Old 08-30-2016, 03:12 AM   #1
MaximeT
MaximeT's Avatar
Drives: GT86-ACE-JRZ-RPF1-Essex
Chassis reinforcement for race slick use.
Hi there.
I plan to start using Michelin WEC race slick soon.
This guy :
http://www.apr-europe.com/pneus/24-6...rt-gt-s8l.html
I was wondering if any of you used slicks without chassis reinforcement and how well the body reacts to the abuse ?
Or which reinforcements are critical ?
JRZ 12-32 | ACE 350 | Delicious Tuning | RPF1 | Essex Sprint | SPL | Powerflex | My Car
MaximeT is offline   Reply With Quote
Old 08-30-2016, 10:11 AM   #2
TrqlessWonder
Drives: 2014 FR-S
I ran Hoosier A6's for an autocross season on an otherwise stock car. No chassis issues whatsoever. Don't be surprised if you start picking up the inside rear more.
-Mike
#24 CS/CSR
TrqlessWonder is offline   Reply With Quote
Old 08-30-2016, 11:28 AM   #3
renfield90
The Stig's German cousin
We are blessed with a pretty stiff chassis.
Is your intention to run the stock suspension? You will not run into big chassis flex issues until things get very stiff. Generally chassis stiffening is the last step you take, and only when it becomes a significant percentage of total flex in the system.
Old 08-30-2016, 11:32 AM   #4
MaximeT
MaximeT's Avatar
I use 3 way JRZ 12-32 at the moment with 10/12k springs, full SPL arms and Powerflex Black.
Thanks for the feedback guys
Old 08-30-2016, 11:37 AM   #5
gramicci101
Off Topic
Have you done anything regarding improved suspension bushings? Energy Suspension makes a polyurethane set.
http://www.ft86speedfactory.com/ener...ings-1436.html
http://www.ft86speedfactory.com/ener...ings-1435.html
While CSG makes a crazy spherical bushing set for your entire drivetrain and suspension.
http://counterspacegarage.com/produc...-kit-gt86.html
The tradeoff would be increased NVH. Probably a lot of increased NVH if all of the bushings were spherical.
Old 08-30-2016, 12:31 PM   #6
MaximeT
MaximeT's Avatar
Yes mostly everything is spherical or Powerflex Black.
Old 09-04-2016, 05:37 PM   #7
RJasonKlein
RJasonKlein's Avatar
I have a set of MCS singles and recently purchased all of the spherical bushings in the kit from CounterSpace Garage (I bought them à la cart, because I already had all of the Whiteline and Perrin driveline bushings installed). I'm currently working with MCS and Vorshlag Motorsports to select springs and my car will be used as a daily driver nine months a year. Prior to my decision to run spherical bushings @CSG Mike and I spent a lot of time discussing whether or not they'd be suitable for daily use - once I get everything installed, I'll let everyone know if they're tolerable or just too brutal to live with every day. I also have every SPL Parts suspension and steering piece made, so it's going to be a real test - especially here in the suburbs of Chicago.
Last edited by RJasonKlein; 09-04-2016 at 08:32 PM. Reason: Corrected a typographical error.
RJasonKlein is offline   Reply With Quote
Old 09-04-2016, 05:51 PM   #8
Ultramaroon
not playing cards
Ultramaroon's Avatar
RJ, do you have a build thread? I'm very interested in your results. We have a milder, less corrosive environment here and I'm keen on dailying with sphericals.
