| Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
Long term E85 use and Lubes
I've been running e85(oft) for about 15k miles and wonder if I should be using any FUEL additives. I've read on other forums that some people use two stroke tc-w3(ashless, burns clean?) and lucas upper cylinder lubricant.
Would those lubes burn clean? Would it help keep things lubed? Is it snake oil? Would they do more harm than good? Is e85 that much more "dry" than e15 gasoline? -Off topic- Air oil separator/oil catch can takes out the oil that would otherwise be put into the intake, which is bad? Since engine oil isn't designed to burn(?) or does not burn clean? therefore creating deposits and gunking up the engine? Last edited by swarb; 08-16-2016 at 01:23 PM. |
#2 |
Drives: Rb25 neo brz
I have been running e98 for 2000 Hard track miles and only saw contamination when i had a return style setup with my catch cans. that being said i would keep that in mind with return style systems. As far as lubricants go we have not seen any issues on the valves and everything is running proper.
| The Following 6 Users Say Thank You to -Phil For This Useful Post: | Bowen (08-16-2016), civicdrivr (08-16-2016), DAEMANO (08-15-2016), DoomsdayJesus (08-15-2016), swarb (08-16-2016), Teseo (08-15-2016) |
#3 | |
Senior Misanthrope
1) Make sure the oil is ILSAC GF-5 2) Change the oil a bit more frequently, like every 4-5k |
| The Following User Says Thank You to kch For This Useful Post: | swarb (08-16-2016) |
| Long Term FR-S | regal | Scion FR-S / Toyota 86 GT86 General Forum | 83 | 04-01-2016 06:40 AM |
| long term and short term | brichard0625 | Engine, Exhaust, Transmission | 7 | 08-26-2013 08:56 AM |
| Long term | Bt216 | Scion FR-S / Toyota 86 GT86 General Forum | 3 | 06-06-2013 11:58 PM |
| Fuel Trims - Long term and short term | victorb | Engine, Exhaust, Transmission | 6 | 03-27-2013 02:18 PM |
| Short Term and Long Term Fuel Trims | naikaidriver | Engine, Exhaust, Transmission | 3 | 03-18-2013 09:55 PM |
