Old 09-05-2016, 01:45 PM   #15
RJasonKlein
RJasonKlein's Avatar
Drives: 2013 Scion FR-S 10 Series
Originally Posted by EN2_Squirrel View Post
I had axle issues with my hoosiers. So did the FRSPORT car. although both cars are being built for Street Mod. So that may explain of of it.
What failed specifically - the inner or outer joint, the splines, or the shaft itself?
Last edited by RJasonKlein; 09-06-2016 at 12:12 AM. Reason: Corrected a typographical error.
RJasonKlein is offline   Reply With Quote
Old 09-05-2016, 02:58 PM   #16
nzer
nzer's Avatar
Drives: 2012 Grey TRD GT86, 2015 VW Golf R
Originally Posted by MaximeT View Post
I think the NZ cars are fully caged, no ?
This one :
http://www.speedhunters.com/2014/01/...ce-mode-engage
Yes, they are fully caged.
nzer is offline   Reply With Quote
Old 09-06-2016, 11:58 AM   #17
EN2_Squirrel
EN2_Squirrel's Avatar
Inside on one. And spectacularly on the other. I am supercharged but i had a massive boost leak when the failures occured.
STREET MOD. My wallet now hates me....
EN2_Squirrel is offline   Reply With Quote
Old 09-06-2016, 02:05 PM   #18
Racecomp Engineering
When you're running slicks and serious suspension...it's time to think about a roll cage or at least a roll bar with proper seats and safety equipment.
Just my opinion...and Myles, Dan, Larry all here in the office nodding in agreement.
- Andrew
MaximeT (09-06-2016), Ultramaroon (09-06-2016)
Old 09-06-2016, 02:23 PM   #19
MaximeT
MaximeT's Avatar
Drives: GT86-ACE-JRZ-RPF1-Essex
- Andrew
Yes, I'm looking at the options at the moment.
I need to go safely from home to the track on the road.
My number one option is to use the future Gspeed bolt in half cage. Schroth ASM 4 point harness with added points 5 and 6.
Plus HANS at the track.
According to Schroth user manual it supposed to work with both track safety and oem airbag system.
As it's HANS compliant and still provide torso movement on the road.
If you have other idea, I'm super interested
For the record, I live in a non civilised country regarding building track cars.
Other options are still using the oem belt.
With a Tillett bucket seat that's made for oem belts or with a Bride reclining seat.
I'll take any serious advices and experience.
JRZ 12-32 | ACE 350 | Delicious Tuning | RPF1 | Essex Sprint | SPL | Powerflex | My Car
MaximeT is offline   Reply With Quote
Old 09-06-2016, 02:57 PM   #20
You live in France! Your delicious wine, food, and women make up for a lot of things.
For a serious car (and in my opinion a car with slicks and badass JRZs is a serious car) I would recommend a HANS, HANS compliant FIA approved fixed back seat, HANS compliant 6 point harnesses, and at least a half cage.
This does make street driving a little more complicated. Theoretically you can keep your OEM steering wheel and airbag and keep the OEM 3 point belts in the car for street driving.
- Andrew
Old 09-06-2016, 03:03 PM   #21
MaximeT
MaximeT's Avatar
Do you know a FIA approved seat that can be used with OEM seatbelt receiver ?
I mean with a large enough lap belt opening.
Thanks for your time. It's really appreciated.
Old 09-06-2016, 03:30 PM   #22
Hmm...that I'm not sure about.
No problem!
- Andrew
Old 09-12-2016, 05:08 AM   #23
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Recaro has a street legal (ABE) bucket seat that can be used with OEM seatbelt. Check here: https://www.recaro-automotive.com/de...arbon-abe.html
Unfortunately, you will not find the appropriate rails and seat bracket for our car. You'll have to import them from Recaro Japan (did this sometime ago) or order something inferior from the US that might need some kind of modification ...
Old 09-12-2016, 05:17 AM   #24
MaximeT
MaximeT's Avatar
Only the leather one got the big opening for seatbelt receiver ?
It can't be used with 6 points and is not FIA :/
Old 09-12-2016, 05:47 AM   #25
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
All the seats have the big opening for seatbelt receiver. Probably in the leather there is less material around the opening. Yes, they are not FIA approved. Just for occasional track usage.
Old 09-12-2016, 05:57 AM   #26
MaximeT
MaximeT's Avatar
OK, thanks
Old 10-07-2021, 11:39 AM   #27
AndMsc
Drives: MY2018 GT86 EU
Would a front fender brace help the car? I don't know how much flex is there. https://ramotorsports.ca/collections...z-fender-brace
AndMsc is offline   Reply With Quote
Old 10-07-2021, 05:39 PM   #28
norcalpb
norcalpb's Avatar
I’ve heard the differential input shaft bearing can get damaged from super sticky tires, but just something I heard.
BRZ - Bumper reinforcement or repair kit Trap63 DIY (Do-It-Yourself) Guides 124 01-12-2026 06:22 AM
WTB - OEM Sway Bar Reinforcement Plates and Stabilizer bar bolts loading_please_wait Want-To-Buy Requests 0 06-16-2015 12:58 AM
Decrease That Flex with FR Sport's "Chassis Reinforcement Sale" FRSport.com Brakes, Suspension, Chassis 0 05-30-2014 01:21 PM
Installing the AVO Rear Reinforcement Bracket AVOturboworld DIY (Do-It-Yourself) Guides 9 10-29-2012 11:44 AM
Beatrush Chassis Reinforcement Group Buy Kami Speed Brakes, Suspension, Chassis 40 07-30-2012 09:39 AM
