Student Driver
Drives: 2016 Subaru BRZ Limited
DIY Camber Bolt Install?
This may be a dumb question, but I'll ask it anyway. If I'm installing the OEM front upper camber crash bolt, can I just do it myself at home, or do I need to get a professional alignment? I'm new to suspension work, so I want to make sure I don't screw anything up.
I'm running C Street autocross, so I'm looking to get maximum front camber while staying within the class rules. Seems like the OEM camber bolt is the way to go. I watched the Savage Geese DIY install video, and the job itself doesn't seem hard. But it wasn't clear whether the change would screw up alignment. |
#2 | |
Not Bаnned Anymore
Drives: Heavily Modified FRS
#3 |
Off Topic
If you have the tools, you can do your own install. It's pretty easy. It's possible to do your own alignment, but if you're asking about how to do one, just get it done professionally and tell them that you want to max out your front camber.
| The Following User Says Thank You to gramicci101 For This Useful Post: | Prmspen (07-19-2016) |
#4 | |
The Stig's German cousin
OP, you will want to max out the camber yourself, then take it in and ask for a toe alignment. You want max camber anyway since a CS car never has enough. If you know any local autocrossers, ask them where they get alignments done since you will want a tech who has a better understanding of your needs and a willingness to do a through, quality job. FYI, the toe change is negligible. I never bothered to get mine aligned and didn't notice any change in tire wear or handling. FYI #2, torque it properly (torque wrench on the nut, not on the bolt). I think the torque spec is 119 ft-lbs. If it's loose or not quite to torque spec, no, your strut will not disconnect from your hub and cause a calamity. You will however get some, shall we say...dynamic...camber. Don't ask how I know.
#5 | |
Student Driver
Also, I hear you on torquing things correctly. One day I'll tell the story of what happens when you don't torque the lug nuts on your Chump Car, then put it on a dolly and try to tow it to the track...
#6 | |
If you were to install camber plates or something and set camber in the -2 to -3 range, you would definitely want an alignment. The toe change is larger at that point. Some people swear by the importance of alignments for autocross, my take on them is just make sure it's not grossly wrong. The thought of the average chump car losing its wheels spontaneously honestly makes me laugh a bit. Almost like you'd expect something like that to happen.
#7 |
Student Driver
In fairness, only one wheel fell off. In the middle lane of an interstate. On Friday afternoon in rush hour.
| The Following 2 Users Say Thank You to Prmspen For This Useful Post: | timurrrr (08-09-2019), Ultramaroon (07-22-2016) |
#8 |
1/16" change in toe is definitely noticeable in how the car drives. Max out the camber, then get the front toe set to zero.
#9 |
Drives: Hyper Blue BRZ
I did this not long ago. Pretty straight forward. I just maxed out the camber on both sides and it is very close to the rear camber from the factory around -1.0. Using home made toe plates, there was virtually no change to the toe. I was expecting the toe to change. It is still so close to zero toe I didn't both getting an alignment and have noticed no unusual wear in 2K miles. Your results could vary. BTW, this change along with some different tires made a hugh difference with the front turn in.
#10 |
Drives: FR-S Whiteout
I've gotten as much as -3.0* out front using camber bolts on an otherwise stock suspension. Not sure what people are doing if they're only getting 0.5* adjustment out of camber bolts.
Intent > Content
cowardice is the mother of cruelty. |
| The Following User Says Thank You to solidONE For This Useful Post: | timurrrr (08-09-2019) |
#11 | |
Student Driver
I'm going with the Subaru bolt so I can still run C Street autocross. |
| The Following User Says Thank You to Prmspen For This Useful Post: | timurrrr (08-18-2019) |
#12 | |
Edit: @Prmspen I'm not sure what the rule books allow, but from the sound of it anything that's factory subaru/toyota is legal? Perhaps you can find a smaller diameter crash bolt that give a bit more slop to give you a bit more range of adjustment. Like this part: http://www.toyotapartsdeal.com/oem/t...105-14147.html I believe this is a 12mm diameter bolt from toyota. And will probably give you a bit more camber adjustment. Though the thinner diameter will obviously be weaker than the 14mm, also not sure of the legality in the class you are running.
Intent > Content
cowardice is the mother of cruelty. Last edited by solidONE; 07-22-2016 at 12:44 AM. |
| The Following User Says Thank You to solidONE For This Useful Post: | Prmspen (07-22-2016) |
#13 | |
Drives: '13 FRS - STX
Greatly appreciate the SPC part numbers though, I think I need both to get enough camber for an STX car and the info is a bit buried. -3.0 with just bolts you say... Delicious, I was only getting ~-1.1 with the 16mm bolt in the top hole.
#14 | |
Undisputed El Presidente
Drives: Zenki 37J ZN6
Really camber plates are the way to go |
| Camber bolt + suspension bolt torque settings | LostSalad | DIY (Do-It-Yourself) Guides | 3 | 05-09-2016 09:29 AM |
| Will OEM camber bolt install affect alignment | B-R-Z | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 9 | 05-23-2014 11:30 PM |
| Alignment needed after front camber bolt install? | ayau | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 60 | 08-31-2013 12:13 AM |
| Whiteline Camber bolt install | TimR | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 3 | 06-06-2013 08:33 AM |
