Old 03-24-2013, 06:22 PM   #1
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
Spark plugs for turbo
Great info by @2forme
Originally Posted by 2forme View Post
SST = Special Service Tool.
Ok, so I did a lot of research this morning. Thought I would share my findings.
The OEM plug is a Denso ZXE27HBR8, which will tell us all about the design of the physical plug.
ZXE - Thread Size x Hex Size - 12mm x 14mm, .55mm Iridium
27 - Heat Step - Equivalent to an NGK 9, Champion 4.59, or Bosch 2
H - Thread Reach - 26.5mm
B - Electrode Design - Triple ground electrode
R - Resistor
8 - Gap - 0.8mm (.032")
Now, with that knowledge, we can "build" a spark plug to our needs. As a general rule of thumb, for every 75-100 hp of FI, you should go one step colder in your plug. This will be your biggest concern when finding a model to fit your needs. One step up in Denso land would be ZXE31HBR8.
Unfortunately, I haven't been able to find any equivalent plugs with those dimensions. Denso, themselves don't even list them. I think it was a completely new model. It's odd to find spark plugs with 26.5mm reach.
The guide to the Denso part number spec is here (pg 12).
NGK lists a spec here.
Hope this helps everyone
Old 03-24-2013, 08:26 PM   #2
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
Need ? No, but you could if you do not mind lifting your engine
Old 03-24-2013, 08:31 PM   #3
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Boom, MINDBLOWN... http://www.ft86club.com/forums/showp...1&postcount=20
This is regarding spark plug change, and I quote:
Originally Posted by ANTI_LAG View Post
I never had to jack the engine up at all, I pulled the plugs from the top. Used a 1/4 ratchet with a short 10mm to remove coil pack bolt then pulled those out then used a standard 14mm socket, slid that in, then used a short extension, push that in, then just barely stuck a 3/8 standard snap on ratchet on it. As long as the car is cold I can do a plug change in about 10 mins.
Work on a 300zx turbo and it makes this car a breeze...
Old 03-24-2013, 08:34 PM   #4
SmsAlSuwaidi
Boosted
But but but I thought the cars manual said .... Argh nvm thanks for the info though
Old 03-24-2013, 08:58 PM   #5
Blue86
Drives: Sonic Blue 86GT Manual
It does! great way to make money for the service department after the warranty is up for a spark plug change.
Blue86 is offline   Reply With Quote
Old 03-24-2013, 09:37 PM   #6
Huehuecoyotl
Drives: Perrin/VORTECH Supercharger TestBRZ
ok, what plugs am I gettin?
Huehuecoyotl is offline   Reply With Quote
Old 03-25-2013, 02:21 AM   #7
Coheed
Coheed's Avatar
Drives: DGM BRZ Limited
The heat range code for these plugs is really cold already. I don't think it is necessary to change them, but you may want to remove them and gap them down a bit if you are experiencing spark issues with boost.
Coheed is offline   Reply With Quote
Old 03-25-2013, 07:41 PM   #8
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Thx guya
Old 03-27-2013, 02:35 PM   #9
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
That did blow my mind. I was thinking about pulling mine to check them along with a quick compression check.
Old 03-27-2013, 02:37 PM   #10
2forme
How are you going to get a compression tester to "screw" in?
Old 03-27-2013, 02:44 PM   #11
King Tut
NASA SpecE30 Racer
King Tut's Avatar
I don't know about yours, but my compression tester has a flexible rubber hose that screws into the spark plug hole. Then I connect it to my gauge.
Old 03-27-2013, 02:52 PM   #12
2forme
Mine does as well, but I don't know how effective it is at screwing in while at a near 90 degree angle.
Old 03-27-2013, 02:53 PM   #13
Huehuecoyotl
how do shop techs do it>? I cant see it fitting, but I have clumsy hands
Old 03-27-2013, 02:54 PM   #14
2forme
They might have an SST.
spark plugs change... fistpoint Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 53 02-23-2022 09:37 AM
spark plugs subaruferrucci Engine, Exhaust, Transmission 22 04-10-2013 11:24 AM
Where do these plugs go from? Z3D BRZ First-Gen (2012+) — General Topics 10 02-18-2013 10:59 AM
Car won't start, no spark? #87 Other Vehicles & General Automotive Discussions 5 12-19-2011 12:29 PM
Jowett Jupiter/spark plugs aspera Engine, Exhaust, Transmission 6 02-25-2010 05:47 PM
