Old 02-23-2014, 09:24 AM   #1
dp1
driving smoother faster
Drives: Sold
Overview of suspension options beyond coilovers (starting point)
Thread goal: Identify desirable suspension upgrades (beyond coilovers) for a primarily street driven car that's also driven on track and ax for fun.
- Stock suspension works for most people. It's best not to mess up what engineers worked hard to achieve with this car, unless you know what you want out of the modifications and you/installer are choosing appropriate solutions to address your needs.
- Spend time driving the car and learning how suspension and tires behave in transitions, before making changes.
- It's usually better not to make make many changes at once.
- If street ride on stock suspension is stiff for you (as it is for me on "smooth" NY roads), and you have no intention in seriously AX-ing or tracking the car, aftermarket coilovers or springs can accomplish a lot. Car costs around $30k new, all in, and if you can afford to spend another 5-10% on excellent coilovers, it could make a huge difference and it may be all you really need.
- This is not a spring/coilover thread, so quick comment on spring rates and camber from @CSG Mike: "The soft (spring) rates mean that you will get a lot of roll. The roll means that you will hit the compression range on the front struts where instead of gaining negative camber (camber going more negative), you will start to lose negative camber (camber going more positive). This will cause you to lose cornering grip in the front. Ultimately, the stickier tires may cause you to go slower, because you roll more, and lose contact patch from camber loss."
Read 2013 Scion FR-S: Suspension Walkaround to see OEM parts http://www.edmunds.com/car-reviews/t...alkaround.html
Read Alignment FAQ (http://www.ft86club.com/forums/showthread.php?t=25001)
- Usually want some more camber in front than in rear, specific numbers depend on lowering and hardware (OEM, camber bolts, bushings, camber plates, lower control arms/LCAs, etc.) and use (street/AX/occasional track/track-only)
- I daily/ax/track my car in North East and I use -3.0f/-2.5r for street/ax/track Apr-Nov and -1.5f/-1.5r for street-only Dec-Mar.
My build: http://www.ft86club.com/forums/showthread.php?t=79895
Few sites with examples of suspension components (alphabetic order):
http://counterspacegarage.com/produc...el=8&limit=all
http://www.crossoverauto.com/crossov...hm40b3u6qqpfg1
http://ft86speedfactory.com/suspension-38/
http://www.jhpusa.com/store/pc/viewC...dCategory=1711
http://perrinperformance.com/c-74511...uspension.html
http://www.racerxfabrication.com/pro...uspension.html (complete set http://www.racerxfabrication.com/pro...nsion_kit.html)
http://www.torquesolution.com/category-s/1299.htm
COMPONENTS
Camber Adjustment Bolts: Not needed for street use unless you have camber issues with stock setup. Cheap alternative to camber plates (front) and LCAs (rear) to get some negative camber but not much. You will wear outside edges of your tires without enough negative camber and push the car hard in turns, usually greater concern for track, somewhat for ax.
- PERRIN Performance http://perrinperformance.com/i-13324...-14mm-dia.html
Lower Control Arm: Not needed for street use except when car is significantly lowered or for track/ax, to dial in specific camber. Negative camber in the rear will increase with drop. SPC hw is cheaper but has limit for negative camber, also search for concerns about rust. Front LCA - robispec, is lighter, has camber, caster, track width, roll center, and other adjustment...that most will never need. Shop first recommended SPC then swapped for SPL when it turned out that SPC couldn't achieve desired -2.5 rear camber.
- FT-86 SpeedFactory http://ft86speedfactory.com/suspensi...ntrol-arms-98/
- CounterSpace Garage http://counterspacegarage.com/produc...el=8&limit=all
- JB Tuned http://www.jbtuned.com/products/spl-...trol-arms.html
- Racer X Fabrication http://www.racerxfabrication.com/pro...trol_arms.html
Upper Control Arm: Not needed for street use.
- The Racer X Fabrication rear upper control arms http://racerxfabrication.com/product...trol_arms.html
Toe Arm: Not needed for street use. Used to adjust rear toe and for lowered applications.
- FT-86 SpeedFactory toe arms (various options) http://ft86speedfactory.com/suspension-38/toe-arms-120/
Engine Mount: Reduce engine movement and improve power delivery at the expense of increased Noise Vibration Harshness (NVH). Stiffest mounts have highest NVH, especially at idle, and are geared towards AX/track use. Installed Perrin engine mount at the same time as Perrin transmission support. Noticeable increase in vibration from stock, especially on cold start.
- RallySportDirect.com (Cusco) engine mount http://www.rallysportdirect.com/Cusc...gine-Mount-Set
- PERRIN Performance http://perrinperformance.com/i-13324...-fr-s-brz.html
Transmission Support: Not needed for street use. Can improve shifting feel at the expense of added NVH, usually not significant. Installed Perrin transmission mount support at the same time as Perrin engine mount. Noticeable increase in vibration from stock, especially on cold start. Waiting to see if anything changes as the engine mount settles in, also temps are in the 40's, which affects rubber. Will update post after putting on some miles.
- PERRIN Performance transmission support http://perrinperformance.com/i-13324...-fr-s-brz.html
Front Control Arm Brace: Not needed for street use. Improves feel under heavy braking in AX/track applications.
