Old 08-06-2016, 01:16 AM   #15
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
The torque "dip" exists because that's how you get the superb fuel economy of this car.
Old 08-06-2016, 01:26 AM   #16
My take is that the "dreaded torque dip" is nothing but a line on a graph.
Like said, under normal driving, you shouldn't notice it (and if you hadn't read about it, you might not have noticed it). If your driving it hard, you shouldn't be in that rpm range......
See, how easy it is to "get past it" .....
MTpockets (08-24-2016), WWFT86 (08-23-2016)
Old 08-06-2016, 02:08 AM   #17
CSG Mike
CSG Mike's Avatar
Ace header + tune.
Old 08-06-2016, 02:10 AM   #18
WWFT86
Drives: 2017 BRZ Limited
Gotcha. I can't tell you how much this BRZ reminds me of the integra Type-R I had 16 years ago.. Time for some neuroplaticity again and learn to drive the car to its potential.. just like the Type-R
WWFT86 is offline   Reply With Quote
The Following User Says Thank You to WWFT86 For This Useful Post:
humfrz (08-06-2016)
Old 08-06-2016, 04:57 AM   #19
steve99
Drives: FT86
Originally Posted by WWFT86 View Post
Found older posts but would like to see what's the mid-2016 opinion on eliminating the torque dip while minimizing noise?
Will the OFT stage 1 alone do it? If it's a aftermarket header which one is known to be quietest?
Thanks
A tune alone from any vendor wont eliminate torque dip just reduce it
A tune with E85 fuel will go close
A tune plus decient cattless header will get rid of it UEL headers usually work best in that mid rpm area,
Ace header works well and combines best of el and uel headers but its expensive and you will require a specific tune for that header. it good but will likely cost you north of $2000
if your just interested in eliminating torque dip a decient uel header like grupp s and an off the shelf tune will do it for about $1000 all up
DAEMANO (08-06-2016)
Old 08-06-2016, 05:36 AM   #20
JD001
JD001's Avatar
Drives: Subaru BRZ
I think it exists to make it feel fast much like turbo lag back in the ole days of turbo charging............nothing for ages...........itch the itch..........think about what you want for lunch/ supper..........then whoaah! Oh then desperately applying the brakes for corner that suddenly appears unexpectedly quickly...
The Following User Says Thank You to JD001 For This Useful Post:
chaoskaze (08-25-2016)
Old 08-06-2016, 07:57 AM   #21
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Don't think the mid 16 opinions have changed much.
Nope. the only answer is still get a Hellcat
Old 08-06-2016, 09:03 AM   #22
Pointmutation
Pointmutation's Avatar
Drives: 2016 ZC6
Noise level is a consideration though as I work shifts.
Interested in what you end up with. I was thinking of doing headers but I work shifts too and don't wanna piss off the neighbors too much. Lol. I'm leaning towards something catted since my FP isn't catted anymore, just resonated.
Pointmutation is offline   Reply With Quote
Old 08-06-2016, 09:36 AM   #23
Lantana frs
Drives: 13 frs red
On a good day my car feels reasonably quick. When the ecu detects improper planetary alignment, 10 percent humidity, or somebody farts within a 5 mile radius it pulls with the authority of a diesel vanagon.
Lantana frs is offline   Reply With Quote
The Following 4 Users Say Thank You to Lantana frs For This Useful Post:
10Stars (08-07-2016), JD001 (08-07-2016), mizzta21 (08-08-2016), Ultramaroon (08-07-2016)
Old 08-06-2016, 01:33 PM   #24
Ro_Ja
Drives: TOYOTA
This made me laugh, lol. Mostly at how true this is...
Ro_Ja is offline   Reply With Quote
Old 08-06-2016, 08:38 PM   #25
Mr.Impreza
Mr.Fujitsubo
Mr.Impreza's Avatar
Drives: 2018 STI
Thanks
These options below won't eliminate it 100%, but improve it while staying very quiet.
Option 2 of course would benefit more since your removing the stock header but it will be a pricey method if your goal is to have a quiet ride.
Option 1 (Keeping Stock Header)
Stage 1 OFT Tune
Aftermarket Drop in Filter (HKS, Apexi, K&N)
Aftermarket Inlet Tube (Perrin, Mishimoto)
Catless Fujitsubo Dual Resonated Front Pipe
Quiet Catback Exhaust (Fujitsubo Authorize R, Blitz VS/VSR , Invidia Q300)
Option 2 (Quietest Cat-less Header option)
Stage 2 OFT EL-Tune
Apex'i EL Catless Header + overpipe + catted & resonated front pipe (This comes in a 3pc set only)
Hope this helps you a little bit.
2015 Toyota 86 ~ The Sold Car ~ Build Journal
OFT Stage 1 Tune Review
Mr.Impreza is offline   Reply With Quote
The Following 2 Users Say Thank You to Mr.Impreza For This Useful Post:
Lantana frs (08-07-2016), WWFT86 (08-24-2016)
Old 08-07-2016, 12:27 AM   #26
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Supercharge it.
Old 08-07-2016, 12:15 PM   #27
Lonewolf
Lonewolf's Avatar
Drives: Moped
Thanks
No point in trying to address something that you may not even notice once you drive the 2017's as the mt cars will have some engine/gearing improvements...
The Following User Says Thank You to Lonewolf For This Useful Post:
WWFT86 (08-24-2016)
Old 08-07-2016, 04:48 PM   #28
churchx
churchx's Avatar
Drives: 2014 GT86
Mr.Impreza: if goal is to have quiet ride, i'd be careful which intake to choose (if any), as some remove stock resonators and may actually be louder then stock. I'd rather simply would do sound tube delete (you can do quick test if that's what you want by plugging it using glovebox ciglighter plug), which as side gain will also lessen road noise getting into cabin.
Least harmful additives to eliminate crickets Muskokan Issues | Warranty | Recalls / TSB 46 05-07-2017 12:10 PM
Eliminate oil pressure switch? @Art_Mighty Engine, Exhaust, Transmission 13 09-17-2015 09:23 PM
The truth behind the option to dealers to eliminate the scion part Frstorm Scion FR-S / Toyota 86 GT86 General Forum 8 08-21-2013 03:37 AM
Best Method to Eliminate Sand ShoShin Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 6 07-29-2013 04:45 PM
Cheapest way to eliminate the torque dip allawd Engine, Exhaust, Transmission 42 04-24-2013 09:40 PM
