:18 PM   #9
Ravenlokk
Ravenlokk's Avatar
Drives: 2013 Raven FR-S
Fumoto valve is great for DiY changes. When you re-installed your old washer, and the drain plug did you wipe it off first? If you put it down and little bit of dirt or debris got on the mating surface it it could also contribute to a small leak.
Ravenlokk is offline   Reply With Quote
Old 09-08-2013, 12:18 PM   #10
Kostamojen
Drives: 1993 Impreza w/ WRX Swap + FWD!
ALWAYS use a new drain plug gasket!
Kostamojen is offline   Reply With Quote
Old 09-08-2013, 03:03 PM   #11
The_Societan
The_Societan's Avatar
Drives: Firestorm FR-S
Umm... oil pan drain plug gasket? Riiight.
a) Never seen one.
b) Didn't know there was one.
c) Therefore, never replaced when changing oil.
d) Going outside to look for puddle under engine.
The_Societan is offline   Reply With Quote
Old 09-08-2013, 06:40 PM   #12
Kostamojen
a) Never seen one.
Yes, all Subaru engines use Aluminum drain plug crush gaskets. They crush VERY flat when tight so they can stick to the plug and be hard to spot but they are there.
If you try to use some generic washer it will leak, if you don't replace it it will leak. They cost like $.90 so ALWAYS replace it, I'm kinda surprised people here don't know this already XD
I used to work at a Subaru dealer and all the time I would see leaky engines due to impropper drain plug gasket replacment, especially by places like Jiffy Lube (If you care about your car, DON'T GO TO JIFFY LUBE!!!)
Old 09-08-2013, 07:27 PM   #13
Wes
Wes's Avatar
a) Never seen one.
Not sure if serious..
If you are, its there but its really stuck onto the drain plug almost as if it was painted over, gotta almost pry it off.
Old 09-08-2013, 08:01 PM   #14
The_Societan
Okay... checked and it's not leaking. I was just confused because I've been changing the oil on my cars myself for like 15 years and I only ever saw the drain plug bolt, no washer. But this is my first "Subaru" engine. Thanks for the tip.
The More You Know...
2011 Nissan GT-R Pricing Starts at $85,060 vh_supra26 Other Vehicles & General Automotive Discussions 195 05-18-2023 09:12 PM
2012 Lexus GS leaks out ahead of Pebble Beach debut Archer256 Other Vehicles & General Automotive Discussions 83 02-12-2016 12:13 PM
New exhaust leaks Vukodlac Engine, Exhaust, Transmission 35 02-27-2013 11:41 AM
Controlled Information Leaks groupb Scion FR-S / Toyota 86 GT86 General Forum 27 02-12-2013 08:20 PM
Took my car in for an oil change... joshua BRZ First-Gen (2012+) — General Topics 25 08-04-2012 09:32 PM
