Old 08-15-2016, 02:46 PM   #1
phantasticity
Ricer
OFT questions
I'm about to get an OFT at the shop today, and I have some questions about it. Like, how do you go from stage 1 to stage 2? Can you go straight to stage 2 after on stage 1? And for example, I'm running 1320 headers right now. If I want to switch to Nameless headers later on, would I have to re-tune? And how would I do that?
Sorry for newbie questions.
phantasticity is offline   Reply With Quote
Old 08-15-2016, 02:52 PM   #2
gramicci101
Off Topic
If you already have a header, you don't need to go stage 1 at all. You can go straight from stock to stage 2.
The OFT will come with five common maps loaded already, one of which should be 91 Octane UEL Stage 2. The actual flashing process is pretty simple, and the device walks you through it. OpenFlash also has a youtube video on their site at http://www.openflashtablet.com/shop/oft-frs-brz-gt86/. Watch the video a few times first.
Is the Nameless header also UEL? Then the same map will apply. If it's EL, you'll need an EL map. Additional maps can be found on OpenFlash Manager, which is software you can install on your computer. OFM is also useful for updating your tablet.
Old 08-15-2016, 02:56 PM   #3
Toyota John
Calle Atun
Drives: 13 FRS, 93 Mr2, 85 ae86
Open Flash Tablet tunes are really just base tunes. They are not going to be header specific except for EL and UEL. The rest is up to you if you want to take is further.
Toyota John is offline   Reply With Quote
The Following User Says Thank You to Toyota John For This Useful Post:
phantasticity (08-15-2016)
Old 08-15-2016, 03:08 PM   #4
phantasticity
Ricer
Old 08-15-2016, 07:22 PM   #5
phantasticity
Ricer
The Following User Says Thank You to phantasticity For This Useful Post:
EffaressNOOB (08-15-2016)
Old 08-15-2016, 07:52 PM   #6
EffaressNOOB
EffaressNOOB's Avatar
Drives: Halo 2016 Scion FR-S, 6MT
Originally Posted by phantasticity View Post
WAIT, if I switch to EL do I need to go back to the original file, before tuning again?
No. Just flash the tune you want to switch to. Remember, Stage 1 is for catted headers and Stage 2 is for catless headers. You didn't mention that in your earlier posts...or maybe you did.
Enkei TFR (Copper) 17x9+45 | Hankook Ventus V12 Evo2 245/40 | Tein Flex A
OFT Stage 2, E85 | Kraftwerks Skunk2 CAI
Open Flash Unequal Length Header
Invidia N1 CatBack
InstaGram: 49RJ
EffaressNOOB is offline   Reply With Quote
Old 08-15-2016, 09:44 PM   #7
everythingsablur
everythingsablur's Avatar
Drives: 2016 Scion FR-S RS 2.0
Is that really the difference? I thought Stage 1 was for stock headers, and Stage 2 was for aftermarket headers (regardless of catted or catless), with the necessary EL or UEL variations therein.
2016 Scion FR-S Release Series 2.0 #170/1000
everythingsablur is offline   Reply With Quote
Old 08-15-2016, 10:01 PM   #8
phantasticity
Ricer
I'm wondering too. I just picked up the OFT, and just went for stage 2 UEL 91 oct. Going to get E85 tomorrow, since it's only 11 miles away from me. Sadly there's no 93 in CA..
Old 08-15-2016, 10:04 PM   #9
phrosty
Yup, stage 2 is for catless. Everything is tuned for the less restrictive environment.
phrosty is offline   Reply With Quote
The Following User Says Thank You to phrosty For This Useful Post:
everythingsablur (08-15-2016)
Old 08-15-2016, 10:12 PM   #10
EffaressNOOB
If you have the stock header (catted EL), you can run Stage 2 E85 EL according to @steve99
"Rough guide OTS Map Requirements:
Stage 1- For vehicles equipped with original header. Other exhaust modifications also compatible. Stock airbox (with or without aftermarket drop-in panel filter) also recommend. Premium grade fuel or fuel as specified by tune.
Stage 2- For vehicles equipped with aftermarket cat-less headers. Other exhaust modifications also compatible. Stock airbox (with or without aftermarket drop-in panel filter) also recommend. Premium grade fuel or fuel as specified by tune
91 (USA) octane or better required for 91 octane tunes
93 (USA) octane or better required for 93 octane tunes
Its ok to use a higher octane than specified by the tune but not a good idea to use a lower octane fuel than specified by the tune.
E85 required for tunes labeled E85 (ie fuel with 60 to 90% ethanol content)
Exception for Stock cars running E85 use Stage 2 E85 EL header tune" http://www.ft86club.com/forums/showthread.php?t=67310
Invidia N1 CatBack
InstaGram: 49RJ
The Following User Says Thank You to EffaressNOOB For This Useful Post:
everythingsablur (08-19-2016)
Old 08-15-2016, 10:18 PM   #11
phantasticity
Ricer
I have a catless header, 1320 performance headers.
OFH+OFT Questions Timmy_Jones Engine, Exhaust, Transmission 8 10-07-2014 03:08 AM
Some questions about the FRS E46C204 Scion FR-S / Toyota 86 GT86 General Forum 49 08-25-2014 01:28 AM
Wax Sealant Pad Questions / Care Questions l0aded Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 3 03-25-2014 11:19 AM
TRD kit questions Tofu driver's Fr-s Cosmetic Modification (Interior/Exterior/Lighting) 28 07-30-2013 03:04 AM
E85 questions Grishbok Engine, Exhaust, Transmission 17 08-08-2012 10:49 PM