Old 09-04-2016, 08:10 PM   #9
RJasonKlein
Hey @Ultramaroon, thanks for the shout out. No, I don't have a build thread, but maybe when I get some time I'll put something together. I'm not trying to hijack this thread, but here's my list of modifications - I thought it may be of interest to you:
- ACE 4-2-1 Type-A 350 equal length header (ceramic thermal coated)
- Motiv catted front pipe (ceramic thermal coated)
- Blitz Nür Spec stainless steel exhaust
- EcuTek Pro ECU programming and datalogging kit
- Delicious Tuning - ECU reflash/stage 2
- 4.56:1 ring and pinion
- Axle-Exchange aluminum driveshaft
- OS Giken 1.5-way LSD
- Rays Gramlights 57Xtreme 18" x 8.5" +42 wheels
- Rays Duralumin black lug nuts
- Raceseng cam plate
- Raceseng CasCam caster and camber plates
- Raceseng Shock Top rear upper shock mounts
- MCS single adjustable coilovers
- SPL Parts Titanium rear lower camber arms
- SPL Parts Titanium rear traction arms
- SPL Parts Titanium rear toe arms w/eccentric lockout
- SPL Parts Pro rear endlinks
- SPL Parts Titanium front lower control arm assembly
- SPL Parts bumpsteer adjustable front tie rod ends
- Cusco rear upper control arm (front) spherical bushing
- Cusco rear upper control arm (rear) spherical bushing
- Whiteline polyurethane differential outrigger support bushing
- Whiteline polyurethane differential bushing
- Whiteline polyurethane transmission bushing
- Whiteline polyurethane crossmember bushing
- Perrin polyurethane steering rack bushing
- Perrin polyurethane shifter bushing
- Perrin engine mount set
- Perrin front control arm brace
- Perrin front endlinks
- Perrin steering rack lockdown
- Project Mu Racing999 brake pads (front & rear)
- TWM Performance short shift kit
- Spiegler braided brake lines
- Spiegler braided clutch line
- MTEC clutch spring
- MTEC shifter springs
- Cosworth drop-in air filter
- Radium master cylinder brace
- Radium strut bar
- Radium dual catch can kit
- Fumoto Quik Valve drain pan bolt
- JMP Coachworks Alcantara steering wheel
- JMP Coachworks Alcantara speaker grills
- JMP Coachworks Alcantara shift boot
- JMP Coachworks Alcantara knee pads
- JMP Coachworks Alcantara coin tray liner
- JMP Coachworks Alcantara rear center armrest
- JMP Coachworks Alcantara instrument hood
- JMP Coachworks Alcantara hand brake boot
- JMP Coachworks leather upper armrests
- JMP Coachworks leather lower armrests
- WeatherTech floor liners
- FR-S engraved plates on WeatherTech floor liners
- Millers Oils CFS 0W20 NT
- Millers Oils CRX 75W90 NT
- Millers Oils CRX LS 75W90 NT
- Torque RT700 brake fluid
Like I said in my prior post, once I get the MCS coilovers and spherical bushings installed, I let you know how they work out on a daily driver - wish me luck...
Last edited by RJasonKlein; 09-04-2016 at 10:04 PM. Reason: Corrected a typographical error.
Old 09-05-2016, 12:53 AM   #10
Ultramaroon
not playing cards
wish me luck...
Definitely, best of luck to you. I'll be following.
Old 09-05-2016, 03:00 AM   #11
Northwest86
Drives: Velocity Orange 86 GT
The New Zealand Racing series uses Slicks. Maybe see if you can contact some of them. Though our people running Hankook Z221's probably aren't that far off slicks to be honest in terms of grip.
Northwest86 is offline   Reply With Quote
Old 09-05-2016, 03:52 AM   #12
MaximeT
MaximeT's Avatar
I think the NZ cars are fully caged, no ?
This one :
http://www.speedhunters.com/2014/01/...ce-mode-engage
Old 09-05-2016, 07:34 AM   #13
EN2_Squirrel
EN2_Squirrel's Avatar
I had axle issues with my hoosiers. So did the FRSPORT car. although both cars are being built for Street Mod. So that may explain of of it.
STREET MOD. My wallet now hates me....
EN2_Squirrel is offline   Reply With Quote
Old 09-05-2016, 07:49 AM   #14
MaximeT
MaximeT's Avatar
Thanks for the feedback.
BRZ - Bumper reinforcement or repair kit Trap63 DIY (Do-It-Yourself) Guides 125 09-07-2026 01:48 PM
WTB - OEM Sway Bar Reinforcement Plates and Stabilizer bar bolts loading_please_wait Want-To-Buy Requests 0 06-16-2015 12:58 AM
Decrease That Flex with FR Sport's "Chassis Reinforcement Sale" FRSport.com Brakes, Suspension, Chassis 0 05-30-2014 01:21 PM
Installing the AVO Rear Reinforcement Bracket AVOturboworld DIY (Do-It-Yourself) Guides 9 10-29-2012 11:44 AM
Beatrush Chassis Reinforcement Group Buy Kami Speed Brakes, Suspension, Chassis 40 07-30-2012 09:39 AM
