Old 10-14-2016, 01:55 PM   #43
CSG Mike
CSG Mike's Avatar
Originally Posted by brzaapi View Post
I had this thought myself, but it is very true and needed to be said.
Mike, I am curious though...were there any other cars you were considering?
Besides a 3rd S2000
Well, this car was ordered with a very specific plan in mind, so there were no other cars considered, except the McLaren 570s and the Koenigsegg Regera. Then I came to my senses and they were put back into the unobtanium bin.
brzaapi (10-14-2016), funwheeldrive (10-14-2016)
Old 10-14-2016, 01:56 PM   #44
CSG Mike
CSG Mike's Avatar
The fact that even after all those miles and time spent working on the cars Mike still went with one as his personal vehicle says more to me than all the promotional hype ever written by Subaru/Toyota!
Well.... the cars I REALLY want is out of my price range by a few zeros...
Tcoat (10-14-2016)
Old 10-14-2016, 02:09 PM   #45
That is irrelevant since it probably applies to all of us in one way or another.
You could have come to despise these cars by now.
Old 10-14-2016, 02:43 PM   #46
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
best colour is best.
The Following User Says Thank You to Packofcrows For This Useful Post:
Captain Snooze (12-02-2016)
Old 10-14-2016, 05:35 PM   #47
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
The 570s is obtainable for mere mortals willing to make sacrifices. The Konigsegegegegegegeegegegege is, however, not.
Problem with a 570s is, it's not exactly daily drive material. This is, I think, why Porsches are so popular. You can actually daily most of them. They don't draw much attention. The twins are perfect daily material, even with a 500HP turbo under the hood.
Old 10-14-2016, 06:20 PM   #48
CSG Mike
CSG Mike's Avatar
Attention grabbing avatar is avatar.
Wait wut:?
Old 10-14-2016, 06:28 PM   #49
CSG Mike
CSG Mike's Avatar
I did some dynoing on both ACN 91 and VP 101 unleaded.
Even after multiple pulls, there was very little power difference between the two fuels. With the early pulls on 101, the ECU attempted to advance timing slightly, and ended up sending knock and sent the advance multiplier down, actually resulting in lower numbers on 101 for quite a while, before getting back up to 91 levels.
Also, on 91, 4 pulls were needed to stabilize the output; the ECU was dumping a ton of fuel up top initially. Each successive pull resulted in the ECU dumping fuel later, until it wasn't dumping fuel at all.
This is the same dyno all the CSG Ace header dynos are performed on; a 2013 dynoed about 165whp here.
I'm tempted to see how long the power carries with a higher redline...
The Following 8 Users Say Thank You to CSG Mike For This Useful Post:
Bristecom (10-25-2016), brzaapi (10-15-2016), Jonsey (10-14-2016), MaximeT (10-15-2016), mrg666 (10-14-2016), new2subaru (10-14-2016), radroach (10-15-2016), SuperDave (10-14-2016)
Old 10-14-2016, 09:33 PM   #50
CSG Mike
CSG Mike's Avatar
[ame="https://www.youtube.com/watch?v=qTU_drCNV6I"]2017 Subaru BRZ 6MT baseline dyno - YouTube[/ame]
iphone7 audio doesn't capture the actual exhaust note at all....
Iceman (10-14-2016), MisterSheep (07-08-2017)
Old 10-14-2016, 10:16 PM   #51
funwheeldrive
Kind of hard to tell, it looks like it's making roughly 175hp at the wheels?
The Following User Says Thank You to funwheeldrive For This Useful Post:
CSG Mike (10-14-2016)
Old 10-17-2016, 01:21 AM   #52
CSG Mike
CSG Mike's Avatar
Yes.
That particular dyno on the picture was on (mostly) VP101, but race gas made pretty much no difference from ACN 91.
Yeah I spent 75 bucks on race gas just to satisfy my own curiosity...
gkubed (11-06-2016)
Old 10-17-2016, 01:22 AM   #53
CSG Mike
CSG Mike's Avatar
Now, I have a bigger dilemma. None of the existing oil cooler kits I was seriously considering fit on the 17 BRZ, due to the enlarged airbox cover.
Going to test fit a Greddy this week, but if that doesn't fit either, then tracking this Saturday may be a no-go...
Old 10-17-2016, 07:14 AM   #54
brzaapi
CAR-AHOLIC
brzaapi's Avatar
Drives: 2018 BRZ Ts - CWP
Are you sure you'll be fast enough to overheat the "TWO THOUSAND SEVENTEEN" BRZ.
Seriously though, this is interesting. Besides Flexfuel/header...an oil cooler is the first mod i would do. In fact it was the first mod on my last BRZ...while waiting on my <cough cough> ACE header to come in.
So Mike please keep us apprised, and do you have a good shot of the new air box...i was not aware of a big change there.
It doesnt look wider, does it just sit lower or extend lower into the engine bay?
Track Toy - 2018 BRZ Ts - CWP
Daily: Audi TT RS
DD/4WD - Colorado ZR2 Bison - Mallett Supercharger
brzaapi is offline   Reply With Quote
Old 10-17-2016, 08:49 AM   #55
It is a fair bit deeper even though the filter it self is smaller.
brzaapi (10-17-2016), CSG Mike (10-17-2016), DarkSunrise (10-17-2016), SkAsphalt (10-24-2016)
Old 10-17-2016, 09:08 AM   #56
DarkSunrise
DarkSunrise's Avatar
I would guess it's the shape of the rear section of the OEM airbox. Most aftermarket oil coolers use a sandwich plate that routes the oil lines past that rounded off portion of the airbox (back right on pre-2017 models). It looks like that portion of the airbox is now square on the 2017 models based on that picture.
Not sure what solutions the aftermarket will come up with, but a Perrin-style CAI (long tube into bumper cover) might be an option. The Mishimoto oil cooler might work as well given the way it angles its lines.
2022 BRZ Build
2013 FR-S Build
The Following User Says Thank You to DarkSunrise For This Useful Post:
Mad Mike's Firestorm Build Mad_Mike Member's Car Journals 90 01-21-2026 09:08 PM
My thoughts on my build (Down South in Africa)! 86 South Africa Member's Car Journals 2 02-02-2016 07:55 AM
Mike&Ikes WRB Build Mike&Ike Member's Car Journals 8 09-18-2015 03:12 AM
Mike Mac's Raven FR-S NYC Build ScionFR-S Member's Car Journals 5 06-07-2014 01:49 PM
Mike's CS FR-S build mikef Member's Car Journals 6 04-25-2013 09:11 AM
