Old 03-11-2013, 10:37 PM   #1
Lee358
Lee358's Avatar
Drives: nissan frontier, DGM MT BRZ
BRZ headlight upgrade, paint, demon eyes (PICTURE HEAVY)
Ok guys and gals i think its time i made a thread on this forum about my upgrade to my headlights. Ive had a lot of help from the guys of Hidplanet.com with this and as of right now im still not finished.
This is not complete i messed up some of the paint so that has to be redone and im not done playing with the projectors then i need to mount the led's and i should be done.
The point of this was to show you guys 1 what im doing and a kind of DIY if you need anything clarified please let me know also any questions please feel free to ask!! (i am three weeks into this today its not as easy as the frs headlights!!) i am also not responsible if you mess up your headlights!!
so i started off with this diy right here steps 1-15
http://www.ft86club.com/forums/showthread.php?t=8788
Thank you @DarrenDriven
cars apart.
here is where it gets different brz/frs
first pull out your HID bulbs
then you can take out all your wiring and your ballast some people say this has to be done some say it does not before putting your headlights in the oven.
you see there is a rubber gasket there to keep moisture out and there is a hook inside the actual light holding the wires in place.
unplug your ballast and your good to put them in the oven
for 15 min
MAKE SURE no wiring is touching your oven!!
everything pulled apart
The BRZ comes stock with the Lexus RX350-Bx projector after some research i have found out that the projector is one of the best on the market. BUT it comes with a "fresnel" lens which looks like this
and a clear lens looks like this
you can do a lot of reading on clear lenses at the retrofit source. When swaping your lens out you can either have your oem ones polished or use a STI-R lens with slight modification. i chose to send mine out to have them polished.
For those wondering which wires control the LED "boomerange"its the green/black coming out of the back of the headlights.
Get everything ready for paint
and then paint
make sure everything important is taped off (cutoff shield solenoids)
Primer
Base coat
Clear
put everything back together to admire your work
put everything back together bulbs and all but obviously dont bake anything you dont have lenses! The reason for this is to get your projectors hot make sure everything still works after it has been painted and also you are some what baking the paint on to your cutoff shield.
once this is done and everything works you can move onto your led's i order wedge led's off ebay in color red and the bases are from superbright led.com
With lenses i found it was best to shine the led from the side
testing my output
Lee358 is offline   Reply With Quote
Old 03-11-2013, 10:43 PM   #2
Hardrock4445
Hardrock4445's Avatar
Nice work soo far! On car pics yet?
Mods: Perrin CAI, JDL EL header, DC sports Catless front pipe, top speed auto pro-1 cat-back, H&R sport line springs, Headlight blackout, "Demon eyes"
Hardrock4445 is offline   Reply With Quote
Old 03-11-2013, 10:46 PM   #3
Lee358
Lee358's Avatar
no not yet i put them on real quick tonight to test my output but it was too dark for pics and i messed up some paint to i cant put them back together yet.
Old 03-11-2013, 10:48 PM   #4
Hardrock4445
Nice, I've considered taking mine apart again and painting reflectors also, and regret not removing "squirrel finders" while I was in there.
Old 03-11-2013, 10:49 PM   #5
Lee358
Lee358's Avatar
dude just upgrade to the HID projectors they look so much better!
Old 03-11-2013, 10:56 PM   #6
JPxM0Dz
F Z1LLA
JPxM0Dz's Avatar
Drives: Lexus IS-F Series 2
Nice job!
Sent from my Note 2 on Omega Rom
2URGSE
JPxM0Dz is offline   Reply With Quote
Old 03-11-2013, 10:58 PM   #7
Hardrock4445
Rather spend little on cosmetic and more on performance.
Old 03-11-2013, 11:58 PM   #8
Lonewolf
Lonewolf's Avatar
Drives: Moped
Did you really just paint in your bathroom...getting overspray everywhere...lmao
Old 03-12-2013, 12:06 AM   #9
Lee358
Lee358's Avatar
Its an old bathroom in the basement i put a space heater down there to control the temp and painted away.. Its never used and going to be ripped out anyways!
Old 03-12-2013, 12:44 AM   #10
Lonewolf
Lonewolf's Avatar
Drives: Moped
Nice, I thought that you were like f--- this bathroom, the car is more important!
Old 03-12-2013, 01:09 AM   #11
Lee358
Lee358's Avatar
Well i mean the car is more important... House smelled like paint for days!
Old 03-16-2013, 01:09 PM   #12
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
Why did you choose to have the stock lenses polished over getting the STI-R lenses? Only reason I ask is your cutoff (assuming the pictures of it are with the polished lenses) doesn't look nearly as sharp as it should be. How far away from the wall were you?
Can't wait to see completed pics. I had no idea these housings used the RX350 bi-x projectors. I absolutely love mine.
Sent from my Nexus 4
Parting out HERE
civicdrivr is offline   Reply With Quote
Old 03-16-2013, 01:48 PM   #13
Lee358
Lee358's Avatar
Those are un tuned from about 10 feet i chose this route because in order to fit the sti-r you must use a sanding wheel to widen the lens holder the oem fits right back in... When i get home from colorado on tuesday im going to add washers to tune the cutoff. Should only take one #6 washer on all sides and some playing around. Either way with the sti-r or oem polished the projector must be tuned.
Old 03-17-2013, 12:44 PM   #14
disgruntld
Less than pleased...
disgruntld's Avatar
Drives: '13 BRZ Ltd SSM 6MT
looks amazing... @__@
disgruntld is offline   Reply With Quote
Will Demon Eyes affect light temperature output? (also the legality) boredom.is.me Cosmetic Modification (Interior/Exterior/Lighting) 6 01-04-2013 05:37 PM
It is almost SEMA time!!! (Picture HEAVY!) Apex Chase Other Vehicles & General Automotive Discussions 11 10-30-2012 09:16 PM
DIY Red Tint and Smoked Tail Lights (PICTURE HEAVY) ninjasaurusrex DIY (Do-It-Yourself) Guides 1 10-27-2012 09:08 PM
Headlight lens question (demon eyes) WolfsFang Cosmetic Modification (Interior/Exterior/Lighting) 19 09-30-2012 02:58 PM
More Official SCION FR-S Photos (picture heavy) (from Las Vegas test event) ichitaka05 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 34 04-27-2012 06:11 PM
