Old 08-10-2014, 05:04 PM   #1
sittinSideways
sittinSideways's Avatar
Drives: '13 Firestorm FRS
Improving Steering Feel
Hi all,
I'm trying to improve the amount of feedback I get from the wheel, and the overall steering feel and responsiveness of the car. I want it to feel tight and responsive. Thus I've started to look into various aftermarket parts to accomplish this. So far I ordered Perrin's Steering Rack Lockdown kit:
http://perrinperformance.com/i-15768...-fr-s-brz.html
While this is a step forward in my goal of recieving more steering feedback, it does nothing towards my other goal of making my steering more responsive. Thus I've started to look into steering rack bushings:
http://www.ft86speedfactory.com/inde...FehaMgodFG0AEA
But... Is this actually more solid than stock bushings, and will it make a difference in steering feel?
Any more suggestions on accomplishing my goals would greatly welcomed! Thanks
Last edited by sittinSideways; 08-10-2014 at 05:33 PM. Reason: Clarify: improving response of entire car
sittinSideways is offline   Reply With Quote
Old 08-10-2014, 05:10 PM   #2
gramicci101
Off Topic
Cusco is overpriced. Other brands are $20-$50. They do provide better steering feel, because polyurethane is stiffer than rubber.
If you want to go all in, look into Turn-in Concepts' solid aluminum steering rack bushings. Or if you need to stay STX-legal, their Delrin bushings.
The Following 2 Users Say Thank You to gramicci101 For This Useful Post:
fstlane (08-10-2014), sittinSideways (08-10-2014)
Old 08-10-2014, 05:13 PM   #3
zkv476
zkv476's Avatar
Drives: 2014 SWP BRZ, MT
Steering rack bushings are probably redundant with the steering rack lockdown in my opinion. Do either or. TiC makes an aluminum bushing replacement and also has virtually no movement. Perrin makes a replacement front control arm bushing that could probably help. http://perrinperformance.com/i-13324...-fr-s-brz.html
zkv476 is offline   Reply With Quote
The Following User Says Thank You to zkv476 For This Useful Post:
Old 08-10-2014, 05:13 PM   #4
tony1019
tony1019's Avatar
Drives: 2013 AVO Boosted Scion Frs
Not sure about steering but I know the car feels way more responsive with upgraded sway bars. Could tell a huge differenceright away that the overall handling felt better.
tony1019 is offline   Reply With Quote
The Following User Says Thank You to tony1019 For This Useful Post:
Old 08-10-2014, 05:37 PM   #5
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
I have heard a solid strut tower bar (like Grimmspeed) has helped with initial turn in response.
And I don't believe TiC sells the aluminum bushings anymore since I could only find the derlin on their website recently. If you are interested I have a brand new set f aluminum I could part with since I really need derlin for autox. PM me if you are interested.
Old 08-10-2014, 05:50 PM   #6
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Same question has already been asked here:
http://www.ft86club.com/forums/showthread.php?t=11810
Old 08-11-2014, 11:32 PM   #7
Turdinator
Señor Member
Turdinator's Avatar
For resposiveness I would look into your alignment, tyres with a stiffer sidewall, poly bushes in the LCAs or aftermarket LCAs with rose joints/rodends/ball joints/hiem joints/whatever you prefer to call them. Lightweight wheels and any weight reduction you can do around the front of the front of the car will also help. There is also a thread on the BRZ tS which mentions the different steering rack bolts Subaru/STI used to improve steering feel that may be worth investigating.
1974 TA22 Celica
2013 86 GT
Old 08-18-2014, 12:49 PM   #8
KoolBRZ
KoolBRZ's Avatar
Originally Posted by sittinSideways View Post
Hi all,
I just installed the Delrin inserts from turn in concepts. They actually reduce vibration while turning in instantly. No over-corrections! There was always some hesitation cutting into a sharp corner, than backing off because the rubber decompresses and over-corrects. These are cheap and easy to install and make the biggest difference dollar for dollar, then anything else. You also need to re-align the car afterwards, since the rack might move some during the installation.
The Following User Says Thank You to KoolBRZ For This Useful Post:
sittinSideways (08-18-2014)
Old 08-18-2014, 04:17 PM   #9
Captain Snooze
Drives: Red Herring
Maybe if you install them yourself but if you have paid someone to install them and do an alignment then the GrimmSpeed bar is cheaper and made a bigger difference for me. Nice double post btw.
Old 08-18-2014, 06:52 PM   #10
Black Tire
Black Tire's Avatar
Drives: Whiteout Scion FR-S
My solution that works quite well, this, this, this, and this:
http://www.frsport.com/Carbing-Front...Z_p_52274.html
http://passwordjdm.com/PasswordJDM-U...8627C2619.aspx
The Carbing brace is probably the most noticeable single improvement.
power steering feel adjustment brillo Engine, Exhaust, Transmission 29 11-06-2017 03:41 PM
Steering Feel Question Concerning Tic Solid Steering Bushings brillo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 15 10-31-2013 04:52 PM
Steering feel with wider tires? TSY Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 42 07-26-2013 10:32 AM
Best Tire for Steering Feel Khyron686 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 03-12-2013 12:01 PM
Steering Wheel Feel ap5512 BRZ First-Gen (2012+) — General Topics 8 12-08-2011 11:16 AM
