Legend
Drives: BRZ Limited
Slave Cylinder Upgrade for Heavy Clutches?
Hi guys, I was wondering if there is an upgrade for the slave cylinder for those with aftermarket clutches? Some of the aftermarket clutches makes the clutch pedal a lot stiffer and I was wondering if there's a solution around this?
On some cars like the late Supra, they sell aftermarket slave cylinders to make the clutch pedal feel lighter especially if they're pushing high power which requires a higher performance clutch. Is there such a thing for the twins? I have searched high and low for it but I can't seem to find any information on it.
#2 |
Off Topic
Have you actually identified the need for this with your clutch? Most people are going the other way. They're removing the clutch spring to get a heavier, more communicative clutch pedal.
#3 |
Drives: blue - Cosworth SC stage 3.0
you just need a slightly smaller diameter slave cylinder?
measure up the bore of the existing part and go for a 1/16" smaller this will increase pedal travel but reduce the effort |
#4 | ||
Legend
Drives: BRZ Limited
#5 |
Drives: swp mt '14 brz premium
I think you have it backwards.@ Ultramaroon suggested that we switch from the OEM 13/16 to 3/4 to get more feel. I did so and got more feel. I think you'll need a 7/8 if you're using the original one and it's too heavy.
| The Following User Says Thank You to jcw99 For This Useful Post: | Ultramaroon (08-08-2016) |
#6 |
stop skipping leg day lol. I do sympathize with you though if you drive in stop and go traffic with a heavy duty pressure plate. you'll get used to it eventually though. my previous car had a heavy clutch pedal with an aftermarket ACT clutch + PP and I eventually got used to it, even in traffic. try adjusting your clutch pedal to see if you can make it better. I like my engagement point to be about an inch off the floor and it makes it easier in traffic as well.
#7 |
[insert cool phrase here]
Drives: BRZ Premium
Should have got an Auto if you complain about heavy clutch pedal.
Weekend fun/track car - '91 MR2 Turbo Gen3 Old daily driver - '88 MR2 Supercharged |
#8 | |
Legend
Drives: BRZ Limited
Thank you for your contribution to the thread. Your words have touched me deeply.
#9 |
Drives: BRZ Premium
Lol. Nah all joking. My MR2 turbo has a OS Genkin twin plate, talk about heavy clutch.... I daily driven that beast for years, my left calf was much beefy. But after a week you get used to it.
Ya know, leg day bro.
#10 |
Hmmm, how about using a multi-disc clutch? I hear they can be finicky but that would be the way to go if you want to get more grab with less force.
Also consider that the weak spot in the driveline is the transmission. The stock clutch will slip before fourth gear grenades.
#11 |
Drives: Scion FRS || Ducati 899
Lol the amount of cancer from this thread,
I'm also interested in a slave cylinder alternative |
#12 |
Legend
Drives: BRZ Limited
I don't mind paying a pretty penny for someone to build me a custom slave cylinder. Anybody know of one in the Southern California (preferably OC) area? If not then what about online?
#13 |
Site Moderator
Drives: ichi 86 Project
| The Following User Says Thank You to ichitaka05 For This Useful Post: | Drakiv (08-10-2016) |
#14 | |
yes if you want a heavier pedal then increase the master bore, it will increase pedal feel but that wasn't the request take a look at this site for a easy calculator to plug in values http://www.markwilliams.com/braketech.aspx another option is to change the pedal ratio to increase the travel and the leverage on the master |
| The Following User Says Thank You to Matt@Cosworth For This Useful Post: | wootwoot (08-09-2016) |
| DIY - Swap clutch slave cylinder and hydraulic line for improved feel and control | Ultramaroon | DIY (Do-It-Yourself) Guides | 452 | 02-18-2023 09:58 PM |
| FS: OEM Clutch Slave Master Cylinder | MicheleAbbate | Transmission and Driveline | 3 | 05-09-2016 04:48 PM |
| Clutch Slave Cylinder | KAR | Southern California | 4 | 08-08-2015 09:25 PM |
| OEM Clutch Slave Cylinder $20 shipped | SlowCone | Transmission and Driveline | 0 | 04-25-2015 05:07 PM |
| BRZ headlight upgrade, paint, demon eyes (PICTURE HEAVY) | Lee358 | Cosmetic Modification (Interior/Exterior/Lighting) | 59 | 04-18-2014 12:42 AM |
