Old 09-22-2016, 01:10 PM   #1933
kch
Senior Misanthrope
kch's Avatar
Originally Posted by ikarntspel View Post
I understand that 18x9.5e40 with a 255/35 will rub with stock suspension
Yes, most likely.
but i was told that adding a 5mm spacer will stop it from rubbing completely, is this true?
It may prevent the tire/wheel from rubbing the front suspension. However, it will create a new problem -- you might start rubbing your fender due to the added poke.
Would also like to know if adding a 5mm spacer is the same as the wheel being 18x9.5e35.
Essentially, yes.
Overall, 9.5 is hard to pull off with stock suspension. I would stick to 9 or less.
The Following User Says Thank You to kch For This Useful Post:
15limited (09-24-2016)
Old 09-24-2016, 08:03 AM   #1934
15limited
15limited's Avatar
Originally Posted by BlaineWasHere View Post
Depends on ride hight, camber, and offset of wheel.
Stock everything I would say 17x9 -40 offset with 245/40/17
To reinforce this, I'm running
17X9 +35 wheels, no spacer
245/45/17 tires
stock struts
-1.5° camber via camber/crash bolts
~1.3" drop springs
I haven't measured it but I can't even fit the tip of my finger between the spring perch and tire, I wouldn't want any less clearance than that. I haven't seen any indications of rubbing on the tire or any part of the fender/fender liner.
Perrin Transmission Bolt, Drift Button,Intake Tube, Radiator Hoses, Engine Mounts, Gurney Flap Diode Dynamics Always On Module OLM 3k HID Foglights GCS Smoked Side Markers Motul Gear 300/300 V OE Acantara arm rest Password JDM Dry Carbon rear diffuser Rally Armour Mud flaps H.I.C side & rear visor Gruppe-S UEL header/OP HKS Front Pipe Leg Sport Cat Back Koyorad aluminum radiator Wheelhaus CF low pro 3rd brake light Toms JDM Clear Tail Lamps
15limited is offline   Reply With Quote
Old 09-25-2016, 02:19 PM   #1935
dirtbike250x
dirtbike250x's Avatar
Drives: '13 FR-S Ultramarine
Check out some impressions of the 245/255 width tire size on this platform
[ame="https://www.youtube.com/watch?v=Cjvhy88r9hU"]Tire Tech : Do Wide Tires RUIN the FRS/BRZ/86? - YouTube[/ame]
2013 FR-S Ultramarine
-TRD Catback, UEL Header and Tune, Blitz Drop in Filter, Mishimoto Silicone Intake tube, Mishimoto Oil Cooler, 17x9 w/245/40/17 PSS, RS*R Coilovers custom track alignment, Check out my YouTube for more track videos https://www.youtube.com/channel/UCA9...O1T2Q3xu4m4bYQ
dirtbike250x is offline   Reply With Quote
Old 09-25-2016, 02:23 PM   #1936
choi0706
Drives: t
Originally Posted by choi0706 View Post
what is the widest wheel/tire size on 17inch that will fit without rubbing? on OE shocks.
should of clarified. stock ride height as well. I'm on 235 tires, but need more rear grip after the turbocharger.
choi0706 is offline   Reply With Quote
Old 09-25-2016, 10:36 PM   #1937
WHITEBUUURRZZ
Drives: 2013 BRZ 6mt limited
very nice, 17s?
WHITEBUUURRZZ is offline   Reply With Quote
Old 09-25-2016, 11:18 PM   #1938
kch
Senior Misanthrope
kch's Avatar
you *should* be able to fit 255/40/17 on 17x9 +35 in the rear.
Old 09-25-2016, 11:36 PM   #1939
15limited
15limited's Avatar
On stock height I would imagine you would have plenty of room, 245/45 with 1.7" drop and -3 camber and I've never rubbed even with harsh compressions on stock stuts.
IIRC there plenty of clearance with +35 offset on the inside of the fender, the first place I could see an issue would be the leading edge of the fender, maybe see someone about getting them rolled if you want to go super wide, the right suspension settings could help with traction too.
