Old 10-02-2016, 12:32 AM   #29
Originally Posted by Eighty 6 View Post
Trans, oh hes talking about the diff. Its a common issue the rattling on the trans.
What caught my eye was people telling him it could be a serious prob. Yeah ok, not applicable
It's my understanding that the OP is talking about (concerned about) the driveshaft in his car ..... more specifically, the carrier bearing along the driveshaft.
So, what is your car doing that concerns you .. ??
Ultramaroon (10-02-2016)
Old 10-02-2016, 03:44 AM   #30
Eighty 6
Newbie
Drives: Gt86
The gear rattles at high RPM in any gear, its a common problem with manuals
Eighty 6 is offline   Reply With Quote
Old 10-02-2016, 04:59 AM   #31
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
What do you mean the gear rattles at high RPM? Does it make noises or just the shift knob shaking?
Old 10-02-2016, 05:16 AM   #32
Eighty 6
Newbie
Drives: Gt86
Shift knob shakes but I get the sound of metal on metal. Dealer is going to replace that. Its a common problem with manuals, something to do with the reverse lockout or something. Cant touch it otherwise I void the warranty
The Following User Says Thank You to Eighty 6 For This Useful Post:
nikitopo (10-02-2016)
Old 10-02-2016, 10:22 AM   #33
Phothiraj
Drives: Lightning Red BRZ
More importantly, does it feel about evenly springy no matter which way you push it, or does the driveshaft flop at all inside the isolator?
IOW, does it feel like the bearing has separated from the isolator?
22mm feels about ballpark to me. I've messed with mine some.
It doesnt feel seperated but after asking my father whos been a mechanic for many years he also insists that the amount of play there is not normal. As well is it weird that only about 80-85% of the time it acts up when i'm driving and not 100% of the time? Also it seems to be a lot worse on my days to work in the rain
Phothiraj is offline   Reply With Quote
Old 10-02-2016, 01:35 PM   #34
Well now, there you have it ....... depression; driving to work ..... in the rain ....
Seriously, you mentioned that your car was rear ended. It's possible that the differential was "shifted" a bit, causing a misalignment of the driveshaft.
Again, I suggest you (and your father, if he is handy) take the car into an auto shop, have it put up on a hoist, run it in gear and observe the drive line.
chaoskaze (10-02-2016), Ultramaroon (10-02-2016)
Old 10-02-2016, 02:08 PM   #35
I was surprised with the amount of play myself. The only way to know for sure is to get in there and visually inspect it. It's really easy to look at from underneath the car.
I'm sticking even more with a bent or otherwise damaged driveshaft. It takes very little to throw it out of whack.
humfrz (10-02-2016)
Old 10-02-2016, 02:20 PM   #36
In the rain you say. I am going to throw another theory at you which in light of your prior accident may also be relevant. It may not be your drive shaft at all but could be your exhaust. I bent a hanger on the exhaust on my old Talon and at certain speeds, a particular rev range and especially when the roads were wet with puddles it would thump like mad. I also blamed the driveshaft or dif for the problem. Took me weeks to figure it out and then one day I noticed the bent hanger. Twisted it back and never had the noise again. May be worth a look.
chaoskaze (10-02-2016), humfrz (10-03-2016), Ultramaroon (10-02-2016), why? (10-02-2016)
Old 10-03-2016, 07:56 AM   #37
justatroll
justatroll's Avatar
Drives: Full race 4cyl boxer
False, False, False - Whoever told you that should be strung up
Arguing with an engineer is like wrestling with a Pig in the mud. You are never going to win and after a couple of hours you realize that he likes it.
justatroll is offline   Reply With Quote
The Following 2 Users Say Thank You to justatroll For This Useful Post:
Ultramaroon (10-03-2016), why? (10-03-2016)
Old 10-03-2016, 12:02 PM   #38
Good eye. I missed that.
Old 10-03-2016, 12:07 PM   #39
This is how it is with flutter. Could be fine and stable until just the right input kicks over the initial resonance. If it's something as heavy as a driveshaft, once it gets going, it could easily rip itself apart.
Old 10-03-2016, 12:11 PM   #40
Phothiraj
I'll go ahead and check if it was a bent exhaust hangar but almost positive it's the driveshaft, it only happens when in gear and as soon as I throw it into neutral it goes away. Also, these past 2 days it seems as if the car is driving fine with a chatter sound every now and then. But I've also haven't driven far to make it noticeable.
Old 10-03-2016, 12:27 PM   #41
Wait, are you saying while it's vibrating, if you throw it into neutral and coast it goes away? At the same speed?
The driveshaft is constantly connected to the rear wheels. If the car is moving, the driveshaft is spinning.
Old 10-03-2016, 12:56 PM   #42
Eighty 6
Newbie
Drives: Gt86
In this "region" thats pretty much it, you cant give them an excuse to void your warranty. Not much u can do about it if they do, other than lengthy, expensive lawsuits etc and the outcome is not gauranteed. They dont want me to touch it I wont
Axle-Exchange One-piece Aluminum Driveshaft ~ impressions slates74 Engine, Exhaust, Transmission 152 08-07-2021 07:39 PM
Aluminum 1-piece Driveshaft Cjs_ Engine, Exhaust, Transmission 17 03-25-2015 04:45 PM
New The Driveshaft Shop Carbon Fiber 1-Piece Driveshaft Evasive Motorsports Engine, Exhaust, Transmission 1 09-24-2013 02:27 PM
