Old 09-07-2016, 01:29 AM   #29
Originally Posted by billwot View Post
Wow, that's really amazing that you can remember something so precisely for 2 years!
Hey there, @billwot , at your ripe age, your long term memory should be good too .....
Old 09-07-2016, 01:42 PM   #30
MrDinkleman
Drives: 2016 Oceanic, "base" model
Weird. Can't reply with quote for Gramicci101...
Anyway, what I meant about "tracking straight" is that as soon as I let the steering wheel go, it starts to drift one way or the other, not that it pulls one way or the other. All of my other RWD cars will usually just track straight for at least a little while. Makes it difficult to tie my necktie in the morning...
But thanks for the suggestion about the CasCam plates. Need to look into those...
MrDinkleman is offline   Reply With Quote
Old 09-07-2016, 02:13 PM   #31
Like mentioned, I would suggest you get an alignment.
Old 09-07-2016, 03:31 PM   #32
billwot
Drives: '11 Cayman , '14 Camry, '11 Tacoma
It ain't that good!
billwot is offline   Reply With Quote
The Following User Says Thank You to billwot For This Useful Post:
humfrz (09-07-2016)
Old 09-08-2016, 05:04 AM   #33
86wtywly
Drives: 2014 Scion Frs
That was my first mannual car. I won't forget.
86wtywly is offline   Reply With Quote
Old 09-08-2016, 05:07 AM   #34
86wtywly
Not necessarily. I've had two new cars that needed to go back to the dealer to have the alignment adjusted.
Yup. And tire pressures. I believe they ship cars with the tires overinflated (forgot reason why) and the dealer may not have let air out during the prep work.
If tire pressure is off, the tire pressure light should be turned on right? And I am not sure the dealer will do the alignment for free though. Most dealers try to avoid as much work as possible. They would tell u everything is normal even there is indeed an issue.
Old 09-08-2016, 05:34 AM   #35
soulreapersteve
Contract? /人◕ ‿‿ ◕人\
soulreapersteve's Avatar
The light will come on under.. 28 psi if I recall correctly. Forgot what the exact number is. 35 is the recommendation, according to the manual and the sticker on the door jam.
The Twins make me smile
Old 09-08-2016, 06:22 PM   #36
billwot
Does that have something to do with the steering effort?
Old 09-08-2016, 07:12 PM   #37
Question, what do you consider "heavier" or "lighter" steering .. ?? The effort to turn the steering wheel ..... or something else .. ??
Since the car is relatively new, you may consider asking the dealer that you bought the car from, to check the alignment. If they won't, I suggest you take it to a tire shop to have it aligned.
Also, as mentioned several times, check the tire pressure. If you bring them down to about 32 psi, from 35 psi, the steering will feel different.
So, 86wtywly, what's your plan ..... ??
Old 09-16-2016, 02:36 AM   #38
86wtywly
Yea i thought there should be more steering efforts on the frs.
Old 09-16-2016, 02:37 AM   #39
86wtywly
[QUOTE=humfrz;2748853]Question, what do you consider "heavier" or "lighter" steering .. ?? The effort to turn the steering wheel ..... or something else .. ??
I checked both at the dealer. They looked and said everything looks great. They provided me with the alignment sheet. Even though I still feel the steering should be a little heavier. But it might be juz the car's setup. I am not sure
Old 09-16-2016, 02:39 AM   #40
86wtywly
Old 09-16-2016, 12:42 PM   #41
Imrac
Drives: 13 SWP BRZ Prem
Want a heavier feel, add wider wheels and tires. Going from my summer set 17x9, 245 to my winter set stock wheels with 215s and a different compound is night and day difference.
The tire friction makes can make a huge difference in the feel of the steering. Try driving on some loose gravel and it will feel extremely light.
JDL UEL Headers, Nameless Res&Cat Over&Front, Invidia Q300 Catback, AVO Dry Panel Filter, Custom ECUTek Tune by DriftOffice
191WHP/151 ft-lb on 92
Imrac is offline   Reply With Quote
Old 09-21-2016, 01:55 PM   #42
mkiisupra
mkiisupra's Avatar
Drives: 83 Toyota Supra, 16 FR-S RS2.0
I also felt a bit of difference between the 13 and the '16 FRS. I however didn't have to wait 2 years to detect the difference. I brought my '13 in to trade in on a '16 and thought the same as the OP (same size tires/rims) that the steering effort feels 'less' on the '16 on my drive home from the dealer.
YMMV,
Eric G
mkiisupra is offline   Reply With Quote
FR-S Future Models 2016+ F1fletch Scion FR-S / Toyota 86 GT86 General Forum 92 12-02-2014 12:32 AM
Improving Steering Feel sittinSideways Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 08-18-2014 06:52 PM
Steering Feel Question Concerning Tic Solid Steering Bushings brillo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 15 10-31-2013 04:52 PM
Best Tire for Steering Feel Khyron686 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 03-12-2013 12:01 PM
Steering Wheel Feel ap5512 BRZ First-Gen (2012+) — General Topics 8 12-08-2011 11:16 AM
