Old 08-20-2016, 08:32 PM   #29
Originally Posted by exE36M3 View Post
FWIW - a throwout bearing isn't going to make any noise when you are driving. It just floats there until you push the clutch in and engages the pressure plate. ............
Well now, @exE36M3 , I had that same misconception before ol @Ultramaroon educated me .......
Apparently, the FR-S has an "active" release bearing (TOB). It runs anytime the engine is running. However, it just "works" when the clutch is pushed in. A very slight pressure from the slave cylinder keeps it in contact with the fingers of the pressure plate at all times.
So, if is really bad, it can howl without the clutch being pushed in.
Old 08-20-2016, 11:32 PM   #30
For the record, I didn't assign a specific name to the system. I don't really know if it's called anything special. It's a run-of-the-mill, self-adjusting hydraulic clutch. And yes, the TOB is rotating 100% of the time. ...unless it's starting to seize. Then it screeches.
Old 08-21-2016, 12:17 AM   #31
Well then, I think I will change my reference name of that kind of TOB form "active" to "constant-contact".
That's more descriptive ......
Old 08-21-2016, 12:47 AM   #32
I think it's just a cable-versus-hydraulic thing, no? I'm with you. I just wonder if there are any functional variants.
Old 08-21-2016, 02:26 AM   #33
Yep, best I can figure is that most all hydraulic clutches have constant contact TOBs.
Old 08-21-2016, 11:26 AM   #34
exE36M3
Yes, i did some more reading on that topic gentlemen. You learning something new everyday!
exE36M3 is offline   Reply With Quote
Old 08-21-2016, 01:45 PM   #35
Yep, we stick together ...... and we can all learn ......
......except fer ol @Tcoat ....... and he thinks he knows it all .......
Old 08-21-2016, 02:50 PM   #36
Nope. But I do know what I don't know and that helps.
Old 08-21-2016, 03:06 PM   #37
hmmmm.........how does one know what they don't know"..... if they don't know, if what they don't know, even exists .......
Next we shall discuss the tree falling in the forest .........
Meanwhile, if I can get mrs humfrz showered up and dressed, we are going to take a ride up into the hills of the coal country. Yep, back in the day, they mined coal not to far from here ......
Old 08-21-2016, 04:34 PM   #38
Old 08-21-2016, 04:53 PM   #39
Fuck off, Rummy.
differential, loose bolt, transmission
Horrible bucking and shutter after clutch install Scikotic Engine, Exhaust, Transmission 32 07-12-2016 08:10 PM
Runduce 6-Speed Transmission Gear - 500hp botbs Engine, Exhaust, Transmission 10 11-22-2015 02:59 PM
is it ok to slip my clutch often in 2nd gear when my rpm is below 2k? awhatzable Scion FR-S / Toyota 86 GT86 General Forum 88 06-17-2015 06:12 PM
What's this clunk sound coming from 2nd gear after letting go of the clutch ? awhatzable Scion FR-S / Toyota 86 GT86 General Forum 17 04-30-2015 02:14 AM
Cold morning and horrible grinding/screeching sound Books Issues | Warranty | Recalls / TSB 1 11-14-2012 02:18 PM
