Spun
Drives: 23' Supra
OFH+OFT Questions
Hey guys, have a few quick questions around the OFH+OFT products.
The only mod on my car right now is the Manzo exhaust, other than that completely stock. I am looking to make daily driving a bit more fun and get rid of the awful torque dip…and it seems like the Open Flash combo is the way to go. I live in Maine, so there is a visual inspection, with the tuner, will it delete the CEL from removing the header cat? Is it normal to run just their header with the rest of the exhaust stock? Will my secondary cat still function normally? As long as the CEL isn’t on, I will be good to go. Does the tune for their header require a drop in filter? I don’t have an aftermarket intake and am not really interested in one, unless someone has a suggestion for one that works particularly well. |
This combo is great bang for your buck. Yes the CEL is disabled so it does not show. Its perfectly fine keeping the rest of the stock exhaust. It will help with any drone or rasp with catless headers. Best 1000$ you can spend that adds power, makes the car drive smoother and will remove the torque dip.
2013 Series 10 FRS #553
Drives: FR-S,GTI
I have the OFH+OFT and Manzo Exhaust. And it sounds fantastic. No worries about the cat. The secondary one works fine by itself and the tune cancels out the CEL. I have a K&N drop in filter but it is not required. You really can't go wrong with the OFH+OFT. The only bad part of the deal is the wait for the header. But in the end it is well worth it.
Spun
Drives: 23' Supra
Thanks guys, I am probably going to be in touch with them shortly. Seems like exactly what I want, and since it fits under the stock heat shield, I can get away with it at the dealership.
Drives: White gts on gt rims
Drives: CBS BRZ
If youre talking about the header, you can see it just by looking down in the engine bay. Its not hard to miss.
All kinds of gains....
Circle Work Clerk
Drives: 2012 Mt. Fuji Red Toyota 86 GTS
I'm planning on running the Tomei UEL header + Overpipe, with OFT.
I already have the Invidia Q300 which is quiet, but has a low grumble. Plan to keep the stock front pipe so the finished exhaust will sound powerful, but not obnoxious. |
#8 | |
Drives: Honda Civic
That is the setup I am looking for! Tomei UEL + stock front pipe + OFT + a catback. |
Drives: 2013 white out FRS
so u know u well fail emissions..i dont think the 2nd cat well be able to let u pass
| Wax Sealant Pad Questions / Care Questions | l0aded | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 3 | 03-25-2014 11:19 AM |
| TRD kit questions | Tofu driver's Fr-s | Cosmetic Modification (Interior/Exterior/Lighting) | 28 | 07-30-2013 03:04 AM |
| HID / LED questions | RealShkillz | Cosmetic Modification (Interior/Exterior/Lighting) | 7 | 06-01-2013 05:15 AM |
| E85 Questions... | ScionFrsFan | Engine, Exhaust, Transmission | 25 | 03-12-2013 10:47 AM |
| E85 questions | Grishbok | Engine, Exhaust, Transmission | 17 | 08-08-2012 10:49 PM |
