Old 06-12-2012, 02:12 AM   #1
fistpoint
Drives: Supercharged Golf Cart
spark plugs change...
I just got through browsing the BRZ manual and nearly shit when I got to the spark plug section. You damn near have to disassemble the engine to replace them!
Surely there will be an easier way eh? I can't imagine paying the monkeys at the dealership AND trusting them to put all those nuts, bolts and clips back in their proper place.
fistpoint is offline   Reply With Quote
Old 06-12-2012, 05:54 AM   #2
Duff_man
Duff_man's Avatar
Drives: Ultramarine FR-S
If the dealer dosen't do it properly..who's going to?
Duff_man is offline   Reply With Quote
Old 06-12-2012, 07:57 AM   #3
Calum
That Guy
Drives: 2013 asphalt FRS MT
me
Seriously, you're gonna trust your car to someone that gets paid by the job and has every incentive to half ass the job?
Old 06-12-2012, 08:04 AM   #4
lordtakuban
lordtakuban's Avatar
Drives: 2013 FRS - Whiteout
Originally Posted by Calum View Post
me
+1
It's a major PITA by looking at the procedure, but the iridium plugs should last at least 80K miles. They're supposed to go 100K or more, but as they say, YMMV.
2013 FRS - Whiteout - Slightly modified
2001 MR2 Spyder - Super White - Heavily modified
lordtakuban is offline   Reply With Quote
Old 06-12-2012, 08:08 AM   #5
HunterGreene
Hail Magnet
HunterGreene's Avatar
I guess at the end of the day, its a boxer engine. Your spark plugs won't be conviniently located.
Maybe check in on some of the Subbie forums and see if they have any work-arounds for it.
Old 06-12-2012, 10:35 AM   #6
Hawaiian
That guy
Hawaiian's Avatar
Drives: Ultramarine mt FR-S
I thought I had read somewhere that the plugs could be accessed from the wheel wells.
Old 06-12-2012, 06:00 PM   #7
fistpoint
That's my point. I normally do simple stuff like this, but after reading there is no way in hell I'm going to be able to with lack of time or knowledge/tools.
Dealerships are infamous for leaving 2 foot(yes, TWO foot long) wrenches under the hood of my cars, leaving screws/bolts laying around that they forgot where to put back, forgetting to hook up the turbos, forgetting this and that and whatever.
That's why I buy Hondas, because they don't need maintenance beyond oil changes for the most part. The stuff I mentioned above was parents cars and minor wreck fixes for me(not my fault).
So, we're looking at a $200-$300 or more spark plug change. Thankfully it should only have to be done once, but having it done correctly is my major worry.
Old 06-12-2012, 07:37 PM   #8
Calum
That Guy
I gotta say this is gonna be a PITA. With my old Neon I used to sit in the living room, watching TV while I gaped the plugs. Then I'd go out, find my ratchet, extension,& socket and installed the plugs during a commercial break. I could be back on my ass in less then 3 minutes including wiping the tools and putting them away.
Old 06-12-2012, 08:00 PM   #9
phm14
Loves the Smell of Track
phm14's Avatar
Drives: '13 86
Most of the operations on the 86 look easy for a late model car. If this is the only PITA maintenance procedure, and it has a minimum 6 year interval (manual says 60K miles) for me, I'm happy. It's possible I could buy something else by then & won't ever change these plugs, so I don't see a concern for me.
2020 86 Hakone MT build thread: https://www.ft86club.com/forums/show...31#post3326231
2013 Toyobaru 86/FR-S 6MT, Red, aka Candy O SOLD
http://www.ft86club.com/forums/showthread.php?t=7934
phm14 is offline   Reply With Quote
Old 06-12-2012, 08:51 PM   #10
seannyice81
Drives: 2013 Asphalt FR-S
I've replaced the plugs on lots of dohc boxers (Saab 9-2xs). On those, you remove the ignition coil sideways through the gap in the valve cover. Then you insert the plug socket, followed by a short universal extension, followed by a roughly 2 inch extension. You then use a short 3/8 ratchet to get the plug loose, then remove the ratchet and loosen the plug the rest of the way by hand. You then remove tools in reverse order, the plug comes out in the plug socket. Use a bendy-magnet if it doesn't want to come out.
Now, I haven't looked very thoroughly at the plugs and coils. At just a glance it looks, not fun or easy. If I end up trying out a plug replacement (doubt anytime soon), I'll let you know if its the same procedure.
seannyice81 is offline   Reply With Quote
Old 06-12-2012, 08:56 PM   #11
csaba
Drives: scion tc
me
Agree!! I don't trust them either. Good thing I'm very handy...
csaba is offline   Reply With Quote
Old 06-12-2012, 09:48 PM   #12
Shagaliscious
Drives: Firestorm FR-S (MT)
There was another thread about this somewhere, someone said you need to raise the engine up 100mm to gain access to the spark plugs. I'm sure when the time comes, someone will have found out a way to replace the plugs with having to do all that.
Old 06-12-2012, 10:05 PM   #13
Touge Monster
Touge Monster's Avatar
Drives: 85 AE86 Hatch, 92 SW20 , 13 GT86
There is a special service tool that acts as some sort of spacer to allow access to the spark plugs haven't seen one yet. Toyota sent out a bulletin to all the techs for sst "special service tools" about a month and half ago and if it makes anyone feel any better all of the techs will be receiving special training of the FR-S company wide. Toyota/Scion whatever is taking this vehicle very seriously.
Touge Monster is offline   Reply With Quote
Old 06-15-2012, 12:45 PM   #14
GL4787
Toyota Service Writer
GL4787's Avatar
Drives: Whiteout M/T, 2003 Duramax
me
yeah, because losing their job isn't "incentive" enough to do good work. Some technicians take pride in the jobs they do. Just because you've obviously had a bad experience or two doesn't mean every tech on earth is an unknowledgable dirtbag that's only worried about a paycheck.
Whiteout Manual
I'm a service writer at a Toyota/Scion dealership, if I can help at all let me know.
GL4787 is offline   Reply With Quote
spark plugs subaruferrucci Engine, Exhaust, Transmission 22 04-10-2013 11:24 AM
Spark plug type and heat ft86-UAE Engine, Exhaust, Transmission 4 06-10-2012 10:21 AM
Do you change your own oil? If so, why? SteelReign Other Vehicles & General Automotive Discussions 76 04-15-2012 04:44 AM
Car won't start, no spark? #87 Other Vehicles & General Automotive Discussions 5 12-19-2011 12:29 PM
Jowett Jupiter/spark plugs aspera Engine, Exhaust, Transmission 6 02-25-2010 05:47 PM