Old 10-08-2016, 02:57 AM   #1940
switchlanez
Glorious BRZ Master Race
switchlanez's Avatar
Drives: Subaru Libird
Originally Posted by gkubed View Post
Does anyone have a picture of what the rear bumper tabs actually are? I know they're "the plastic tabs that aren't part of the fender", but I looked back there and don't see any evidence of rubbing on anything.
BUMP this question. I've been googling/searching/clicking through this thread and can't find a picture. I have 18x9.5 +45 currently with 255/35R18 no rubbing. Considering Hankook Ventus V12 evo2 265/35R18 (which run narrow) on rear. 1.4" drop no camber correction. Trying to avoid shaving the bumper tab because I'm anal like that. But want to see what it looks like first to qualify really just how anal I should let myself be.
Old 10-08-2016, 09:19 AM   #1941
Jive Turkey
the tuna, no crust.
Jive Turkey's Avatar
Drives: 2014 Hachiroku of the year
i'l try to take a photo of it today as i'm ripping my car apart back to stock. mine is completely shaved away.
+45 isn't the aggressive so thats saving you also.
i see a lot of people asking about rear fitment. On stock suspension theres plenty of room in the rear, its the FRONT thats the issue. you should easily be able to do a 255 on stock suspension rear and can get away with a 265 also. OFFSET is everything to do with this.
Jive Turkey is offline   Reply With Quote
Old 10-11-2016, 08:11 AM   #1942
15limited
15limited's Avatar
Pretty much sums it up. If you need to fine tune fitment, standard adjustable LCA's are only a couple hundred bucks.
this is ~1.7" drop 245/45
The Following User Says Thank You to 15limited For This Useful Post:
Jive Turkey (10-20-2016)
Old 10-11-2016, 11:13 AM   #1943
Fred E
Drives: WRB BRZ
Back to stock?!?!
Fred E is offline   Reply With Quote
Old 10-12-2016, 03:06 AM   #1944
nzer
nzer's Avatar
Drives: 2012 Grey TRD GT86, 2015 VW Golf R
I am running 18x9.5" +45 Wedsport SA10R with 265/35R18 Bridgestone RE003 with around 25mm drop. No rubbing on guards or bumper tab.
Only rubbing I had was on front chassis rail at full lock so put steering stops in front to prevent that. Camber -2 at front for track but stock camber at back as haven't bothered to put any adjusting mechanism at rear.
Pics with 255 here http://www.prosportauto.co.nz/blog/p...SA10R-Fitment/
And here's with 265/35/18
nzer is offline   Reply With Quote
The Following 3 Users Say Thank You to nzer For This Useful Post:
djdnz (10-12-2016), slow15frs (10-14-2016), switchlanez (10-12-2016)
Old 10-14-2016, 08:49 PM   #1945
In1t
In1t's Avatar
Drives: Black Limited JDM BRZ
Work Kiwami 18x9.5 +38 235x40 tires, RS-R super low springs and SPC 14mm camber bolts
In1t is offline   Reply With Quote
The Following 2 Users Say Thank You to In1t For This Useful Post:
HachiRo (10-14-2016), Metabrz (10-17-2016)
Old 10-14-2016, 11:58 PM   #1946
HachiRo
Drives: 2013 White-Out FRS
Looks beautiful! Just be careful on big bumps. I had the same set-up pretty much and you'd hear the rubbing whenever the car hit a big bump or at high speed, haha.
I live my life one quarter-pounder at a time.
HachiRo is offline   Reply With Quote
Winter Tire Review Thread (Please contribute) pastuch Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 344 03-13-2024 05:49 PM
Wheel Directory: Forgestar F14 18x8.5 +38/18x9.5 +38 ScionFR-S Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 97 09-09-2015 06:32 PM
Meaty rubber on flush spoke rims? red_comet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 06-14-2013 12:21 PM
Official wheel/tire fitment thread needed empower-auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-22-2012 01:40 AM
The Wheel and Tire Fitting Thread EvoFanatic Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 03-15-2012 03:05 PM
