Old 09-19-2016, 10:18 PM   #1
BRZ'13
BRZ'13's Avatar
Drives: subaru
Suspension clunking (i think)
Been having a weird issue with the car. I think its suspention related
From a stand still if i rev to about 3.5-4k and let the clutch slip i can hear knocking in the rear (barely any if any wheel spin). It certainly does not feel like tire hop but maybe it is? The sound goes away once the car is going over 25km/h. I can re perform the sound everytime from a stop
Not sure if anyones had any similar issues. Thinking it could be axles maybe
Im on cheap coilovers (bc racing), 265 tires with supercharger if that helps
BRZ'13 is offline   Reply With Quote
Old 09-20-2016, 12:32 AM   #2
If you were making a turn, I would suspect a rear axle.
But, going straight ahead, I would suspect a drive shaft universal or a bad acting differential.
You may wish to check that your coil overs are bolted down tight.
BRZ'13 (09-20-2016)
Old 09-20-2016, 02:13 AM   #3
I think OP is saying he's practically launching it. "Barely any wheelspin." It also sounds like he's describing a cyclic/repeating sound until he gets up to a certain speed.
I think OP has a failed CV joint.
humfrz (09-20-2016)
Old 09-20-2016, 06:53 AM   #4
RichardsFRS
RichardsFRS's Avatar
Drives: 2013 Pearl White 6MT
I had similar issues and I could feel the clunk too. After investigating; the damn seats were lose from the latch. LOL I know, the obvious right
Back from bancation in Banopolis where I laid on the beach with a beer between my legs. I at night and ate at sun rise
RichardsFRS is offline   Reply With Quote
The Following User Says Thank You to RichardsFRS For This Useful Post:
BRZ'13 (09-20-2016)
Old 09-20-2016, 08:24 AM   #5
You say "on cheap coilovers" but not if you have done the other supporting mods. LCAs or anything else?
BRZ'13 (09-20-2016)
Old 09-20-2016, 12:23 PM   #6
.......that's for not being able to tell the difference ......
Ultramaroon (09-20-2016)
Old 09-20-2016, 12:51 PM   #7
RichardsFRS
Shut up old man! At least I could hear it!
Old 09-20-2016, 12:51 PM   #8
kch
Senior Misanthrope
kch's Avatar
Does it happen on hard braking too? And do you have aftermarket LCAs? Could be them.
Old 09-20-2016, 01:05 PM   #9
WHAT DID YOU SAY ....... ???????
Old 09-20-2016, 06:00 PM   #10
BRZ'13
BRZ'13's Avatar
Drives: subaru
yeah this. if i set off normally, i cant hear it. il try and film it and see if i can get it on tape. only happens on low speeds
Old 09-20-2016, 06:01 PM   #11
BRZ'13
BRZ'13's Avatar
Drives: subaru
only other mod back there is SPC control arms at about 2.3 degrees camber
i cant see it being the coils since its only at low speeds. maybe contributing to the cause?
Old 09-20-2016, 06:02 PM   #12
BRZ'13
BRZ'13's Avatar
Drives: subaru
il check under braking and yes SPC lower arms
Old 09-20-2016, 07:13 PM   #13
I forgot to ask how much drop. Anything over about an 1 1/2 has been known to cause axle issues.
It could also be as simple as needing to tighten the retaining nuts though. I would start with that since you certainly fit the description.
Axle issues - http://www.ft86club.com/forums/showthread.php?t=49511
Nut tightening - http://www.ft86club.com/forums/showthread.php?t=92971
BRZ'13 (09-20-2016), humfrz (09-20-2016)
Old 09-20-2016, 08:22 PM   #14
BRZ'13
BRZ'13's Avatar
Drives: subaru
ok this is certainly the issue. exact description in the second link. lowered + sticky tires + 300whp will do it.
Thank you!
The Following User Says Thank You to BRZ'13 For This Useful Post:
Tcoat (09-20-2016)
Rear suspension clunking noise. Help ): dito Suspension | Chassis | Brakes -- Sponsored by 949 Racing 38 09-15-2016 03:09 AM
Loud clunking underneath driver's side area: suspension, chassis, or wheel related? loading_please_wait Issues | Warranty | Recalls / TSB 4 06-18-2015 03:13 PM
Clunking in rear suspension toeout Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 01-21-2015 04:11 PM
Clunking sound coming from suspension Maverickgear Issues | Warranty | Recalls / TSB 9 07-11-2014 02:41 PM
rear rattling/clunking suspension noise ceebo Scion FR-S / Toyota 86 GT86 General Forum 8 04-25-2014 10:00 PM
