Old 08-13-2016, 08:47 PM   #1
Skyllz
Drives: Something fun.
Header Rust resistance...
Anything better than the other out there? Does ceramic coating help? Not that i'll drive my BRZ alot in the winter but it will see some snow. It is something to consider up here in Canada.
About to order an OFT+OFH3 unless there is an argument for something better out there.
Skyllz is offline   Reply With Quote
Old 08-13-2016, 10:08 PM   #2
phrosty
Have run OFH through two salt-filled winters, no signs of rust. I'd expect other headers made with 304SS (which is basically all of the well-known ones) would perform equally well.
Our engine bay stays pretty clean, and any water will quickly boil off the header. I hope rust won't be a problem but we all know there is no perfect steel. I imagine ceramic would help prevent it even more, but not sure if it's needed.
phrosty is offline   Reply With Quote
The Following 2 Users Say Thank You to phrosty For This Useful Post:
humfrz (08-13-2016), Skyllz (08-13-2016)
Old 08-13-2016, 10:34 PM   #3
OK, @phrosty addressed the question ........ let's move on ...... nothing else to see here .......
Old 08-15-2016, 11:55 AM   #4
Cole
Not a troll
Cole's Avatar
Just to further @phrosty point...
While the ceramic coating will not eliminate corrosion entirely, it will be effective at reducing the amount of corrosion that takes place, and it will take longer to happen.
Cole is offline   Reply With Quote
Shift resistance natesparxxx Engine, Exhaust, Transmission 10 04-30-2014 10:23 PM
Shift resistance amaciose Engine, Exhaust, Transmission 2 12-06-2013 08:53 PM
Shift resistance going into gate (notchiness) 1Cor10:23 Engine, Exhaust, Transmission 14 12-06-2013 07:16 PM
noise when releasing clutch/shift resistance abutterman Issues | Warranty | Recalls / TSB 11 07-20-2013 09:23 AM
Brake resistance Teo Tracking / Autocross / HPDE / Drifting 3 03-08-2013 03:03 PM
