Old 09-05-2016, 06:35 PM   #17585
No of course you weren't. Officers didn't get muskets!
OK-OK-OK ........ya got me there ........
humfrz is offline
finch1750 (09-05-2016), jawn (09-05-2016)
Old 09-05-2016, 06:45 PM   #17586
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
just took a nap. now its time to work on the car and see if I can get it to fill up with gas again.
finch1750 is offline
Old 09-05-2016, 08:48 PM   #17587
Dude geese do everything while they are shitting! Not like they grab a copy of Playgander and head off for some privacy. They are nothing but shit factories.
I know but I had hoped to slip it under the wire.
Ultramaroon is offline
Old 09-05-2016, 08:52 PM   #17588
Hey, remember when they upgraded to caplocks? I bet that was pretty awesome, wasn't it?
Old 09-05-2016, 09:19 PM   #17589
Yep, they were much more dependable, especially in the rain ......
humfrz is offline
Old 09-05-2016, 09:21 PM   #17590
hmmm.........I understand the nap part ........ but, what's with the filling up with gas thing .. ??
You been huffing again .. ??
humfrz is offline
Old 09-05-2016, 09:27 PM   #17591
soulreapersteve
Contract? /人◕ ‿‿ ◕人\
soulreapersteve's Avatar
Well, not a premium as such, but when she gives me that sensuous smile, I do leave her a big tip.
Back-in-the-day ....... I might have been able to tell you more about her ......
Oh, I bet you do.
[ame="https://www.youtube.com/watch?v=-nZ_EZTmFxM"]Just the Tip - YouTube[/ame]
The Twins make me smile
soulreapersteve is offline
The Following 2 Users Say Thank You to soulreapersteve For This Useful Post:
EAGLE5 (09-05-2016), humfrz (09-05-2016)
Old 09-05-2016, 10:52 PM   #17592
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Nobody likes the tuna here.
[ame="https://www.youtube.com/watch?v=OaTO8_KNcuo"]It's not a Toomah! - YouTube[/ame]
EAGLE5 is offline
Old 09-05-2016, 10:53 PM   #17593
EAGLE5
Dismember
EAGLE5's Avatar
Tell her, "Don't bet on the horses."
EAGLE5 is offline
Old 09-06-2016, 12:01 AM   #17594
finch1750
finch1750's Avatar
My MR2 sat for a while and I think the breather tube to the filler neck got clogged by something. When I'm at the pump it only lets me put in about .5gal at a time. The DIY I found though is terrible I think or I'm really really stupid. I'll find out tomorrow hopefully when I buddy checks the FSM he has for the info.
Or on a side note anyone have access to All Data and could get me the instructions to remove the fuel filler neck on a 2005 MR2 spyder?
Old 09-06-2016, 12:26 AM   #17595
A reference for you:
http://www.mr2.com/forums/archive/in...p/t-81550.html
I scraped this off the Internet:
"If you've ever noticed, there are two metal line associated with the filler, the larger one and a smaller one. This smaller one is a fueling fill vent.
The hissing that you get when releasing the cap is a problem with the canister and evap control, but this has nothing to do with fueling the tank..
Did you try lifting the nozzle out a bit? Some times on both or my two's (and my supras did this too), if the nozzle is in angle or depth or something, it cause the shutoff to trigger and pulling it out partly would correct the issue... It also only seemed to do it at certain stations too.. I've noticed that some of the newer pumps have a longer spout on the nozzle and I think this is the problem.
Something else to note is that where the filler pipe connects to the tank, the plate assembly that bolts to the tank the the hose from the filler pipe connects to has a flap valve in it. Its a roll over saftey valve to prevent the filler pipe from allowing fuel to fill in it in the event that the car rolls. The flap could be stuck closed for some reason from the last fill or seized in from rust or gum up on the hinge pin or what not....
If you can seem to get it to fill, try taking to heat shield off and remove the hose that connects the pipe to the plate and see if the flap is stuck and try freeing it up."
I asked my friend, Bubba, and he says just to pull the filler nozzle a little ways out of the filler and try again.
If that doesn't work, he says to jam a length of 1/2" garden hose down the filler tube to open up/punch out, the obstruction. He learnt that technique while siphoning gas from his neighbors cars .......
humfrz is offline
Old 09-06-2016, 12:30 AM   #17596
Someone, please translate that for me ......
humfrz is offline
Old 09-06-2016, 12:32 AM   #17597
finch1750
finch1750's Avatar
Tried moving it around. different pumps and stations too. It's been sitting on and off for weeks because of it.
That is the DIY I was reading but I can't figure out what the hell the guy is talking about. I see 3 hoses off the filler neck, not 2, and they are way smaller then what he says and no reason to remove the intake to get to them. Are the heat shields mentioned the ones under the car?
Old 09-06-2016, 12:52 AM   #17598
I'm not sure. I just googled MR2 filler tube, or something like that, and it sent me to a MR2 forum post.
You may wish to sift through some of those forums ........ but, as you know, you can't believe everything that is posted on forums .......
You might use Bubba's garden hose, hooked up to an air compressor to see if you can "blow it clear".
OR, the results could remind me of the time I dropped an Agfa 35mm film camera in a rice paddy so, I took it home and took it apart to dry and clean it up. When I couldn't get it back together, I took the pieces, in a cardboard box, into a camera shop and asked how much he would charge to put it back together.
He told me it would have been $50, if I would have just brought it in to be cleaned, but, now that I messed it up, it would be $100.....
So, I bought a new one.
humfrz is offline
