Old 08-30-2016, 04:45 PM   #43
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Complex geometry doesn't change the basic fundamental mounting points. A Porsche is still a strut + lower control arm, and a Ferrari is still a double wishbone.
You can check here where the forces are going with a double wishbone:
[ame="https://www.youtube.com/watch?v=-S6H7ZdzBfE"]Strut Bar - Explained - YouTube[/ame]
Old 08-30-2016, 04:57 PM   #44
gramicci101
Off Topic
Rather listen to someone who's graduated high school already, thanks.
Old 08-30-2016, 05:19 PM   #45
CSG Mike
CSG Mike's Avatar
I guess this car needed a strut tower brace. It's a Porsche GT4.
FRS Justin (08-30-2016)
Old 08-30-2016, 05:24 PM   #46
Pat
Pat's Avatar
Drives: 2023 BRZ
Whoa. Do you know the story?
Old 08-30-2016, 09:01 PM   #47
CSG Mike
CSG Mike's Avatar
Went over a larger berm at Thunderhill, but not one that I would consider something like the red berms of death at Laguna...
Old 08-30-2016, 11:39 PM   #48
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
Originally Posted by gramicci101 View Post
Speaking of transferring points of failure and spot welds coming apart, check this out.
http://www.ft86club.com/forums/showthread.php?t=105791
Because of that, if I were to buy a strut bar I would buy one that mounts all the way around the strut using all three bolts, not one that uses the existing strut brace points.
Whoa.. "Your honor, I'd like to present Exhibit A".
Joking aside. Stuff like this is why seem welding is desirable.
PRO86 | WTCC | STL
The Following 2 Users Say Thank You to rice_classic For This Useful Post:
FRS Justin (08-31-2016), Jonsey (09-02-2016)
Old 08-31-2016, 02:44 AM   #49
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Porsche 911s don't have in front a double wishbone suspension. If someone changes the spring rates and go x2 or x3 stiffness, then he is fool enough to race without having extra bracing or other reinforcements. Personally, I' m not a Porsche fan and I don't care what someone should do in these cars. I KNOW what I should do in Subaru cars. And I am not saying I am smarter than others. I am just following the leaders. Mainly STi and a few others.
Old 08-31-2016, 12:48 PM   #50
CSG Mike
CSG Mike's Avatar
Changing the spring rates doesn't change the load experienced in the same area.
What it does change, is the spring constant, which means less compression. The load itself is unchanged.
Old 08-31-2016, 04:34 PM   #51
jmimac351
Chin Chief Instructor
jmimac351's Avatar
Drives: 2015 Ford F150 Aluminium Couch
Listen to CSG Mike. I've watched 2 other BRZ track cars owned by close friends with, literally, a few thousand miles on each car at Sebring alone, not to mention tracks all around the country. These cars are not babied. Neither car has had an issue that a strut tower bar would address. It's a waste of money. Period.
2015 Subaru BRZ
2008 NC Miata with 2.5 swap
Building 1963 289 Cobra Le Mans Replica
Cobra Replica Build Pics
Chin Chief Instructor www.ChinTrackDays.com
jmimac351 is offline   Reply With Quote
The Following 2 Users Say Thank You to jmimac351 For This Useful Post:
CSG Mike (08-31-2016), Pat (08-31-2016)
Old 08-31-2016, 09:00 PM   #52
stevesnj
stevesnj's Avatar
Originally Posted by FRS Justin View Post
This is a bad example to compare a Typical style bar too.. The TRD uses different mounting points and brackets that are a lot stronger than what a typical bar uses......
I wasn't comparing, I was just stating what TRD is doing.
My 2016 Build thread
The Following User Says Thank You to stevesnj For This Useful Post:
Old 09-01-2016, 11:25 PM   #53
ROADRACER
Drives: unlimited cheap build N/A track car
What it does change, is the spring constant, which means less compression. The load itself is unchanged. __________________
So are you saying stiffer springs will not increase the force exerted on the strut tower?
ROADRACER is offline   Reply With Quote
Old 09-02-2016, 09:17 AM   #54
OkieSnuffBox
Drives: '23 BRZ Limited
What it changes is the speed of weight transfer.
The Following User Says Thank You to OkieSnuffBox For This Useful Post:
Racecomp Engineering (09-06-2016)
Old 09-02-2016, 12:55 PM   #55
Sleepless
Sleepless's Avatar
Drives: 2016 FR-S
And the force over time. So, the tower will see higher forces with a stiffer suspension over the same lap.
Serious hairsplitting and discussion for a really cheap device which does what it is supposed to do; reduce chassis flex at the struts and distribute loads between the two towers.
Sleepless is offline   Reply With Quote
Old 09-02-2016, 01:24 PM   #56
Pat
Pat's Avatar
Drives: 2023 BRZ
Yeah, I think I'll pass on getting one now.
But I do wonder, after the chassis has 150,000 hard miles on it, would the strut tower brace be more noticeable and effective?
Time Trial BMW M3 endless_pain Cars for Sale/Trade 1 11-28-2014 03:02 PM
Strut Tower Bar VS Strut Tower Brace norcalpb BRZ First-Gen (2012+) — General Topics 8 10-23-2014 10:31 PM
New Time Trial & Performance driving group Saul_Good Rocky Mountains / Great Plains 3 06-25-2014 08:22 PM
FR-S sets new Time Trial track record at Roebling Road! Arsenal Autosport Tracking / Autocross / HPDE / Drifting 28 08-18-2013 06:45 AM
FT86 cup time trial sw20kosh Northern California 5 03-27-2013 03:27 PM
