Old 10-20-2016, 11:32 PM   #1
PSim
Drives: BRZ or FR-S (soon)
Buying BRZ with replaced engine
I'm currently shopping for a BRZ and came across one that's in good shape but has had the engine replaced. The original engine got water in it through the cold air intake.
Is this something you all would consider or not? Not being a mechanic, it seems like the factory-installed engine may be more solid.
PSim is offline   Reply With Quote
Old 10-20-2016, 11:34 PM   #2
tyler_win_photo
tyler_win_photo's Avatar
Drives: 2014 Scion FRS (Asphalt)
If it's been installed properly and it's not crazy high miles, shouldn't be much to worry about.
tyler_win_photo is offline   Reply With Quote
Old 10-20-2016, 11:47 PM   #3
Lonewolf
Lonewolf's Avatar
Drives: Moped
Sure, they may say it was water ingested through an intake, but make sure it's not a flood car. They often have all sorts of electrical/rust issues down the line.
The Following 2 Users Say Thank You to Lonewolf For This Useful Post:
gramicci101 (10-21-2016), wparsons (10-21-2016)
Old 10-21-2016, 12:11 AM   #4
ryoma
ryoma's Avatar
the intake for this car is pretty high up unless they re-routed it with a custom CAI setup. if large amounts of water was able to get sucked through that high up, I would be skeptical of the rest of the car.
The Following 2 Users Say Thank You to ryoma For This Useful Post:
humfrz (10-21-2016), shellslinger (10-21-2016)
Old 10-21-2016, 12:42 AM   #5
If I were you, I would look around for another car.
Old 10-21-2016, 12:51 AM   #6
renfield90
The Stig's German cousin
This this this.
http://www.edmunds.com/car-buying/ho...maged-car.html
http://auto.howstuffworks.com/under-...amaged-car.htm
If it's not a flood car it's probably fine. Most of the junkyard motors for the car are low mileage examples that probably got drifted into light poles and trees. If it's not a junkyard motor then it's probably a crate motor.
Consider getting a 3rd party mechanic to inspect, which is always wise when buying a new car if you're not sure what you should be looking for.
Old 10-21-2016, 01:46 AM   #7
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Like others said, make sure it wasn't in a flood. If been factory replaced or you proper paper work from a shop. It should be ok.
I would look over the car real good and make sure I'll have some kind of warranty.
Old 10-21-2016, 01:00 PM   #8
PSim
According to the seller, it was driven through about a foot of water and did not sit in the water.
Old 10-21-2016, 01:26 PM   #9
Lantana frs
Drives: 13 frs red
No thanx. Move on. These cars are not amphibious.
Lantana frs is offline   Reply With Quote
Old 10-21-2016, 01:28 PM   #10
Lantana frs
Drives: 13 frs red
Hes probably not lying. Didn't sit in the water. Probably floated.
The Following User Says Thank You to Lantana frs For This Useful Post:
Icecreamtruk (10-21-2016)
Old 10-21-2016, 01:39 PM   #11
PSim
And I'm guessing some of these problems wouldn't arise until some time down the road? He says he's been driving for five months but that may not be enough time for otehr issues issues to show up?
Old 10-21-2016, 01:53 PM   #12
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
I'd just find a car with a nice record and low price. These things are cheap, and people sell them for nothing. Why buy one with a questionable history?
Old 10-21-2016, 02:02 PM   #13
wparsons
wparsons's Avatar
The intake is way more than a foot off the ground, it was either in a lot more water or wasn't running the stock intake.
flickr
Old 10-21-2016, 02:38 PM   #14
FX86
did this dude drive his car into a lake? the intake sits high..what kind of body of water did he run into?
Clutch Replaced StOpNG0x Engine, Exhaust, Transmission 46 08-31-2016 01:35 AM
Reliability of engine with short block replaced ShadowTS Issues | Warranty | Recalls / TSB 4 08-22-2014 11:49 PM
Had to get one tire replaced, where to put it? malave7567 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 07-29-2014 06:33 AM
Can this part be replaced? czar07 Cosmetic Modification (Interior/Exterior/Lighting) 17 11-07-2012 01:46 PM
I may have had the first ever manufacturer-replaced FR-S VZ86 Scion FR-S / Toyota 86 GT86 General Forum 12 05-13-2012 12:39 AM
