go_a_way1
Old 06-28-2016, 11:42 PM   #3165
Riseuporfall
Riseuporfall's Avatar
Drives: 2016 scion frs
Originally Posted by Slick View Post
That should fit neatly within the fenders without issue.
I was wondering the same thing but would it fit with a 225/40r18 without rubbing the insides?
Sent from my E6853 using Tapatalk
Riseuporfall is offline   Reply With Quote
Old 06-29-2016, 12:09 AM   #3166
Riseuporfall
Would a 225/40r18 fit on a scion frs in all four corners without rubbing?
Old 06-29-2016, 06:31 PM   #3167
Riseuporfall
Shouldn't rub. I have 18x8+45 with 245/35 front no rubbing. I would suggest a 225/40/18 over the 225/45, because the 225/45 is 1.35 inches taller than stock. Too much. The 225/40 is already a 1/2" taller, so it will help fill the gap and be closer to stock diameter. The rule of thumb is +/-%3 or less.
Tire calculator.
http://www.discounttire.com/dtcs/infoTireMath.do
I wanted to run 18x7.5r18 offset of +45 with 225/35 in the front and 18x7.5r18 with 235/40 in the back would that setup work on stock suspension or no?
Old 06-29-2016, 08:37 PM   #3168
the_comedian312
Drives: '13 BRZ 6MT Limited GBS
Hey what's going on guys. I currently have 18x9.5+38 wheels sitting in my house and I was wondering if rocking 255/35/18 all around would cause any fitment issues? I'm sitting on full stock suspension right now.
the_comedian312 is offline   Reply With Quote
Old 06-29-2016, 09:12 PM   #3169
HuntingtonFRS
Drives: 2013 Scion FR-S in White
That's wide. Look up the tool on the forum that shows fitment and you can compare to stock so you don't go too big or too small
HuntingtonFRS is offline   Reply With Quote
The Following User Says Thank You to HuntingtonFRS For This Useful Post:
the_comedian312 (06-29-2016)
Old 06-30-2016, 02:54 PM   #3170
the_comedian312
The tool said I'd be good on stock suspension so I'm gonna go ahead and mount them up today.
Old 06-30-2016, 03:18 PM   #3171
swarb
That tool only takes into account of the outside clearance. It does not have any reference to the inside clearance. Your wheel will be very close to the strut up front. Some people have no problems, some people rub. The clearance will be about ~5mm or less.
Mount them, lower the car, and stick your phone up there and take a video/pic and decide for yourself if you feel that clearance is enough for you. Every car is slightly different with alignments etc, so no real way to know for sure unless you try it.
Old 06-30-2016, 03:23 PM   #3172
the_comedian312
Thanks for the help man I'll be sure to check it out
Old 07-06-2016, 04:08 AM   #3173
Jaydemm
Drives: 13' SWP Voltech Supercharged BRZ
I'm dropped on RSR Superdown Springs on stock suspension. I'm curious to know whats the best specs on wheels i could run? Looking to possibly do 18's maybe 17s? Please help a n00b :]
Jaydemm is offline   Reply With Quote
Old 07-06-2016, 05:00 AM   #3174
swarb
Best is relative.
Looks (subjective)
Cost (relative)
Performance (objective??)
Pick two.
And in order if importance.
Old 07-06-2016, 05:13 AM   #3175
Jaydemm
Best is relative.
Looks (subjective)
Cost (relative)
Pick two.
Looks wise, track inspired(RPF1, NT03)
Cost under 2k
Objective as a daily driver, don't want anything to aggressive but would like it to be flush with the RSR Superdown springs
Thanks in advance
Old 07-06-2016, 02:54 PM   #3176
swarb
Cost under 2k
Thanks in advance
Rpf1 17x9 +35 with good summer tires. 245/40-17
18x9.5 +38 won't fit or are dangerously close to rubbing on the front strut. Higher offsets would fit but you would probably need a 5mm spacer.
The Following User Says Thank You to swarb For This Useful Post:
Jaydemm (07-06-2016)
Old 07-11-2016, 12:47 AM   #3177
MatthewF
Drives: Scion FR-S
Looking for help with tire sizes.
I have 18x8.5 +35 wheels for the front and 18x9.5 +35 for the rear. Also, I'm on stock height.
If some of you could help me with suggestions on what size tires I should get I'd be very appreciative.
MatthewF is offline   Reply With Quote
Old 07-15-2016, 09:03 PM   #3178
chargedup
Drives: SC BRZ
about to install some coils w/ front camber and throwing a new wheel setup on-
17x9 et~20 all around. the fitment tool shows they should be right at fender but haven't seen anyone run this setup yet. 215/45's up front, 225's out back. any experience?
chargedup is offline   Reply With Quote
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 10:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 03:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 03:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-13-2012 12:21 AM
