Drives: Limited Lightning Red
Whiteline Camber bolt install
Got the 16 mm bolts and it appears the struts have to notched to get them to go in. Anybody who has done this install know differently?
Drives: 2012 Toyota 86
i ordered the part off of ft86speedfactory and they fit fine and are 16mm. try loosening the bottom bolt so you have some play. what part number did you get?
Just the tip
Drives: 2013 Lightning Red Subaru BRZ Mt Lt
I had to shake mine (the shock) a little when putting it in. Make sure you get an alignment afterwards.
Current: 2013 Lightning Red Subaru BRZ Limited
Past (sold): Click here to see previous cars and bikes ![]() |
Got them in. Just took a little finesse as suggested. And aligned it with 1.2 degrees of negative camber which I am happy with
| Whiteline Camber bolt.... Help | FRSFirestorm | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 24 | 04-28-2017 03:15 PM |
| Alignment needed after front camber bolt install? | ayau | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 60 | 08-31-2013 12:13 AM |
| FS: rce yellows & whiteline camber bolt $300 | chappys4life | Mid-Atlantic | 19 | 05-13-2013 02:31 PM |
| [SYD] Brand new SPC 81280 16mm camber bolt (Whiteline rebrand these as their own) | eckoflyte | Australia Classifieds | 1 | 03-31-2013 11:02 PM |
