Old 09-30-2016, 07:35 PM   #1
wyatt263
wyatt263's Avatar
Drives: 2013 Scion FRS, 1985 Toyota Supra
OFT Stage 1, Newb Questions
Just installed a stage one OFT for 93octane fuel. I may be noticing more engine noise, not intake noise, badddd engine noise. Or maybe I'm just listening to it more carefully since I've installed a tune. Is this tune safe? My LTFT is around - 7%, isn't that a little low? I've got an Injen cold air intake that claims to be tuned and has a little tube bypassing the MAF sensor, could that be messing up my fuel trim? Also, I noticed on the data log on WOT the parameter only reads 97% and there's about 1/8in of dead spot at the beginning of the pedal, is there a fix for that? Already went through ignition cycles to hopefully re-learn it, but to no avail. This is my first time tuning and I have no idea what to look for.
wyatt263 is offline   Reply With Quote
The Following User Says Thank You to wyatt263 For This Useful Post:
aagun (10-03-2016)
Old 09-30-2016, 07:48 PM   #2
Teseo
Drives: frs
Dead pedal will gone soon, let the ecu learn parameters.
Noise can be valvetrain
Old 09-30-2016, 08:07 PM   #3
NyC Zn6
NyC Zn6's Avatar
Drives: 10 Series #974 6m/t
When I first tuned my car with the OFT I also noticed an increase in sound as well. Vtec just kick in yo..
The Following User Says Thank You to NyC Zn6 For This Useful Post:
tinma (10-05-2016)
Old 09-30-2016, 08:12 PM   #4
PandaBRZ
PandaBRZ's Avatar
Drives: SWP BRZ
You're hearing the more aggressive valve timing from 3-5k RPM.
Read my writing about the BRZ on my website.
PandaBRZ is offline   Reply With Quote
Old 10-01-2016, 09:36 AM   #5
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
-7% at idle is nothing to worry about. But check LTFT after a couple hundred miles when ECU has learned the new trims. It sounds like you haven't put that many miles on so what's your total fuel trims (LTFT + STFT) at idle and at 2500 RPM? At stage 1 at idle mine were around -5 or -6, less negative at 2500 RPM
The extra noise I heard at stage 1 seemed to be in the torque valley RPMs. I figured the tune was changing the cam timing to compensate for the torque hole. I'm not sure though, I have no way to verify. But when you tune, sounds change. When you have an intake, you hear the new sounds louder. Don't sweat it.
At stage 2, there's a whole different set of noises to fret over!
guybo is offline   Reply With Quote
The Following 2 Users Say Thank You to guybo For This Useful Post:
aagun (10-03-2016), elBarto (10-02-2016)
Old 10-01-2016, 09:51 AM   #6
D_Thissen
D_Thissen's Avatar
Yup, that's normal. I believe it has to do with the drive by wire. The dead spot will go away after a 100km (60miles) or so.
The Following User Says Thank You to D_Thissen For This Useful Post:
tinma (10-05-2016)
Old 10-01-2016, 10:19 AM   #7
DarkSunrise
DarkSunrise's Avatar
Use this procedure to get rid of the dead spot after re-tuning. Always works for me.
Originally Posted by Foobar View Post
Could try Jeff Perrin's suggestion of turning car on without starting the engine, fully press and release gas pedal 20 times, turn car off, turn on without starting again, press and release 20 times again, then start engine. No more ECU reset dead pedal.
Sent from my Nexus 4 using Tapatalk 2
As for negative fuel trims, try posting a data log after a few hundred miles.
2022 BRZ Build
2013 FR-S Build
The Following User Says Thank You to DarkSunrise For This Useful Post:
aagun (10-03-2016)
Old 10-02-2016, 10:01 PM   #8
fibble
Drives: 2015 86 GTS
Less than 100% throttle at WOT is completely normal for these cars.
You need to read some of the OFT tips and tricks posts. All will become clear .
fibble is offline   Reply With Quote
Old 11-01-2016, 01:50 PM   #9
Jrider
Jrider's Avatar
Drives: 2013 Silver BRZ
I just tuned my car with the OFT to stage 1. I have a perrin CAI, and a perrin catback. I noticed what sounded like a terrible engine noise right around 4000 RPM. It sounded bad like the original poster said. I thought it was related to the intake perhaps. Flashed back to stock and it is gone. So this raspy, almost grinding loud noise is normal??? Will the stock airbox continue to produce this sound if I put it back on?
Jrider is offline   Reply With Quote
Old 11-01-2016, 02:35 PM   #10
phrosty
It's normal and not related to your intake. It is caused by aggressive VVT tuning to reduce torque dip.
phrosty is offline   Reply With Quote
Old 11-01-2016, 02:57 PM   #11
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Drives: 2014 Supercharged SSM BRZ Limited
slap a header on it and flash stage 2 tune....that noise will go away!
BirdTRD is offline   Reply With Quote
Old 11-03-2016, 04:36 PM   #12
Synkopy
Dragon King of Jupiter
Drives: 2016 BRZ Hyperblue
Noise is still there with stage 2. Can confirm. Just not as loud.
Synkopy is offline   Reply With Quote
Exedy Stage 1 Failure: Advice + Stage 2 Questions Pneub Engine, Exhaust, Transmission 4 07-18-2016 09:24 PM
A Newb to shifting and did a MTEC install questions YamahaR86 Engine, Exhaust, Transmission 7 09-10-2015 06:29 AM
newb questions about 2015 frs touch screen HU red05five Electronics | Audio | NAV | Infotainment 3 06-08-2015 10:58 PM
A couple of newb questions sorry.. tzbang Forced Induction 14 11-02-2014 09:33 PM
Questions about upgrading the avo stage 1 turbo kit to stage 1.5 and 2 Astroboy Forced Induction 4 03-01-2014 07:29 PM
