Old 08-23-2016, 06:32 PM   #1
mhughett
Drives: 2015 Crystal White BRZ Limited
Subaru Coolant at NAPA
For those that are interested, NAPA has the Subaru-compatible blue extended-life coolant for $14.85/gallon. It is Pentofrost A3 coolant. Seems like a good deal to me. Many of us have to add coolant periodically and this should certainly work.
https://www.napaonline.com/napa/en/p...207/AOR8115207
http://www.pentosin.net/specsheets/P...st_spec_A3.pdf
mhughett is offline   Reply With Quote
The Following 4 Users Say Thank You to mhughett For This Useful Post:
1GiantTurtle (08-29-2016), funwheeldrive (09-01-2016), Gabzor (10-17-2016), Sportsguy83 (09-12-2016)
Old 09-01-2016, 12:59 PM   #2
mhughett
Also, while I was there I saw that they also carry a Zerex Asian formula coolant that meets the Subaru spec's and it is in the same blue color as well. It is pre-diluted and is only $14.49/gallon. That's about $10/gallon less than the dealer.
The Following User Says Thank You to mhughett For This Useful Post:
Gabzor (10-17-2016)
Old 09-01-2016, 04:07 PM   #3
nmastereal
Reserve online, pick up in store to save 10% offer valid till 9/7 no coupon needed.
nmastereal is offline   Reply With Quote
Old 09-01-2016, 04:17 PM   #4
ryoma
ryoma's Avatar
that's good to know. always a plus when you don't need to go to the stealership (and the fact that I live 30+ miles away from the nearest subaru dealer lol)
Old 09-02-2016, 06:10 PM   #5
86league
Drives: '13 BRZ Limited
FWIW, Autozone also has Pentosin Pentofrost A3 which is said to be formulated for the Subaru 2009+... $16.99 list - but better than the dealer.
http://www.autozone.com/antifreeze-r...4416_274711_0/
http://www.pentosin.net/f_antifreeze.asp
86league is offline   Reply With Quote
Old 09-12-2016, 01:01 AM   #6
CBRZY
CBRZY's Avatar
Drives: 2017 BRZ PP (White)
Seems like it'll be okay to mix with OEM coolant, but just wanna make sure, is it?
CBRZY is offline   Reply With Quote
Old 09-12-2016, 04:37 PM   #7
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Very good find!
Old 10-14-2016, 08:13 PM   #8
jtanka
Drives: FRS 10 series
Thanks for the info, this helps since the OEM coolant is almost 30 dollar a gallon.
But is the life time the same as the OEM coolant? OP do you know? The OEM one last way pass 100k before the 1st flush.
jtanka is offline   Reply With Quote
Old 10-17-2016, 02:32 PM   #9
mhughett
The Zerex Asian formula is good for 150k/5 years. Not sure about the Pentosin but I know it is a long-life product as well.
Old 10-17-2016, 02:34 PM   #10
mhughett
Just remember with the Zerex that the same formula comes in both blue and red colors and not all stores with have the blue. Advance Auto only had red.
Old 10-18-2016, 03:10 PM   #11
jtanka
I purchased the pentosin on 10/16/16 . My reservoir was at the low mark so I filled it up to about half way when engine is cold.
When it is hot , it will be a little pass the full mark, will update if engine temps get hotter. Thanks for the heads up, the price is more affordable than the OEM coolant.
Old 10-27-2017, 04:42 PM   #12
qqzj
Drives: MDX, Camry
Is there any evidence from Subaru taht Pentonsin A3 and the other stuff works for Subaru cars? Claimed made by Pentonsin is a little fishy. Lots of places claim their ATF is compatible with Honda's and we know they don't always work.
qqzj is offline   Reply With Quote
FS: Subaru Super Coolant Hanakuso Mechanical Maintenance and Tools 0 06-11-2016 04:35 PM
Toyota Coolent & Subaru Long Life Super Coolant Interchangeable? davithedork Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 17 01-05-2016 04:19 AM
SARD UNIVERSAL COOLANT BREATHER TANK , OIL FILLER CUP SCION FRS / SUBARU BRZ myjdmparts Groupbuys 3 09-25-2015 05:48 PM
Subaru OEM Coolant System Additive JDKane527 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 1 05-27-2014 02:24 PM
