Old 10-25-2016, 02:59 PM   #15
HKz
Reformed
HKz's Avatar
Drives: '23 GRC, '11 Prius, '04 RAV4
Originally Posted by allowe View Post
Lol! Sorry about my paranoia! The throttle does seem sloppy though.
..it is a simple machine, why be paranoid...http://www.truedelta.com/Scion-FR-S/reliability-1096
...like most Subies and Toyotas there aren't any major problems..
HKz is offline   Reply With Quote
Old 10-26-2016, 12:40 AM   #16
RJasonKlein
RJasonKlein's Avatar
Drives: 2013 Scion FR-S 10 Series
Like @Tcoat mentioned, my car had a dead spot right off of idle, particularly when the car was moving slowly and then throttle was reapplied. This was most noticeable when coasting through low-speed corners, the revs would drop to under 2,000 rpms, you add throttle on corner exit, and then the engine seemed to fall into a hole before it would respond with an abrupt hit. Initially I thought it was the torque dip, but it wasn't that the car was down on power at the time, it was that the throttle was depressed and the car was absolutely dead...until it wasn't. Throttle response was sharp at all other rpms and the car ran perfectly at speed. My car did this stock and with a Cosworth drop-in filter.
Last edited by RJasonKlein; 10-26-2016 at 12:42 AM. Reason: Corrected a typographical error.
RJasonKlein is offline   Reply With Quote
Old 10-26-2016, 04:38 AM   #17
steve99
Drives: FT86
The throttle realy should not have dead spot or be laggy.
unless theirs somthing wrong or
you just reset or reflashed ecu
the maf scaling is off due aftermarket intake or you have air leak
you have exhaust leak upsetting 02sensor readings
you running rearly crap fuel and its getting a lot of knock
you should be able to go heavy of full throttle at any rpm and its should not bog, it may not pull very well at low rpm but should not die
Old 10-26-2016, 07:49 AM   #18
allowe
allowe's Avatar
What happened that made it work fine ?
allowe is offline   Reply With Quote
Old 10-26-2016, 10:23 AM   #19
radroach
Drives: car
My experience with FR-S that had intake / exhaust done was that the low revs felt more vague and sloppy, at least at clutch engagement. Couldn't tell by feel or sound where the lower revs were (this was a muffler delete, so all I could hear was mostly drone).
Your symptom sounds like the ecu is still learning, have you pulled the battery recently? Also to add what others are saying, your car won't work right with that intake without a tune.
Old 10-26-2016, 01:16 PM   #20
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
You truly are dead set on finding something wrong aren't you!!!!
Of course they'll find something. I've even read lately that all the '12-'16 models were designed in a rush ... What else we'll hear ...
Old 10-27-2016, 12:40 AM   #21
RJasonKlein
I assume it was the EcuTek Pro ECU and Delicious Tuning ECU reflash, although an ACE 4-2-1 Type-A 350 equal length header, Motiv catted front pipe, and Blitz Nür Spec stainless steel exhaust were installed at the same time.
Old 11-02-2016, 10:41 AM   #22
allowe
allowe's Avatar
Here is an update to this thread and sorry for bringing it back up.
Today I got in the car, warmed it up and now the dead space has pretty much all vanished. There is the tinyest (and I mean like 0.3 inch) play still in the throttle but the response now is pretty damn good. I did drive 300kms the day before so maybe it did need to relearn everything as I did install a subwoofer. First gear does still feel someone sloppy though from 1 k to 3 k rpm but it has gotten a lot better and I think a tune would probably take care of that considering I have injen intake. I wonder if open flash tab from vishnu would cure that or would I have to get it ecutek tuned
Old 11-02-2016, 12:01 PM   #23
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
Yes sir, I have that on my vehicle as well. DBW has it's ups and downs. I take that as a safety precaution. I'd worry if it were my brake though. Mine has 1/10th of that play but not my accelerator.
Old 11-02-2016, 02:11 PM   #24
MurderousPandas
MurderousPandas's Avatar
Drives: 2013 Scion FRS
Intake is more than likely the cause, too much air for the ECU. I have OFT, and the only thing you have to do for a new intake is scale the MAF, which can be done by either datalogging and perfecting it yourself, or by using a pre made chart available on the forums.
Sent from my HTC6535LVW using Tapatalk
MurderousPandas is offline   Reply With Quote
Part throttle faster than full throttle brn12345 Engine, Exhaust, Transmission 38 10-21-2021 12:20 PM
Throttle Pedal Lag gonzo Software Tuning 4 08-29-2014 02:07 AM
AFR of ~15 during throttle but up to 20.3 off throttle, idles at ~15 ok? tracerit Engine, Exhaust, Transmission 11 02-15-2014 12:44 PM
5th Gear and 6th Gear 0% throttle to 80% throttle gear crunch? kharn83 Issues | Warranty | Recalls / TSB 9 08-06-2012 07:44 PM
