Old 10-08-2016, 11:06 PM   #19699
soulreapersteve
Contract? /人◕ ‿‿ ◕人\
soulreapersteve's Avatar
Originally Posted by cjd View Post
That'll sure add to the draw of the car... The boys'll be all over you!
^He's right, yah know.
The car, even in stock form, attracts mostly dudes. Put a naked anime girl on your car and even more dudes will flock to you.
Disgusting weebs such as myself.
The Twins make me smile
soulreapersteve is offline
The Following 3 Users Say Thank You to soulreapersteve For This Useful Post:
cjd (10-08-2016), go_a_way1 (10-09-2016), Ultramaroon (10-08-2016)
Old 10-09-2016, 12:09 AM   #19700
Ashikabi
Ashikabi's Avatar
You know the vinyl wrap would pad the rock chips do it wouldn't damage the paint and likely not the vinyl. You should definitely get some babes on there
Ashikabi is offline
The Following 2 Users Say Thank You to Ashikabi For This Useful Post:
go_a_way1 (10-09-2016), soulreapersteve (10-09-2016)
Old 10-09-2016, 12:41 AM   #19701
Tcoat is offline
The Following 7 Users Say Thank You to Tcoat For This Useful Post:
Andrew025 (10-09-2016), Cole (10-09-2016), Dadhawk (10-09-2016), go_a_way1 (10-09-2016), p1l0t (10-09-2016), scary alien (10-09-2016), Ultramaroon (10-09-2016)
Old 10-09-2016, 09:34 AM   #19702
Ashikabi
Ashikabi's Avatar
Here's a question about the coolant tank and how it operates... we "fill"the over flow tank when it says "low" right? But if the only 2 openings on the tank are the fill cap and the inlet hose, how does coolant go back into the system?
I've been looking at aftermarket tanks because the stock one is ugly but obviously I don't want my coolant system to not function properly
Ashikabi is offline
Old 10-09-2016, 10:49 AM   #19703
It just sucks the fluid back through pressure differential when th engin cools. The coolan doesn't flow through the tank. The marked levels are just to make sure you don't run it dry and start sucking air into the system or overflow the tank when hot. You could use any tank you want.
Tcoat is offline
Old 10-09-2016, 10:53 AM   #19704
Ashikabi
Ashikabi's Avatar
So the tube on the top has a pickup tube/straw inside the tank to draw from the bottom of the reservoir I take it
Ashikabi is offline
Old 10-09-2016, 10:59 AM   #19705
Yep.
Tcoat is offline
Old 10-09-2016, 05:03 PM   #19706
NickD
Drives: '05 Corvette
bruh
NickD is offline
Old 10-09-2016, 05:44 PM   #19707
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Two generations in a row, the best trained jedi killed all the baby jedi.
EAGLE5 is offline
The Following 3 Users Say Thank You to EAGLE5 For This Useful Post:
p1l0t (10-09-2016), scary alien (10-09-2016), Teseo (10-09-2016)
Old 10-09-2016, 05:51 PM   #19708
cjd
cjd's Avatar
Drives: 2017 BRZ
It skipped a generation...
cjd is offline
Old 10-09-2016, 07:00 PM   #19709
EAGLE5
Dismember
EAGLE5's Avatar
Emperor Palpatine killed off gen 1 of the Jedi. Anakin killed off gen 2 of the Jedi, of which Luke was a member. Kylo Ren killed off gen 3.
EAGLE5 is offline
Old 10-09-2016, 07:25 PM   #19710
I want to do something crazy wild and unique to my car (without spending 5 grand lol I spent enough)
Tcoat is offline
go_a_way1 (10-11-2016), MrFisty (10-09-2016), p1l0t (10-09-2016), scary alien (10-09-2016)
Old 10-09-2016, 08:06 PM   #19711
cjd
cjd's Avatar
Drives: 2017 BRZ
The way you phrased your statement technically leaves it ambiguous to whom "two generations in a row" applies; the specificity of "the best trained jedi" and the structure of the sentence suggest that it's two generations in a row of the best trained jedi that kill the babies - in which case it skipped a generation.
Many dead. Much sad. The end.
cjd is offline
Old 10-09-2016, 09:30 PM   #19712
MrFisty
The Fistiest
MrFisty's Avatar
Drives: 2013 Argento FR-S
Hater pipes or electronic cut out?
They said my last sig was too big.
MrFisty is offline
The Following User Says Thank You to MrFisty For This Useful Post:
