| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#1933 | |||
Senior Misanthrope
Overall, 9.5 is hard to pull off with stock suspension. I would stick to 9 or less. |
| The Following User Says Thank You to kch For This Useful Post: | 15limited (09-24-2016) |
#1934 | |
17X9 +35 wheels, no spacer 245/45/17 tires stock struts -1.5° camber via camber/crash bolts ~1.3" drop springs I haven't measured it but I can't even fit the tip of my finger between the spring perch and tire, I wouldn't want any less clearance than that. I haven't seen any indications of rubbing on the tire or any part of the fender/fender liner.
Perrin Transmission Bolt, Drift Button,Intake Tube, Radiator Hoses, Engine Mounts, Gurney Flap Diode Dynamics Always On Module OLM 3k HID Foglights GCS Smoked Side Markers Motul Gear 300/300 V OE Acantara arm rest Password JDM Dry Carbon rear diffuser Rally Armour Mud flaps H.I.C side & rear visor Gruppe-S UEL header/OP HKS Front Pipe Leg Sport Cat Back Koyorad aluminum radiator Wheelhaus CF low pro 3rd brake light Toms JDM Clear Tail Lamps
#1935 |
Drives: '13 FR-S Ultramarine
Check out some impressions of the 245/255 width tire size on this platform
[ame="https://www.youtube.com/watch?v=Cjvhy88r9hU"]Tire Tech : Do Wide Tires RUIN the FRS/BRZ/86? - YouTube[/ame]
2013 FR-S Ultramarine
![]() -TRD Catback, UEL Header and Tune, Blitz Drop in Filter, Mishimoto Silicone Intake tube, Mishimoto Oil Cooler, 17x9 w/245/40/17 PSS, RS*R Coilovers custom track alignment, Check out my YouTube for more track videos https://www.youtube.com/channel/UCA9...O1T2Q3xu4m4bYQ Last edited by dirtbike250x; 09-25-2016 at 04:33 PM. |
#1936 |
Drives: t
#1937 |
Drives: 2013 BRZ 6mt limited
very nice, 17s?
#1938 |
Senior Misanthrope
#1939 |
On stock height I would imagine you would have plenty of room, 245/45 with 1.7" drop and -3 camber and I've never rubbed even with harsh compressions on stock stuts.
IIRC there plenty of clearance with +35 offset on the inside of the fender, the first place I could see an issue would be the leading edge of the fender, maybe see someone about getting them rolled if you want to go super wide, the right suspension settings could help with traction too.
#1940 |
Glorious BRZ Master Race
Drives: Subaru Libird
BUMP this question. I've been googling/searching/clicking through this thread and can't find a picture. I have 18x9.5 +45 currently with 255/35R18 no rubbing. Considering Hankook Ventus V12 evo2 265/35R18 (which run narrow) on rear. 1.4" drop no camber correction. Trying to avoid shaving the bumper tab because I'm anal like that. But want to see what it looks like first to qualify really just how anal I should let myself be.
#1941 | |
the tuna, no crust.
Drives: 2014 Hachiroku of the year
+45 isn't the aggressive so thats saving you also. i see a lot of people asking about rear fitment. On stock suspension theres plenty of room in the rear, its the FRONT thats the issue. you should easily be able to do a 255 on stock suspension rear and can get away with a 265 also. OFFSET is everything to do with this. |
#1942 | |
![]() ![]() this is ~1.7" drop 245/45
| The Following User Says Thank You to 15limited For This Useful Post: | Jive Turkey (10-20-2016) |
#1943 | |
Drives: WRB BRZ
#1944 | |
Drives: 2012 Grey TRD GT86, 2015 VW Golf R
Only rubbing I had was on front chassis rail at full lock so put steering stops in front to prevent that. Camber -2 at front for track but stock camber at back as haven't bothered to put any adjusting mechanism at rear. Pics with 255 here http://www.prosportauto.co.nz/blog/p...SA10R-Fitment/ And here's with 265/35/18 ![]()
My fully loaded TRD86
http://www.ft86club.com/forums/showt...760#post582760 Last edited by nzer; 10-12-2016 at 03:17 AM. |
| The Following 3 Users Say Thank You to nzer For This Useful Post: |
#1945 |
Drives: Black Limited JDM BRZ
#1946 | |
Drives: 2013 White-Out FRS
I live my life one quarter-pounder at a time.
| Winter Tire Review Thread (Please contribute) | pastuch | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 344 | 03-13-2024 05:49 PM |
| Wheel Directory: Forgestar F14 18x8.5 +38/18x9.5 +38 | ScionFR-S | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 97 | 09-09-2015 06:32 PM |
| Meaty rubber on flush spoke rims? | red_comet | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 16 | 06-14-2013 12:21 PM |
| Official wheel/tire fitment thread needed | empower-auto | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 06-22-2012 01:40 AM |
| The Wheel and Tire Fitting Thread | EvoFanatic | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 03-15-2012 03:05 PM |
