Old 10-02-2016, 03:25 PM   #15
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
normal engine temperature
Hey Chaos I am confused. How does an oil cooler make the car warm up faster?
It's magic. 🙈
Love is what makes a Subaru, Subaru. Ok it's time for my meds.
Jks aside that's what people were saying after they installed that... O.o
The Following User Says Thank You to chaoskaze For This Useful Post:
Ultramaroon (10-02-2016)
Old 10-02-2016, 04:17 PM   #16
Originally Posted by chaoskaze View Post
It's magic. ��
I reckon it's time for "those peoples" meds .....
Old 10-02-2016, 08:26 PM   #17
notout86
Drives: GTS 86 auto
So, @notout86 how long or how far do you travel before your car's temperature gauge reaches "normal" temperature ... ??
Yes, I have noticed that my FR-S does take longer to "warm up" than our family sedan.
about 4km
GTS86 Auto (Australia)
The Following User Says Thank You to notout86 For This Useful Post:
humfrz (10-02-2016)
Old 10-02-2016, 08:36 PM   #18
notout86
Drives: GTS 86 auto
Our car does warm up slower compare to some others 🚗 , I know if you installed the oem style oil cooler sandwich plate from forester xt it will warm up a lot faster. I usually let the car sit for like 5 min before driving.
I have read that it is best to drive off right away as it saves fuel and warms up faster.
Old 10-02-2016, 09:11 PM   #19
Yes but don't wank on it because cold oil pressure is through the roof. That means it is limited by the tight clearances at all the journals and cold oil viscosity.
I keep it under 3K until it warms up to full operating temp.
It's not as tight as an F1 engine which will literally seize when cold but it's pretty damn close. This is not your father's Oldsmobile.
humfrz (10-02-2016), notout86 (10-03-2016)
Old 10-02-2016, 09:17 PM   #20
The block warms up at closer to the same rate as the cylinders because it is a water-to-oil heat exchanger. Without the mod, the oil temperature lags behind the water temp. Much more during winter temps.
This speaks to my last post. Don't beat on it until the whole engine comes up to normal operating temp, not just the water.
Old 10-02-2016, 09:26 PM   #21
Ahhh I see.
Old 10-02-2016, 09:35 PM   #22
about 4km
That sounds about "normal" .....
Normal working temperature LSD killy Engine, Exhaust, Transmission 4 09-15-2016 03:24 AM
CAI and Engine Temperature Scrub Engine, Exhaust, Transmission 1 07-15-2016 10:53 PM
Engine oil standard operating temperature brillo Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 20 04-22-2015 01:12 AM
Engine Temperature huffy044 Scion FR-S / Toyota 86 GT86 General Forum 4 01-13-2015 03:59 PM
Engine temperature Skye Issues | Warranty | Recalls / TSB 5 08-09-2012 10:33 PM