- PERRIN Performance front control arm brace http://perrinperformance.com/i-13324...-fr-s-brz.html
Endlinks: Not needed for street use. Recommended with installation of stronger aftermarket swaybar. Purchased both front and rear Whiteline endlinks per advice from shop.
http://ft86speedfactory.com/suspension-38/end-links-96/
- Whiteline http://ft86speedfactory.com/whitelin...links-616.html
- PERRIN Performance spherical bearings http://perrinperformance.com/i-13324...-fr-s-brz.html
- PERRIN Performance ss xd spherical bearings http://perrinperformance.com/i-14660...-fr-s-brz.html
- PERRIN Performance endlinks with poly bushings http://perrinperformance.com/i-13324...-fr-s-brz.html
- Racer X Fabrication rear end links http://www.racerxfabrication.com/pro...end_links.html
- Whiteline rear end links http://ft86speedfactory.com/whitelin...links-613.html
Rear Toe Links: Not needed for street use. Adds rigidity and used for toe adjustment.
Racer X Fabrication rear toe links http://www.racerxfabrication.com/pro...toe_links.html
Positive Steering Response System: Not needed for street use. Replaces the front control arm, front bushings, to reduce toe changes under hard braking.
- PERRIN Performance (zero) http://perrinperformance.com/i-13324...-fr-s-brz.html
- PERRIN Performance (offset) http://perrinperformance.com/i-13324...-fr-s-brz.html (offset)
Steering Rack Lockdown: Not needed for street use. Creates a solid connection between the steering rack and chassis to increase driver feel and communication from the front tires.
- PERRIN Performance steering rack lockdown http://perrinperformance.com/i-15768...-fr-s-brz.html
Sway Bar: Not needed for street use. Stiffens the car during cornering. Often used in AX/track applications. Make sure that you talk to somebody with experience using sway bars on this platform before you make the plunge, also with understanding of your tires, alignment and coilovers. Ideally, somebody already tried what you are interested in, and you have a way to verify that it is what you want. Otherwise, you can change understeer/oversteer behavior, introduce more wheel spin, make the ride unnecessarily harsh and twitchy. Be careful with this one, especially if you spend most of the time driving on the street.
@CSG Mike: "Sways are typically used to reduce overall body roll (used front AND rear), or to adjust front/rear load balance (stiffer bar = more load = that axle loses traction faster relative to the opposite axle). E.g., if you have a car that is very oversteery under cornering, you can use a front sway to try to balance it out."
- PERRIN Performance front sway bar http://perrinperformance.com/i-13324...-fr-s-brz.html
- PERRIN Performance rear sway bar http://perrinperformance.com/i-13324...-fr-s-brz.html
dp1 is offline   Reply With Quote
Old 02-27-2014, 11:30 PM   #2
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
I read about someone running an eccentric bolt on the rear lower control arm to gain some negative camber. Not so sure if that is a good idea since there is nothing stopping them from rotating besides the clamping force on the nuts and bolts. Although, the low cost is very appealing. Any opinions on this?
Old 02-27-2014, 11:35 PM   #3
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Since you already have Ohlins, you should know what I also know:
Ohlins RT
Wheels
Tires
Brakes
Endlinks (maybe)
THAT IS IT.
Right now, for DD + ~10-15 track events a year max, I have zero need for any other suspension mod on the car.
If I do swap out something else, it'll be because parts are breaking, not because I need them.
-alex
Old 02-27-2014, 11:40 PM   #4
dp1
Drives: Sold
Ohlins RT
Wheels
Tires
Brakes
Endlinks (maybe)
THAT IS IT.
-alex
Thanks, what is your F/R camber and toe?
Old 02-27-2014, 11:48 PM   #5
mav1178
mav1178's Avatar
Front is -2.25, zero toe.
Rear is -1.5, zero toe. Rear camber is static, as it is what the car's camber ended up at after I "slammed" the Ohlins.
And when I mean slammed, I mean I adjusted it as low as they can go... which isn't much. Around -25mm front and -20mm rear versus stock. Barely lower than Eibach Prokits.
-alex
Old 02-27-2014, 11:50 PM   #6
dp1
Drives: Sold
-alex
Thanks, one more q - rims size/offset and rubber type/size for track?
Old 02-28-2014, 12:01 AM   #7
mav1178
mav1178's Avatar
Currently:
Volk RE30, 17x8" +44
Falken Azenis RT615R 235/40-17
Will move up to a different compound as my skills improve. 10 years between tracking the car (on a regular basis) makes you a rusty driver!
-alex
Old 03-27-2014, 10:07 AM   #8
dp1
Drives: Sold
Updated comments on engine mounts and transmission support.
BRZ/FR-S Suspension Options List (Springs and Coilovers) WingsofWar Suspension | Chassis | Brakes -- Sponsored by 949 Racing 333 02-01-2022 05:32 PM
Megan Racing Coilovers - Street / Track / EZ STREET - Starting at $699 Shipped GuerillaRacing Brakes, Suspension, Chassis 149 05-12-2015 05:53 PM
Buddy Club Racing Spec coilovers track and street test Mark Slide Squad Suspension | Chassis | Brakes -- Sponsored by 949 Racing 32 12-09-2013 07:01 PM
In Search of Coilovers (Clearance/Street/Track/Not Super Stiff) FR-S Matt Suspension | Chassis | Brakes -- Sponsored by 949 Racing 23 06-06-2013 08:36 PM
