Old 09-13-2016, 12:41 PM   #1
hpde_addict
Drives: '18 Camaro V6 1LE
What's a reasonable starting point for fluid change intervals?
What's a reasonable starting point for fluid change intervals, in the number of track days? My car is stock N/A, EHP tires, XP8 / Club Racer, has an oil cooler installed, and "level of abuse" is around 2:16 at Thunderhill Bypass.
Engine - Redline 5W30
Brake/Clutch - Motul RBF600
Transmission/Differential - Motul Gear 300
hpde_addict is offline   Reply With Quote
Old 09-13-2016, 01:04 PM   #2
CSG Mike
CSG Mike's Avatar
You're using good stuff.
Engine - normal oil change interval, as long as your oil cooler is suffient and keeping your temps under 250F (stock oil temp is read post-cooler, so oil temp peak is higher)
Brake fluid - Whenever the feel degrades, or your reservoir is dark
Clutch fluid - once a year (use leftover brake fluid from a bleed)
Trans/Diff - Every 5 days, or 15k miles, whichever comes first.
The Following 5 Users Say Thank You to CSG Mike For This Useful Post:
DarkSunrise (09-13-2016), hpde_addict (09-13-2016), MarkR171 (09-13-2016), Shark_Bait88 (09-13-2016), strat61caster (09-13-2016)
Old 09-13-2016, 01:25 PM   #3
MarkR171
MarkR171's Avatar
Drives: '05 Elise
Edit: I just realized this is every 5 TRACK days. Makes perfect sense now, move along.
'05 Lotus Elise
'19 BMW M2C
'22 Subaru WRX
ex '15 Scion FR-S
MarkR171 is offline   Reply With Quote
The Following 3 Users Say Thank You to MarkR171 For This Useful Post:
CSG Mike (09-13-2016), strat61caster (09-13-2016), wparsons (09-15-2016)
Old 09-13-2016, 01:29 PM   #4
Icecreamtruk
Drives: Track preped NA FRS
Emm, so I should have changed my tranny fluids twice already this year, this might explain why my first and second dont want to engage right after a track day (as in, right after when driving home).
Icecreamtruk is offline   Reply With Quote
The Following User Says Thank You to Icecreamtruk For This Useful Post:
Old 09-13-2016, 02:47 PM   #5
CSG Mike
CSG Mike's Avatar
These are just ballpark recommendations. Adapt them to your useage, habits, and pace.
Old 09-13-2016, 03:58 PM   #6
hpde_addict
Would a limit of 10 days per oil change be a good starting point?
BTW, I think these initial guidelines would be very useful for noobs in "Quick and dirty guide to track prepping your car".
Old 09-13-2016, 07:11 PM   #7
CSG Mike
CSG Mike's Avatar
Good idea!
Used oil analysis is the best way to determine intervals...
Insurme1 (09-15-2016), wparsons (09-15-2016)
Old 09-15-2016, 12:05 PM   #8
Insurme1
Drives: 2013 Scion FR-S 10-Series
Recommended Oil
Mike,
I track my car and would love your advise on what oil I should be running. I will purchase from you as well. My car has a Cosworth SC and P&L oil cooler but the oil cooler is not very efficient. My temps are near 300 at the end of my run sessions. Currently running 15w50 Mobile 1 synthetic but it just makes me nervous it's too thick. I'm very aware of the engine failures with our cars and oil temp to be a factor.
Please help!
Thanks,
Mike
Insurme1 is offline   Reply With Quote
Old 09-15-2016, 12:54 PM   #9
CSG Mike
CSG Mike's Avatar
Originally Posted by Insurme1 View Post
Mike,
Please help!
Thanks,
Mike
You need to fix that oil temp issue first, but I don't recommend running thicker than a 30 weight on this car.
Running too thick an oil ALSO results in higher temperatures, due to friction. Try a 30 weight first, and then keep an eye on your oil temps, and proceed from there.
Icecreamtruk (09-15-2016), Insurme1 (09-15-2016)
Old 09-15-2016, 12:56 PM   #10
Icecreamtruk
Mike,
Please help!
Thanks,
Mike
Not mike, but from what I have read here I would guess that his first question would be, why are you using 15W50 oil? The car is supposed to use 0W20, ok yeah yours is supercharged, so maybe 5W30 or even 10W40 could make sense, but 15W50 is way too much. Remember the thicker the oil, the more heat it retains and the harder it becomes to cool down.
Old 09-15-2016, 01:21 PM   #11
Insurme1
Actually from a senior member from this forum. According to his analysis a forced induction motor under extreme summer conditions being tracked the viscosity of the lower weight oil breaks down causing a loss of pressure then failure. I have been somewhat nervous about it that's why I'm asking.
Old 09-15-2016, 01:35 PM   #12
Insurme1
Thanks Mike! Going on to your site and purchase some goodies today!
Thanks Mike Shelton
Old 09-15-2016, 05:46 PM   #13
CSG Mike
CSG Mike's Avatar
If you use a full synthetic as mandated by Subaru, the oil won't break down. Sometimes, following directions pays off!
Old 09-15-2016, 07:51 PM   #14
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
My UOA analysis really suggests different.
http://www.ft86club.com/forums/showthread.php?p=2452143
AT fluid change when going FI? xsnapshot Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 7 05-31-2016 07:03 PM
What are the oil change intervals listed for 2015 cars? pantdino Issues | Warranty | Recalls / TSB 8 09-06-2015 01:36 PM
AT Fluid Change? Estey Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 45 10-23-2014 09:55 PM
Oil change intervals? nickw14 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 10 08-10-2014 04:06 PM
Overview of suspension options beyond coilovers (starting point) dp1 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 03-27-2014 10:07 AM
