Old 10-13-2016, 04:18 PM   #1
Jajanken86
Jajanken86's Avatar
Drives: Silver FR-S
First stud broken
Hey guys, I just broke my first stud yesterday and I was wondering what would the budget friendly approach be? My lack of experience tells me to just get another oem stud and another oem lug nut, install them and call it a day, but I hear oem stud is garbage so I'd like to hear more opinion.
I also don't have access to a press so suggestions on how to install would be great. I'm still on stock wheels too, if you guys needed to know.
Sent from my SAMSUNG-SM-G900A using Tapatalk
Jajanken86 is offline   Reply With Quote
Old 10-13-2016, 04:24 PM   #2
Taco Man in HD
Taco Man in HD's Avatar
Drives: slow BRZ
I've had good experiences with ARP extended studs, and here's a DIY thread to follow for the install. Pretty easy process.
http://www.ft86club.com/forums/showthread.php?t=21563
Taco Man in HD is offline   Reply With Quote
The Following 2 Users Say Thank You to Taco Man in HD For This Useful Post:
Jajanken86 (10-13-2016), smg1138 (10-13-2016)
Old 10-13-2016, 04:24 PM   #3
swarb
budget would be oem. after market would be arp, but that isn't too budget friendly.
The Following User Says Thank You to swarb For This Useful Post:
Old 10-13-2016, 04:48 PM   #4
Jajanken86
Jajanken86's Avatar
Drives: Silver FR-S
Yes I've read that diy but it doesn't go much into detail how to do it without a press. And I don't really wanna hammer the old studs out in risk of damaging the hubs.
Old 10-13-2016, 05:16 PM   #5
zypher
Drives: WR Blue BRZ
I wouldn't worry to much about damaging the hub, the stud is only pressed in on the last 1/4" once you get past that you can push it out by hand.
I messed the threads up on two of my studs and replaced them using a hammer to pull them out and a spare lug and washers to pull them back through.
As long as you take some time and are careful there is no problem with not having a press.
zypher is offline   Reply With Quote
The Following User Says Thank You to zypher For This Useful Post:
Old 10-13-2016, 05:24 PM   #6
Jajanken86
Jajanken86's Avatar
Drives: Silver FR-S
Lol ok how many washers should I get?
Old 10-13-2016, 08:29 PM   #7
zypher
Drives: WR Blue BRZ
The idea with the washers make a spacer so that you can use the lug nut to pull the stud into place.
So enough washers to stack about 1.5" high
Old 10-13-2016, 11:05 PM   #8
Jajanken86
Jajanken86's Avatar
Drives: Silver FR-S
If I got a pack of 5 ARP short studs that are the same length as oem, there wouldn't be a problem just replacing the broken stud with an ARP and leaving the other 4 studs oem right?
Old 10-13-2016, 11:27 PM   #9
Votlon
Votlon's Avatar
Drives: Scion FRS || Ducati 899
On a racecar yes, on your street car you will be fine. Its the same as using a different lugnuts for keys; shouldnt affect wheel balance
Votlon is offline   Reply With Quote
The Following User Says Thank You to Votlon For This Useful Post:
Old 10-13-2016, 11:50 PM   #10
Jajanken86
Jajanken86's Avatar
Drives: Silver FR-S
Lol I thought so. Just wanted to be sure.
It's a race car in my heart haha but my wallet doesn't agree
The Following User Says Thank You to Jajanken86 For This Useful Post:
Votlon (10-16-2016)
Old 10-14-2016, 10:16 AM   #11
CatDaddysBBQ
Drives: '13 FR-S
Two tips (from somebody who has had a few oem studs snap)
1: Never let a shop/dealership/etc change wheels. Every single time I removed wheels after somebody else put them on, at least one was ruined. It took me a few times to catch on to the problem, but now I just flat out refuse to let anybody else but me touch them.
2: ALWAYS use a torque wrench and be gentle
3: You'll have a bit better luck with aftermarket lugs (i haven't had any issues since switching to Gorillas)
CatDaddysBBQ is offline   Reply With Quote
The Following User Says Thank You to CatDaddysBBQ For This Useful Post:
calic (11-10-2016)
Old 10-15-2016, 11:41 PM   #12
p1l0t
p1l0t's Avatar
Yes never let nobody touch your shit!
CatDaddysBBQ (10-17-2016)
Old 10-17-2016, 04:19 PM   #13
CatDaddysBBQ
Drives: '13 FR-S
I know. The first was during a dealer-covered first service after buying it new. I didn't know about the issue with the studs, so I didn't have any reason to object to a tire rotation. It was the next time I touched the wheels that I had a stud issue. Didn't know it was common (yet - it was still 2013).
After getting two replaced, I vowed never to let anybody touch them again, but one other time, I got a nail in the tire two blocks from a discount tire. They swapped it out - I didn't put the spare on since I was so close to the place.
They also ruined a stud. I replaced that one myself, and since have not let anybody touch them for the past two years...
I know better, and have for years now... but occasionally shit happens!
p1l0t (10-18-2016)
Old 10-18-2016, 09:40 AM   #14
bhmax
Drives: 13 BRZ, 17 Focus RS
Someone on here recommended these: https://www.ebay.com/itm/131578754532 Saved these to watch in case I need them at some point. Can anyone comment on the possible quality of them?
bhmax is offline   Reply With Quote
How to prevent broken wheel stud vincelive123 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 22 01-11-2016 07:21 PM
Broken Exhaust Stud During FP Install EvoPrecision8 Engine, Exhaust, Transmission 28 03-31-2015 03:21 PM
Need Advice: Broken strut mount stud... cobrabyte Suspension | Chassis | Brakes -- Sponsored by 949 Racing 27 12-22-2014 04:37 PM
Broken stud on stock header BAMF86 Engine, Exhaust, Transmission 1 06-06-2014 04:27 PM
Broken Stut mount Stud. Anyone Did This Before? Figo Issues | Warranty | Recalls / TSB 3 07-19-2013 10:29 AM
