Old 12-06-2013, 10:25 AM   #1
1Cor10:23
1Cor10:23's Avatar
Shift resistance going into gate (notchiness)
Hi all,
I know there's a few topics regarding irregular shift feeling but was wondering if anyone experienced harder shifting starting to develop after break- in.
Currently, at 4k miles. No grinding but it definitely feels like there's more resistance going through each gate as you row through the gears.
I know going up or down into 2nd is always going to be rough however, just recently 3rd and 4th started to feel notchy with an extra push or tug required to get fully into gear. Before going up into 3rd and into 4th and down from 4th to 3rd was perfectly smooth and effortless (since no lateral movement required).
With car turned off, rowing through gears feels like it should, only resistance when running and driving.
Anyone with similar experience?
Sent from my SGH-I317M using Tapatalk
Old 12-06-2013, 10:54 AM   #2
brn12345
brn12345's Avatar
I Have the same thing. Used to be only 2nd. Now 3rd and 4th not so great. Have been advised to change oil. Guess ill try that.
brn12345 is offline   Reply With Quote
Old 12-06-2013, 11:02 AM   #3
humfrz
No, mine seems to shift quite smoothly, especially after it gets warmed up.
However, if it did shift notchy, the first thing I would do is change the transmission oil.
humfrz
Old 12-06-2013, 11:05 AM   #4
Anthonytpt
Anthonytpt's Avatar
Drives: '13 Argento 6MT FR-S
Is your car warmed up? I see you're in Canada so I felt the question would be relevant. Additionally, as you've observed, there are plenty of threads addressing shifting resistance or the like. The remedies include swapping out the fluids, installing a positive shift kit, rear shifter bushing, and/or getting a short shifter.
Anthonytpt is offline   Reply With Quote
Old 12-06-2013, 11:18 AM   #5
1Cor10:23
1Cor10:23's Avatar
Yes, fully warmed, engine was at 90+c. Ironically, this started happening yesterday, which was the warmest day of the past 2 weeks.
I'm thinking changing the trans fluid would be a good first step. Would a short-shifter change the feel even if rowing with the stock shifter while off is perfectly smooth? I'm thinking it's more to do with the trans and not the shifter itself.
Old 12-06-2013, 11:21 AM   #6
DarkSunrise
DarkSunrise's Avatar
I think this shifter will always be a little notchy, but are you making sure to lift between shifts? That helps.
2022 BRZ Build
2013 FR-S Build
Old 12-06-2013, 11:24 AM   #7
lickitysplit
Don't care
Drives: 2013 Whiteout FRS
After putting my Kartboy Short Shifter, the Kartboy rear shifter stay, and amsoil oil my shifts are fantastic.
lickitysplit is offline   Reply With Quote
Old 12-06-2013, 12:08 PM   #8
1Cor10:23
1Cor10:23's Avatar
Could you elaborate on "lift"? Thanks!
Old 12-06-2013, 12:12 PM   #9
350matt
Drives: toyota mr2/ Toyota GT86
he means you don't have your accelerator foot flat to the floor during a gearshift
might also be worth bleeding the clutch fluid as well as considering some fresh gear oil
350matt is offline   Reply With Quote
Old 12-06-2013, 12:19 PM   #10
DarkSunrise
Try completely lifting your foot off the gas pedal between shifts. There's a bit of rev-hang with these cars, and it's important that the RPMs drop in between shifts to make the syncros' job easier. In turn, that will enable you shift easier and quicker into each gate.
2022 BRZ Build
2013 FR-S Build
Old 12-06-2013, 12:40 PM   #11
OrbitalEllipses
Drives: Attitude
Bro. Never lift, bro.
Old 12-06-2013, 12:48 PM   #12
1Cor10:23
1Cor10:23's Avatar
Yeah I'm definitely fully off gas before clutch-in
Old 12-06-2013, 12:48 PM   #13
DarkSunrise
Yep true story.
2022 BRZ Build
2013 FR-S Build
Old 12-06-2013, 06:57 PM   #14
1Cor10:23
1Cor10:23's Avatar
Who knows, maybe it's all in my head
noise when releasing clutch/shift resistance abutterman Issues | Warranty | Recalls / TSB 11 07-20-2013 09:23 AM
HUD shift up and shift down display question JS86JS Electronics | Audio | NAV | Infotainment 6 05-17-2013 02:54 AM
Brake resistance Teo Tracking / Autocross / HPDE / Drifting 3 03-08-2013 03:03 PM
How do you shift? Carbon420 Scion FR-S / Toyota 86 GT86 General Forum 27 12-30-2012 01:11 PM
No more 1st gear thump or 2nd gear notchiness kc4mne Scion FR-S / Toyota 86 GT86 General Forum 28 09-06-2012 08:39 PM
