Old 09-20-2016, 10:00 PM   #1
Crunk81us
Drives: Toyota 86
t86rs rear suspension. stock but 2.6 degree neg camber???
Hi Guys,
So I am just wondering if oem parts could be mixed and matched to somehow add neg camber to the rear?
Many of the cars at the lower end of the field sit around 1.5 degree neg camber at minimum ride height.
some cars "that came like this from factory with all factory parts" have up to 2.8 degree neg.
any ideas on how this has been achieved. I have looked around and all i have found is upgraded bolts but they dont change anything.
I know rear camber is ride height dependent as well, but max I have seen is 1.7 neg at below min ride height.
Is this just a case of someone measuring hundreds of factory parts to find arms that are slightly longer, cradles that are slightly wider, and hubs that are slightly more offset and combining them? or am i missing something here?
I AM DEFINITELY NOT SAYING ANYONE IS CHEATING.
I THINK THERE ARE JUST SOME VERY SMART PEOPLE OUT THERE!
Crunk81us is offline   Reply With Quote
Old 09-20-2016, 11:03 PM   #2
Cole
Not a troll
Cole's Avatar
Go jack your car up, then loosen every single bolt on the entire suspension assembly.
Then, tighten them all up and get it aligned.
Do that 100 times and you'll get different results every time.
Cole is offline   Reply With Quote
Old 09-21-2016, 12:22 AM   #3
NissanGuy
NissanGuy's Avatar
Drives: Strangely.
Furthermore:
If you manage to do that while on the ground, you'll end up with more camber.
My FR-S has a build thread!
(It's mostly full of Nissans)
NissanGuy is offline   Reply With Quote
The Following User Says Thank You to NissanGuy For This Useful Post:
Crunk81us (09-21-2016)
Old 09-21-2016, 02:58 AM   #4
Crunk81us
Drives: Toyota 86
Originally Posted by NissanGuy View Post
Furthermore:
really.. its that simple?
Old 09-21-2016, 03:03 AM   #5
swarb
Yes. Good luck doing it safely.
And "Crash bolts" up front should add another .8 camber.
Some may consider trd springs "oem"
Old 09-21-2016, 10:29 AM   #6
wparsons
wparsons's Avatar
Where are you finding someone that had -2.8* in the rear at stock height on all stock parts? That seems really unlikely, and is WAY outside the factory spec.
flickr
Old 09-21-2016, 12:12 PM   #7
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
If it's been lowered, maybe. Unlikely a completely stock one to have that much camber.
These look like they have been lowered a good amount. http://www.caradvice.com.au/441862/2...ew-track-test/
Also, how much are you lowered? According to my records, with completely stock suspension on my MY13 I had -1.0*L/-1.4*R in the rear, no driver weight. After installing some swift lowering springs (-1.0" or 25mm) I had as much as -2.3* camber with all else stock.
Intent > Content
Old 09-21-2016, 07:08 PM   #8
NissanGuy
NissanGuy's Avatar
Drives: Strangely.
It's a pain in the ass, but yeah, basically. Most notably on the front strut-to-knuckle bolts. But at that point, you may as well put in some camber/crash bolts.
The rear has enough camber, and some very aggressive geometry. I think the rear subframe bushing flex reduces your dynamic camber; rear subframe bushing inserts definitely improve rear grip.
Old 10-18-2016, 07:12 AM   #9
Crunk81us
Drives: Toyota 86
they have coilovers, and a minimum ride height.
All other parts are supposed to be oem.
Old 10-18-2016, 12:42 PM   #10
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Sounds like this is rules related to a racing series? Its really not likely imo but you never really know.
i would probably protest if they were between me and a trophy
Old 10-18-2016, 05:11 PM   #11
wparsons
wparsons's Avatar
You didn't actually mean ALL factory parts, or came from the factory like that...
flickr
Old 10-18-2016, 05:55 PM   #12
Spartarus
...Just add nauseum
Spartarus's Avatar
Drives: 2003 (AP1) S2000
It sounds like he's repeating a claim made by someone else in the series, probably by the team with the aforementioned mystery camber...
There are many ways to displace.
-Spartarus
Spartarus is offline   Reply With Quote
The Following User Says Thank You to Spartarus For This Useful Post:
wparsons (10-19-2016)
Alignment with stock suspension + camber plates Pat Tracking / Autocross / HPDE / Drifting 9 08-18-2015 01:39 PM
FOR SALE: 62 Degree front suspension kit. Ringnes Suspension | Chassis | Brakes -- Sponsored by 949 Racing 18 11-07-2014 05:07 PM
WTB: caster/camber plates - Or rear suspension alignment pieces STS-V Want-To-Buy Requests 0 06-27-2014 10:24 AM
How to achieve -2.0 front Camber with stock suspension (if possible)? glamcem Suspension | Chassis | Brakes -- Sponsored by 949 Racing 66 04-06-2014 03:11 AM
Cheapest way to get more camber on stock suspension Snake Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 02-11-2014 09:45 AM
