Old 09-06-2016, 04:38 PM   #15
FX86
Originally Posted by 86wtywly View Post
Drove a 2014 two years ago. That steering feels heavier and provides more steering feel in my opinion
but two years is a long time...what did you drive after the 2014 model?
Old 09-06-2016, 04:40 PM   #16
Shit, I don't think I would recall the precise steering feel from a car I drove two years ago even if I drove it every day!
The arm dyno is no more reliable than the butt dyno after that long.
humfrz (09-06-2016), mdm (09-07-2016), Ultramaroon (09-07-2016), wireman957 (09-06-2016)
Old 09-06-2016, 04:50 PM   #17
Juz got a 2016 frs. Everything is fine except steering feels lighter than before. Drove a 2014 model two years ago. The steering used to feel a little heavier. To me, that provides more steering feel.
Anyone know what's going on? They changed the steering on the 2016 model?
Hello, there, 86wtywly .........
What's going on?
It could be a couple of things.
* you had a very small representative sample 2 years ago (one car ..??).
* it could be the fact it was two years ago ..... ...... recollections can change over time.
Time fer ma nap ...... I suggest you chew on those possibilities .....
Old 09-06-2016, 04:54 PM   #18
86wtywly
Drives: 2014 Scion Frs
I had a evo x. But I don't really think that is suitable for me. No connection with the car whatsoever. That's why I changed back
86wtywly is offline   Reply With Quote
Old 09-06-2016, 04:55 PM   #19
FX86
how was the steering feel on the evo?
Old 09-06-2016, 04:58 PM   #20
86wtywly
What's going on?
It might be those factors. Probably I am paranoid.
The Following User Says Thank You to 86wtywly For This Useful Post:
humfrz (09-06-2016)
Old 09-06-2016, 04:58 PM   #21
86wtywly
Direct, precise, and heavier feel comparing to frs I am driving now.
Old 09-06-2016, 04:59 PM   #22
86wtywly
Ur probably right man. Maybe I am over analyzing the situation.
Tcoat (09-06-2016)
Old 09-06-2016, 07:57 PM   #23
Evos used a hydraulic assist instead of the electric motor. They did have a heavier feel but I never quite liked the ever so slight lag that I felt it had. Wasn't horrible but was enough that several abrupt opposite turns could get interesting. I will take the electric assist over hydraulic any day.
Old 09-06-2016, 08:17 PM   #24
wireman957
wireman957's Avatar
Drives: 2015 FR-S MT Steel
^^^this
For years the only steering assist that most cars had was hydraulic and the very nature of hydraulics means there is at least a bit of a lag while the hydraulic fluid compresses enough to do its job, especially when it gets a little old. I find the progressive nature (based on speed) of the 86's electronic assist feels very natural. It is much more communicative than the steering in my old 924, which at the time, was remarkable. Compared to the Santa Fe I traded in to get my FR-S, the steering in my 86 is perfect. It's like I just have to think about turning or changing lanes and the car does it. I honestly don't feel like I've ever had such control over a vehicle in my 45 years of driving. Smooth turns, induced over-steer, whatever, I see zero issues with the steering in this car.
"No matter where you go, there you are" - Buckaroo Banzai
wireman957 is offline   Reply With Quote
The Following 6 Users Say Thank You to wireman957 For This Useful Post:
humfrz (09-06-2016), Mule (05-30-2017), MuseChaser (09-07-2016), soulreapersteve (09-08-2016), Tcoat (09-06-2016), Ultramaroon (09-07-2016)
Old 09-06-2016, 09:53 PM   #25
MrDinkleman
Drives: 2016 Oceanic, "base" model
It's a new car though shouldn't be having any problems with alignment
Not necessarily. I've had two new cars that needed to go back to the dealer to have the alignment adjusted.
So I should check my alignment first?
Yup. And tire pressures. I believe they ship cars with the tires overinflated (forgot reason why) and the dealer may not have let air out during the prep work.
MrDinkleman is offline   Reply With Quote
Old 09-06-2016, 10:20 PM   #26
MrDinkleman
Actually, after giving it some more thought, I agree with the OP that steering feel on the FRS does feel light and it doesn't track as straight as I like. I was thinking it would be great if I could increase caster but then I discovered that caster is not adjustable and I've been meaning to ask if anyone in aftermarket part land makes a part to make caster adjustable.
Old 09-06-2016, 10:29 PM   #27
billwot
Drives: '11 Cayman , '14 Camry, '11 Tacoma
Wow, that's really amazing that you can remember something so precisely for 2 years!
billwot is offline   Reply With Quote
Old 09-07-2016, 01:19 AM   #28
gramicci101
Off Topic
RaceSeng CasCam plates. Some plates add a set amount of caster (RCE and Velox, I think) but RaceSeng is the only one that is adjustable.
Make sure all the other stuff is good though. The OEM front spec is 0 +/- 0.75°, with the wheels no more than 0.75° apart. So conceivably, one wheel could be 0, the other could be +0.75°, and they would still be in spec. Also check the toe. The OEM range is 0 +/- 0.19° for each wheel, and that could have significant effect as well. A good performance alignment might fix your issues without having to drop $500 on a set of camber plates.
The Following 2 Users Say Thank You to gramicci101 For This Useful Post:
humfrz (09-07-2016), MrDinkleman (09-07-2016)
FR-S Future Models 2016+ F1fletch Scion FR-S / Toyota 86 GT86 General Forum 92 12-02-2014 12:32 AM
Improving Steering Feel sittinSideways Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 08-18-2014 06:52 PM
Steering Feel Question Concerning Tic Solid Steering Bushings brillo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 15 10-31-2013 04:52 PM
Best Tire for Steering Feel Khyron686 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 03-12-2013 12:01 PM
Steering Wheel Feel ap5512 BRZ First-Gen (2012+) — General Topics 8 12-08-2011 11:16 AM
