Old 07-20-2016, 12:05 AM   #1
Nah
Drives: 2013 Scion Frs 6mt
Open Flash Turbo Tuning Level 9000
What the f***...
(my first words when looking at the SBD base tune for oft for the first time.)
Let this thread be for the top level DIY'ers...
This thread has been created for three reasons
1) To instill knowledge onto those who dare dip into the dangerous world of Forced Induction Tuning.
2) To challenge the minds of the experienced and wise.
3) And for the car gods... may there be more boost. Boost = Hot B******
Let's make this thread epic. We as a community must come together and dissect the changes made to each map in the SBD base tune.
We will answer two simple questions
1) Why the change was made
and
2) How it effects the motor
Lets make a name for ourselves. It may take years but boost and b****** aren't going anywhere.
Except with us.
link for base tunes http://www.ft86club.com/forums/showp...21&postcount=1
Nah is offline   Reply With Quote
Old 07-20-2016, 12:10 AM   #2
Nah
The first table changed is Manifold Pressure Sensor Scaling... It seems that the multiplier is decreased considerably from an NA tune and the offset is changed to .001. Any reason as to why?
Old 07-20-2016, 12:30 AM   #3
steve99
Drives: FT86
the tune is likely for a different MAP sensor likely an Omni 2.5, 3 or 4 bar rather than stock MAP sensor
Omni 2.5 Bar MAP
The OFT300 (Vortex supercharger) map uses the 2.5 BAR Omni and has CEL-P0068 disabled in the map
ok for 2.5 Bar OMNI MAP sensor ECUTEK scaling in BAR
Manifold Pressure Sensor multiplier in bar per volt. = 0.500
Manifold pressure sensor offset. Value is measured in bar. = 0.100
MAP Sensor voltage max = 5.0v
MAP sensor Voltage min = 0.0v
Omni 3 Bar MAP Sensor (Metric in Bar)
0.617 - MULTIPLIER
0.03 - OFFSET
scaling limits 0 - 4.75v
Omni 4 Bar MAP Sensor
Manifold Pressure Sensor Scaling - (imperial PSI)
Multiplier - 12.087
Offset - 0.168
Metric/Bar
bar/volt .833
offset (bar) .012
Manifold Pressure Sensor Limits - (CEL still comes on )
High Input CEL Above - 5.00v
Low Input CEL Below - 0.00v
Disable CEL P0103 and P0068
Old 07-20-2016, 12:34 AM   #4
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
I don't see anything wrong with it or any tables you wouldn't normally change. You guys are using wrong definitions if you can see stuff you don't understand.
Old 07-20-2016, 12:39 AM   #5
steve99
Drives: FT86
@Nah you might want to start with bad noodles tuning guide , its for wrx but relivant for turbos
http://forums.nasioc.com/forums/show....php?t=1626520
Old 07-20-2016, 12:43 AM   #6
steve99
Drives: FT86
as @Wayno said make sure your useing correct definitions,
from memory those sdb tunes were not calid hacked like a lot of oft NA tunes
break out the hex editor and check all three calid in the rom file
also make sure your using either metric or imperial definitions if say your using kodemane47 defs or romraider or oft.
all roms are actually metric but the def may scale values for display in either metric or imperial.
Old 07-20-2016, 03:03 AM   #7
Nah
ahh I see... no wonder all the scales are all outta wack... makes sense...
Im going to look at that info for turbo's.
Never used a hex editor actually.
So what definition file would I use to read the SBD base tune? Because when I hit the "compare maps" literally over a 150 maps have been changed and every scale is way different from what im used to seeing but like you guys said probs due to me not having the def files...
Old 07-20-2016, 06:23 AM   #8
steve99
Drives: FT86
yes i suggest you read my Romraider tips thread linked below.
if your playing with roms and definitions you need to be able to use hex editor to confirm calid or calid hacks and understand how definitons work and recognise mismatch tunes and defs else bricking ecu is possible.
Tuning turbo cars is difficult, i would suggest if you want to learn then you buy the sbd turbo kit, which will come with a free unlocked tune.
you can safely bolt that kit on and run the tune which will run well, then you ca log and make minor tweaks to the tune. Starting from scratch will be extremly difficult and dangereous for most people (including myself)
Old 07-22-2016, 03:06 AM   #9
Nah
Well... im thinking this...
i'd tune MAF at idle first... then give it light revs... then take it up to 3k. 4k. so on and so forth. just focusing on A/F.
timing would come after
its all the other factors that are involved... we could definitely make changes to a base map in regards to drive ability... I want that base map.
Old 07-22-2016, 12:19 PM   #10
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
The kit uses a 3 Bar Map sensor.
OFT no longer provides a free tune with the Kit that I know of. When they went to 10psi wastegate, Shiv decided that custom tuning was the best way to keep the car safe. So you have to pay for tuning.
It might be worth asking though.
Old 07-22-2016, 11:27 PM   #11
lee1rbc
lee1rbc's Avatar
Yeah, for me I received the tune from Shiv. The only areas I have been willing to adjust is ignition, AFR and MAF scaling.
2013 BRZ Limited current mods: TD05 20g turbo - Invidia over pipe and catted down pipe - Magnaflow catback - Enkei Fujin wheels. BFG comp 2 A/S 225-45-17.
lee1rbc is offline   Reply With Quote
Old 07-22-2016, 11:51 PM   #12
steve99
Drives: FT86
yep newer 10psi kits you buy custom tuning, but original lower power 7 psi kit you got free map included. Both would be open and allow further mods though by end user (at their own risk) .
DustinS (07-24-2016)
Vinshu Tuning Open Flash Tablet RedFRS4me User/Vendor/Sponsor Reviews, Feedback, Comments 4 06-22-2016 02:56 AM
Open Flash Tablet Tuning Question Fish Head Software Tuning 7 01-21-2016 12:35 PM
Tuning for 86 in SA CPI - Open Flash units Fuzz AFRICA 29 03-15-2014 01:08 AM
Open Flash tablet brz/frs tuning Ocho Seis Canada Classifieds 4 02-08-2014 11:11 PM
