Old 07-11-2016, 05:58 AM   #1
megamarines
megamarines's Avatar
Drives: 2015 FR-S RS 1.0
Send a message via AIM to megamarines
ISC Control Arm Clunking and Noise
Hey guys, I've had some ISC V2 Control Arms on my car for a few months now, and at low end speeds they're always clunking/groaning every time I go over any form of terrain or get in and out of my car. I've had my alignment done twice and all parts inspected, but there's no running and there's no wear and tear markings that would be a sign of damage.
Do I need to grease the point on the bearing to reduce noise or what? As time goes on its only getting louder and louder while becoming very obnoxious.
megamarines is offline   Reply With Quote
Old 07-11-2016, 11:02 AM   #2
Ashikabi
Ashikabi's Avatar
Clunking could be sway bar links binding. Drive it up on ramps, loosen both ends of end links then retighten with equal weight on both sides. The grinding I guess could be the ball joints in the links or maybe the bushings in the LCAs... not sure what to do if it's the bushings. Another alignment isn't going to help though. Maybe your bolts are too tight? Try a torque wrench
Old 07-11-2016, 08:50 PM   #3
sosick
fastest frs in sbg
sosick's Avatar
Drives: sick ass ultramarine frs
I have the same issue with these then i switched to v1 and its still the same thing. I checked everything over back there and i cant find a damn thing
2013 ultramarine frs sold
2014 turbo ultramarine frs Sold
2014 firestorm frs
sosick is offline   Reply With Quote
Old 07-12-2016, 03:46 AM   #4
megamarines
It's AGGRESSIVELY loud too, right? Gets worse in the heat?
Old 07-12-2016, 04:28 AM   #5
sosick
fastest frs in sbg
sosick's Avatar
I notice it over slow bumps and i hear alot of squeaking
2014 firestorm frs
Rear suspension clunking noise. Help ): dito Suspension | Chassis | Brakes -- Sponsored by 949 Racing 38 09-15-2016 04:09 AM
Tire Clunking Noise darko Issues | Warranty | Recalls / TSB 5 04-01-2016 03:57 PM
kw v3 rear making clunking noise eera Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 12-17-2015 05:10 PM
Clunking Noise After LCA Install Bach415 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 23 07-06-2015 04:24 PM
clunking noise after LCA install starron Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 05-17-2015 05:02 PM
