Old 09-13-2016, 03:44 AM   #533
Camsheim
Hachiroku
Camsheim's Avatar
Drives: GT86 AT Mid 2012
Oups , it's ok now , the log was indeed not public
Camsheim is offline   Reply With Quote
Old 09-13-2016, 09:33 AM   #534
steve99
Drives: FT86
looks ok
The knock is all minor less than -0.7 nothing to worry about and its low rpm
ltft looks fine
It running a little rich wide open throttle low 11 ie 11.3 or so should be around 11.8, its safe but will cost you a bit of power.
If this is first tank of E85 leave it alone for now and check on second tank
If its still running rich
You will need to take about 5% out of you maf scale above 3.2v
http://www.datazap.me/u/camsheim/e85...zoom=3356-3514
Camsheim (09-23-2016)
Old 09-13-2016, 09:36 AM   #535
Camsheim
Hachiroku
Camsheim's Avatar
looks ok
ltft looks fine
Thanks you
Could it be the impact of the 6L of RON98 remaining in the tank.
Better wait for the next refuel to have a less diluted E85 and redo a datalog to check the AFR during WOT ?
Old 09-13-2016, 10:10 AM   #536
steve99
Drives: FT86
Thanks you
Yes that's probably best, post up the log then and we can see how its going.
Old 09-15-2016, 10:53 AM   #537
Tectoniic
#FiftyShadesOfBlue
Tectoniic's Avatar
Drives: 2015 FR-S
As we get closer to winter and the temperature drops is it normal for LTFT to increase a percentage or two in idle and under low throttle?
My thought process is:
Temps drop
E85 Stations go to the winter blend which has less ethanol
Car starts adds extra fuel to compensate for the lack of ethanol
LTFT Idle used to be +4 on average, now it is +6
LTFT very low throttle crusing in 5/6th gear used to be +6/7, now it is getting up to +8/9
Been using the same speedway brand E85 (Between 51% and 83% for all their pumps) for over a month now and fuel trims were consistent until it started getting a bit colder.
I know these are small changes so I didn't want to make a new thread but I just want to make sure my logic checks out before looking for any kind of exhaust leak or other problem. I know that that without a flexfuel kit I can't rule out regular changes in the stations E85 but it seemed to be pretty consistent during warmer temps.
Engine/Exhaust: OFT w/ E85 Tune | FT86SF Catted UEL | Invidia Q300 Catback
Wheels/Tires/Suspension: Avid.1 AV-20 18x8.5 +33 w/ 245/35/18 PSS | RCE Yellow Springs | Velox LCAs
Cosmetic: Valenti FT86SF Special Edition Tails | Diode Dynamics Full HID/LEDs | BRZ Fender Garnishes
Tectoniic is offline   Reply With Quote
Old 09-15-2016, 09:56 PM   #538
steve99
Drives: FT86
Temps drop
in general
if Ethanol percent goes lower ie more petrol then LTFT should trend Lower (more petrol makes car run rich so ecu pulls fuel)
If Ethanol percent goes higher ie less petrol thenLTFT should trend Higher (less petrol makes car run leaner so ecu adds fuel)
However the maf sensor has temperature compensation and this also alters fuel trims especially at idle. In cold weather. as intake air temperature differential between when your driving and stationary at idle is likely greater.
The Following 2 Users Say Thank You to steve99 For This Useful Post:
Camsheim (09-23-2016), Tectoniic (09-16-2016)
Old 09-23-2016, 03:45 PM   #539
Camsheim
Hachiroku
Camsheim's Avatar
So i made my custom E85 map with the base map from Wayno.
After 10km no high load it's awesome -3L/100km on average.
And the log look good. I will let it settle for another 100km and datalog again.
http://www.datazap.me/u/camsheim/e85...-9-10-11-12-14
Old 09-23-2016, 03:58 PM   #540
steve99
Drives: FT86
highly unlikely your getting that economy on E85, generally its about 25% worse than on petrol.
did you change the "Fuel Multiplier Display Offset" table from stock it needs to go up about 30% as in first post else the fuel display will read 30% low
Old 09-23-2016, 04:04 PM   #541
Camsheim
Hachiroku
Camsheim's Avatar
Yep i did.
On Stock RON98 i was at 7,5 , on OTS e85 i was at 12,5 , now i'm at 10.
7,5x1.33= 9,997 it's feel just right on low load.
On OTS it was feeling too high
Old 09-23-2016, 04:59 PM   #542
steve99
Drives: FT86
Yep i did.
haha yes -3l/100km better on wayno's tune yes that's about correct
thought you were saying 3L/100km economy on E85 :-)
Old 09-23-2016, 05:08 PM   #543
Camsheim
Hachiroku
Camsheim's Avatar
3L on E85 with any car would be a dream :p
Old 10-13-2016, 01:58 AM   #544
Sarsi
Drives: Toyota 86 GTS
Guys, hope you don't mind to just have a quick check of my log to make sure nothing's amiss. I have 2013 Stock Auto, this is the first tank of United E85 after about 100kms flashing Wayno's E85 EL tune from his thread.
http://www.datazap.me/u/sarsi/1st-ta...zoom=1898-2152
Cheers
Sarsi is offline   Reply With Quote
Old 10-13-2016, 03:42 AM   #545
Wayno
Wayno's Avatar
Cheers
It don't get any better than that. You should log until redline though.
FYI this is what to look at. You don't need to touch timing.
Old 10-13-2016, 07:58 PM   #546
Sarsi
Thanks Wayno, I thought you suggested logging from 2-6k in your dialling in thread but see that I've somehow gotten mixed up, anyway good to know all is good
Next step is to install the PSR header
Stock FR-S Tune Just Done Zach3794 Engine, Exhaust, Transmission 67 11-05-2017 03:01 PM
stock BR-Z, much detonation during shifts: tune? elefunkd Engine, Exhaust, Transmission 69 07-26-2013 05:20 PM
Anyone have a stock tune from Visconti? Bleevin CANADA 3 07-03-2013 02:01 AM
My Initial (all stock) BRZedit tune mad_sb Engine, Exhaust, Transmission 6 02-16-2013 01:20 PM
Save stock tune with ecutek? gdrider77 Engine, Exhaust, Transmission 7 01-06-2013 01:50 AM
