Old 11-02-2016, 08:55 PM   #15
Xxyion
Lowly Cartuber
Xxyion's Avatar
Drives: 2016 BRZ, 2005 Honda S2000
Originally Posted by armstrom View Post
Exactly... If I hadn't already picked up a used Harrop kit would be all over this.
-Matt
I almost want to just pull the trigger now beacuse with that sale + the refund i'm looking at a reliable Supercharger kit that has a good warranty (my car is new) for just over 4k. (after tax)
Xxyion is offline   Reply With Quote
Old 11-02-2016, 09:11 PM   #16
Cal3000
Drives: Panda FR-S
I didn't go wrong with my Vortech Kit.
Daily driven on E85 w/ 312whp(dynojet) red lining multiple times everyday. Bouncing off rev limiter.
The SC so far has lasted 100K miles and is still working optimal.
I have a Chevy/Mustang enthusiast engineering manager at my work. He basically said Vortechs usually outlast engines.
Vortech SC on 9psi Pulley, Invidia Catless Front Pipe, Invidia N1 Catback Exhaust
242whp/197ft-lb on Mustang Dyno (91 octane water)
284whp/223ft-lb on Mustang Dyno (E85)
Cal3000 is offline   Reply With Quote
Old 11-02-2016, 09:28 PM   #17
Nah
Drives: 2013 Scion Frs 6mt
100k on your motor with the supercharger!?!?!?!
Mis read your post lol... but still how many miles on the setup?
Nah is offline   Reply With Quote
Old 11-02-2016, 11:27 PM   #18
Wise
Circle Work Clerk
Drives: 2012 Mt. Fuji Red Toyota 86 GTS
How is the transmission going any problems during that timespan? Do you run an aftermarket clutch?
Wise is offline   Reply With Quote
Old 11-03-2016, 01:36 AM   #19
menikmati
Drives: 2015 BRZ, 2005 STI, 2024 Type R
Originally Posted by Tedderple View Post
Edelbrock is currently running a sale right now FYI. $3650 I believe.
HNNNNNGGHHHH.
Where?
menikmati is offline   Reply With Quote
The Following User Says Thank You to menikmati For This Useful Post:
Yoda (11-03-2016)
Old 11-03-2016, 10:09 AM   #20
armstrom
Drives: none
Originally Posted by menikmati View Post
HNNNNNGGHHHH.
Where?
http://www.ft86club.com/forums/showthread.php?t=112242
Make sure you click the link at the bottom of that post, that's where you'll see the price.
I took some time to read the details this morning and apparently they had a manufacturing problem and some of the parts were machined or cast wrong and there's an offset to how the runners align to the manifold. They claim it does not impact the inner surfaces so it will not degrade performance. They did post detailed pictures of the issue.
-Matt
Sent from my XT1095 using Tapatalk
armstrom is offline   Reply With Quote
The Following User Says Thank You to armstrom For This Useful Post:
menikmati (11-03-2016)
Old 11-03-2016, 10:24 AM   #21
Anderzz
Anderzz's Avatar
Drives: 2013 Subaru BRZ Premium
What's the top end potential on an edelbrock without needing a new clutch or built internals?
Anderzz is offline   Reply With Quote
Old 11-03-2016, 10:40 AM   #22
Nah
I'd say 220-240 to the wheels without a clutch. Depends how you drive I'm sure it won't last too long. E85 I'm sure you'd hit 280 and up on the stock motor. How long it'll last depends on your tune, driving habits, and of course luck lol.
Those numbers are based on speculation from all the other information I've read.
The Following User Says Thank You to Nah For This Useful Post:
durdinn (11-06-2016)
Old 11-03-2016, 11:54 AM   #23
Anderzz
Anderzz's Avatar
Thanks, I admittedly drive spiritedly on an every other day basis at least. (45m commute with a good mix of 15m back roads and 30m highway).
Do you think that the clutch swap would be necessary over 240 regardless of SC kit?
I'm starting to lean more Vortech because of the top end potential I want... there's no E85 within 2.5h of me lol.
Sent from my SM-G920T using Tapatalk
Old 11-03-2016, 12:35 PM   #24
Xxyion
Lowly Cartuber
Xxyion's Avatar
As far as i'm aware you can run 300 whp safley without immedietly switching out the clutch. It will just wear down quickly and then you just switch it out when you start getting issues.
I have heard that the Edelbrock can hit 300 whp on 91 but i'm not 100% sure on the validity of those statements. However the current price drop + rebate + warranty looks incredibly enticing to me right now.
Old 11-03-2016, 12:49 PM   #25
bfrank1972
Drives: 2013 FR-S Argento
Why are we all talking about clutches and horsepower instead of torque? It's torque that kills clutches - and the positive displacement superchargers can produce a lot more torque for a given peak whp output level - that's one big consideration. Example: A tuned intercooled innovate, or intercooled edelbrock on CARB tune will both produce probably 240-250whp peak on pump, but both will also produce close to 200 wtq for a good span of the rev range, with torque falling off in the upper ranges. A well tuned centrifugal unit like a vortech may produce around 280whp peak - sounds like a lot more but in reality it's at or under 200wtq for most of the power band.
Around 200wtq is probably the limit before you start having some issues - and also depends a lot on how abusive you are.
Apples to apples, a 280 whp positive displacement supercharger (or turbo) will likely kill the clutch a lot faster than a 280whp centrifugal supercharger. A tuned/optimized 280whp edelbrock unit will probably make the clutch suffer.
The Following 6 Users Say Thank You to bfrank1972 For This Useful Post:
Anderzz (11-03-2016), CSG Mike (11-03-2016), Icecreamtruk (11-03-2016), Lorico (11-04-2016), Nah (11-03-2016), weederr33 (11-04-2016)
Old 11-03-2016, 01:59 PM   #26
Kylebrz
Kylebrz's Avatar
Drives: 2013 subaru brz
I beat my car none stop and the hks v3 has done nothing but impress me no issues at all and I'm pushing 298whp on 94
Kylebrz is offline   Reply With Quote
The Following User Says Thank You to Kylebrz For This Useful Post:
zeal86 (11-06-2016)
Old 11-03-2016, 03:46 PM   #27
Phantobe
Phantobe's Avatar
Drives: 14 Ultramarine FR-S
May as well post here since I've been debating between Edelbrock & JRSC but I don't plan to pull the trigger for another year or so.
I know that PD chargers make more wtq down low and that centrifugal type chargers make more top end whp...
So I'm just wondering is there any noticeable tq in a centrifugal type supercharger below 4.5k RPM? Does it pretty much feel like a NA engine? I like the fact that centrifugal makes more top end but will it still feel like there's a torque dip in the 3-4.5k RPM range?
2014 Ultramarine Scion FR-S
2000 Integra LS - SOLD
Phantobe is offline   Reply With Quote
Old 11-03-2016, 04:09 PM   #28
Anderzz
Anderzz's Avatar
that's encouraging, how many miles has it been in the car?
New to me daily driver.. 95 M3. Dave-ROR Other Vehicles & General Automotive Discussions 58 07-17-2014 02:05 AM
Is your FR-S your daily driver? Drive Scion FR-S / Toyota 86 GT86 General Forum 136 02-10-2014 09:10 AM
FRS as a Daily Driver? Pake1 Scion FR-S / Toyota 86 GT86 General Forum 104 08-15-2012 11:48 PM
Will the BRZ be your daily driver WRXGuy1 BRZ First-Gen (2012+) — General Topics 47 05-23-2012 12:15 PM
BRZ as daily driver? Pakjk89 BRZ First-Gen (2012+) — General Topics 80 03-22-2012 09:50 AM
