Northwest AK, ID, OR, WA
Old 09-02-2016, 02:05 PM   #1
stockysnail
Just the tip
stockysnail's Avatar
Anyone replace their spark plugs themselves yet?
I just noticed that at 60k miles it's time for me to replace the spark plugs in my car. This is going to suck ass! One of the few times having a boxer engine sucks ass. I may be asking for assistance in the coming months.
Oil filter on top is one of the best parts however.
Old 09-02-2016, 02:49 PM   #2
Decay107
Turning is for Nerds
Decay107's Avatar
Drives: 35 characters is not enough
There are posts up that show the correct tools to use, doesn't look terrible, but certainly requires some disassembly.
If the car is still running fine at 60 I intend to run mine longer than the interval. Iridium plugs are normally good for 100K, at least.
Decay107 is offline   Reply With Quote
Old 09-02-2016, 03:42 PM   #3
stockysnail
Just the tip
Are you willing to sign a contract saying I won't need to replace them until 100k?
I know there are DIY but if there were any people that I could talk to in person as in person is always better for me just in case things aren't 100% clear.
The Following User Says Thank You to stockysnail For This Useful Post:
Rio (09-05-2016)
Old 09-02-2016, 05:07 PM   #4
m.box.design
m.box.design's Avatar
Drives: 2013 Whiteout FRS
I saw a post from FRS86 in LA about changing plugs with no disassembly. Probably some handy tool work with the help of mirrors and some witchcraft.
Old 09-02-2016, 05:30 PM   #5
Imrac
Drives: 13 SWP BRZ Prem
With the aid of a mechanic friend, we did it. Prepared for an epic battle, wasn't all that bad.
Not too much disassembly was required. Removed the high pressure fuel pump cover, engine under tray, the two motor mount bolts and that was it.
We jacked up the engine maybe 2 inches to clear the frame rails. Just recommend having several flexy joints for your sockets, a magnet on a bendable wire, and a palm ratchet. Took us about an hour from start to finish.
JDL UEL Headers, Nameless Res&Cat Over&Front, Invidia Q300 Catback, AVO Dry Panel Filter, Custom ECUTek Tune by DriftOffice
191WHP/151 ft-lb on 92
Imrac is offline   Reply With Quote
The Following 2 Users Say Thank You to Imrac For This Useful Post:
86ft.lb (09-15-2016), stockysnail (09-02-2016)
Old 09-02-2016, 05:32 PM   #6
whataboutbob
AutoX-10/10ths every run
The front plugs actually aren't that bad. It's the rear plugs that are difficult as the frame rail tapers in toward the rear of the motor. I unbolted my engine mounts and tilted the motor, one side at a time to do the rear plugs. It is tight back there and you just have to be patient. A finger socket driver is a useful tool for this task.
Build thread:Here
Old 09-02-2016, 06:36 PM   #7
stockysnail
Just the tip
I have Perrin Engine mounts and I heard someone say the bolts suck and if you remove them they should be replaced, so if I have to do that then this will be not as pleasant.
@Imrac you have a same exhaust setup as me and I was tuned at DriftOffice as well for my supercharger. I originally had the Nameless axleback as well but after adding the catless headers I couldn't handle going up hills as it was too loud and the freeway I use has a long hill. I wanted to shoot myself after a while. So happy with the swap to the Q300. I've had a ton of compliments on the sound of my car and I've had the pleasure to listen to someone else drive my car at the track and I agree with people's assessment. I have videos on my youtube if you'd like to hear them.
Old 09-02-2016, 06:46 PM   #8
Toyarzee
Shibby!
Toyarzee's Avatar
Drives: '14 White FR-S, '01 turbo mini taco
Toyarzee is offline   Reply With Quote
The Following 2 Users Say Thank You to Toyarzee For This Useful Post:
Mr.ac (09-06-2016), stockysnail (09-02-2016)
Old 09-02-2016, 07:44 PM   #9
Decay107
Decay107's Avatar
Nope, good luck. Go ahead and try to find yourself some 7/16-18 bolts, I'll wait...
...ok, so you've failed. What is really needed is some thicker washers, I can supply some thick grade 9s.
The Following User Says Thank You to Decay107 For This Useful Post:
Ultramaroon (09-05-2016)
Old 09-04-2016, 02:33 PM   #10
Cooperdh
Hot Lava Lover
Cooperdh's Avatar
Drives: 2013 Scion FR-S- lava
I'm at 55k so looking to change mine in a few months too. Let me know what you come up with.
Cooperdh is offline   Reply With Quote
Old 09-05-2016, 01:53 AM   #11
SnipeD
SnipeD's Avatar
Drives: 15' FR-S MT
I hear this is the tool that does the trick.
http://www.powerhouseproducts.com/ph...socket-5-8html
SnipeD is offline   Reply With Quote
The Following User Says Thank You to SnipeD For This Useful Post:
stockysnail (09-16-2016)
Old 09-06-2016, 01:28 PM   #12
Imrac
I should have said nuts, not bolts No need to remove those, just the nuts on the bottom of the cross member.
Also, +1 on the exhaust setup . What SC did you go with? My car will be paid off within the next 6 months, so it might be time to force some air in there
Old 09-06-2016, 01:57 PM   #13
Decay107
Decay107's Avatar
Actually on the Perrin mounts, they are, in fact, bolts rather than nuts. I so wish they were nuts and studs. In fact, if anyone can point me in the direction of a 7/16-18 stud and flange nut of decent grade I'd be eternally grateful.
Imrac (09-06-2016)
Old 09-06-2016, 02:59 PM   #14
Imrac
Brutal... Why would they use that size?! McMaster-Carr doesn't even carry it!
spark plugs change... fistpoint Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 53 02-23-2022 09:37 AM
Spark plugs for turbo whitefrs Forced Induction 88 05-05-2018 09:18 PM
NGK OEM Equivalent Spark Plugs? wparsons Engine, Exhaust, Transmission 10 05-12-2016 01:09 PM
Spark plugs Triumphrider Engine, Exhaust, Transmission 12 06-19-2014 10:47 AM
spark plugs subaruferrucci Engine, Exhaust, Transmission 22 04-10-2013 11:24 AM
