Old 10-01-2016, 11:36 PM   #1
notout86
Drives: GTS 86 auto
normal engine temperature
I know the thermostat is fully open at 95 degrees C, but what temperature shows via the OBII plug?.
Also, on a day with temperature around 20 degrees C, how many km does it take to get up to normal temp.?
GTS86 Auto (Australia)
Old 10-01-2016, 11:47 PM   #2
I don't understand your first question. I don't have an answer for your second; five to seven minutes if you're not abusing it.
Old 10-02-2016, 12:37 AM   #3
My FR-S's temp gauge levels out in about 3 miles.
Old 10-02-2016, 01:15 AM   #4
So, that's like 20 minutes?
Old 10-02-2016, 01:36 AM   #5
Well, yes, that does include waiting till the granddaughters buckle up, going 20 mph past 2 school zones, opening car door for granddaughters, waiting till they go through the school gate, slowly driving away from the school, passing the two 20 mph school zones again ...... yep, about 20 minutes on a good day (when I can hit all the lights green) ......
Old 10-02-2016, 01:41 AM   #6
But you leave the blinker on just in case, right?
Old 10-02-2016, 01:46 AM   #7
Well, of course ......I will be turning that way ...... sometime ......
Old 10-02-2016, 01:55 AM   #8
Notout, we haven't forgotten about you. Get back to us.
Old 10-02-2016, 03:37 AM   #9
notout86
Drives: GTS 86 auto
Sorry I was vague.
I started by stating the temp at which the thermostat opens fully is 95 because I assume the engine itself may be different. If an analyser is plugged into the OBDII plug a sensor somewhere in the engine sends a signal for temperature... that's what I wanted to know.
For time or distance to operating temp I should have stated on an average sort of day around 20 degrees C and in suburban driving around 60 kmph.
My previous car warmed up in half the time/distance under the above conditions and I wondered whether my '86 is typical.
Old 10-02-2016, 01:23 PM   #10
So, @notout86 how long or how far do you travel before your car's temperature gauge reaches "normal" temperature ... ??
Yes, I have noticed that my FR-S does take longer to "warm up" than our family sedan.
Old 10-02-2016, 02:02 PM   #11
Originally Posted by notout86 View Post
Sorry I was vague.
No worries. Yes, it takes a while There is no valve for the heater core so even stone cold, it's circulating water. If you have the cabin heat cracked open even a little bit, it will dramatically increase the engine warm-up time.
Hope that helps.
Old 10-02-2016, 02:49 PM   #12
DIE1000DEATHS
TechNINJA
DIE1000DEATHS's Avatar
Drives: Whiteout MT, 87 Mustang, 09 RUCKUS
The OBD will report about 90C when at normal operating temp according to my scan guage. However, my Innovate coolant temp gauge reads quite differently (sensor is plumbed into upper rad hose). It normally will show more around 98C when driving.
Also, the OBD reports temps coming up much more quickly than the Innovate gauge. I have seen the scan gauge show 74C when the Innovate hasn't moved from 49C (It's lowest it will show).
Hope this helps.
DIE1000DEATHS is offline   Reply With Quote
Old 10-02-2016, 02:54 PM   #13
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
Our car does warm up slower compare to some others 🚗 , I know if you installed the oem style oil cooler sandwich plate from forester xt it will warm up a lot faster. I usually let the car sit for like 5 min before driving.
Old 10-02-2016, 03:24 PM   #14
Hey Chaos I am confused. How does an oil cooler make the car warm up faster?
Normal working temperature LSD killy Engine, Exhaust, Transmission 4 09-15-2016 03:24 AM
CAI and Engine Temperature Scrub Engine, Exhaust, Transmission 1 07-15-2016 10:53 PM
Engine oil standard operating temperature brillo Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 20 04-22-2015 01:12 AM
Engine Temperature huffy044 Scion FR-S / Toyota 86 GT86 General Forum 4 01-13-2015 03:59 PM
Engine temperature Skye Issues | Warranty | Recalls / TSB 5 08-09-2012 10:33 PM
