Drives: '18 Camaro V6 1LE
What's a reasonable starting point for fluid change intervals?
What's a reasonable starting point for fluid change intervals, in the number of track days? My car is stock N/A, EHP tires, XP8 / Club Racer, has an oil cooler installed, and "level of abuse" is around 2:16 at Thunderhill Bypass.
Engine - Redline 5W30 Brake/Clutch - Motul RBF600 Transmission/Differential - Motul Gear 300 |
#2 |
You're using good stuff.
Engine - normal oil change interval, as long as your oil cooler is suffient and keeping your temps under 250F (stock oil temp is read post-cooler, so oil temp peak is higher) Brake fluid - Whenever the feel degrades, or your reservoir is dark Clutch fluid - once a year (use leftover brake fluid from a bleed) Trans/Diff - Every 5 days, or 15k miles, whichever comes first. |
| The Following 5 Users Say Thank You to CSG Mike For This Useful Post: | DarkSunrise (09-13-2016), hpde_addict (09-13-2016), MarkR171 (09-13-2016), Shark_Bait88 (09-13-2016), strat61caster (09-13-2016) |
#3 | |
Drives: '05 Elise
![]() Edit: I just realized this is every 5 TRACK days. Makes perfect sense now, move along.
'05 Lotus Elise
'19 BMW M2C '22 Subaru WRX ex '15 Scion FR-S Last edited by MarkR171; 09-13-2016 at 02:05 PM. |
| The Following 3 Users Say Thank You to MarkR171 For This Useful Post: |
#4 |
Drives: Track preped NA FRS
Emm, so I should have changed my tranny fluids twice already this year, this might explain why my first and second dont want to engage right after a track day (as in, right after when driving home).
| The Following User Says Thank You to Icecreamtruk For This Useful Post: | CSG Mike (09-13-2016) |
#5 |
These are just ballpark recommendations. Adapt them to your useage, habits, and pace.
#6 | |
BTW, I think these initial guidelines would be very useful for noobs in "Quick and dirty guide to track prepping your car". |
#7 | |
Used oil analysis is the best way to determine intervals... |
#8 |
Drives: 2013 Scion FR-S 10-Series
Recommended Oil
Mike,
I track my car and would love your advise on what oil I should be running. I will purchase from you as well. My car has a Cosworth SC and P&L oil cooler but the oil cooler is not very efficient. My temps are near 300 at the end of my run sessions. Currently running 15w50 Mobile 1 synthetic but it just makes me nervous it's too thick. I'm very aware of the engine failures with our cars and oil temp to be a factor. Please help! Thanks, Mike |
#9 | |
Running too thick an oil ALSO results in higher temperatures, due to friction. Try a 30 weight first, and then keep an eye on your oil temps, and proceed from there. |
| The Following 2 Users Say Thank You to CSG Mike For This Useful Post: | Icecreamtruk (09-15-2016), Insurme1 (09-15-2016) |
#10 | |
#11 | |
Actually from a senior member from this forum. According to his analysis a forced induction motor under extreme summer conditions being tracked the viscosity of the lower weight oil breaks down causing a loss of pressure then failure. I have been somewhat nervous about it that's why I'm asking. |
#12 | |
Thanks Mike! Going on to your site and purchase some goodies today! Thanks Mike Shelton |
#13 | |
#14 | |
Drives: 2005 Toyota Camry
http://www.ft86club.com/forums/showthread.php?p=2452143 |
| AT fluid change when going FI? | xsnapshot | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 7 | 05-31-2016 07:03 PM |
| What are the oil change intervals listed for 2015 cars? | pantdino | Issues | Warranty | Recalls / TSB | 8 | 09-06-2015 01:36 PM |
| AT Fluid Change? | Estey | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 45 | 10-23-2014 09:55 PM |
| Oil change intervals? | nickw14 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 10 | 08-10-2014 04:06 PM |
| Overview of suspension options beyond coilovers (starting point) | dp1 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 7 | 03-27-2014 10:07 AM |
